Author Topic: Hot water - Do or Don't?  (Read 11384 times)
Offline SeLFMaDE
« on: November 27, 2009, 04:57:43 PM »
Just found out I have a plumbing problem and will need to replace and reroute some pipes. One of the pipes by chance happens to be the one that goes out to the hose I use for washing my cars. It's currently a cold water line and can easily be switched to a hot water line. It's no secret that hot water cleans everything better, but are there any dangers of using hot water our cars and newer cars in general? Could the top shrink? Could the seals be damaged? Is the paint too thin or soft to handle it? Anybody who uses hot water, please share your experience.
Re: Hot water - Do or Don't?
« Reply #1 on: November 27, 2009, 06:05:21 PM »
You run the risk of cracking the windshield if you try to wash a car with hot water on a cold day...  or so I'm told.
« Reply #2 on: November 27, 2009, 06:54:15 PM »
Washed my car to the gas stations and I know first program of their self washing posts is with hot water.
I washed it even this week twice, outside temp 42-50 F (6-10 C) without any problems.
Offline DaveOC
  • Running Wisconsin
« Reply #3 on: November 27, 2009, 06:57:16 PM »
Not any worse than using cold water on a very hot day.  Yes it's possible to crack a windshield, but not likely.
Aggressive #000741
Offline baconbits
« Reply #4 on: November 27, 2009, 07:46:22 PM »
Hot or cold...just don't wash it like this..
http://www.break.com/index/the-ultimate-car-wash.html
« Reply #5 on: November 27, 2009, 08:04:55 PM »
You could always put both hot AND cold water outside like I did. It's nice to take the chill off the water when washing. A tap from Moen like the this is nice.
Or do like I did and simply use a set of laundry taps on the outside wall.
« Reply #6 on: November 27, 2009, 08:17:49 PM »
Sly Bob ;   ITs not been out that long and is frost proof . When I was up there in August I could have done that for you. Even had my tools with me. I got one rite after they were in the supply  house . Put some silicone around it so the wall is water tight.Nice job
« Reply #7 on: November 27, 2009, 09:21:11 PM »
Thanks for the offer 1 LIL NDN , it really is a nice looking tap. The one in the picture I got from another site though. All I have is a modified set of laundry taps in the garage that work really well.
I have tools too.  :D  I am a licensed plumber and gas fitter in the province of Ontario.
Offline SeLFMaDE
« Reply #8 on: November 27, 2009, 09:27:39 PM »
That Moen tap is nice. Any info on where I can get one or what the model number is?
« Reply #10 on: November 27, 2009, 11:50:15 PM »
SLY   All Bobs are Plumbers and I even have a Twin also a Plumber . We're  slow down here. My company here was All About Plumbing  and Bro's is R F K Plumbing .
 still working but want to retire and spend more time working on my Cars and House
 68 and counting   :gaah:
Offline BLK GXP
  • Rollin'
« Reply #11 on: November 28, 2009, 01:00:24 PM »
A few years back the cold silcock froze on the front of my house even though it was frostproof. Since I had to fix it anyway I turned it into the garage instead of out the front of the house. I also ran a hot line with it, and bought a laundry faucet. It was kind of crappy and leaked, so I rigged up a set of ball valves, and put some heat trace cable on it. Having hot water out there is great for all sorts of things. I even used it to clean out the turkey fryer pot. I use it plenty on the cars with no problems at all.
And no, I am not a plumber. I am an Electrician
« Reply #12 on: November 28, 2009, 04:23:34 PM »
BLK GXP    IT Shows  LOL   OH ya  The frost proof hydrants don't freeze UNLESS you leave the hose connected   A Lesson for all in the winter if you turn your water off to the outside faucet remove the hose and turn the faucet on ( only open faucet if the water is off inside house if its not frost proof)
   Will send my Bill Later. " Work is slow "   This is known as Professional
   Tech Advice
« Last Edit: November 28, 2009, 04:41:51 PM by 1 LIL NDN »
« Reply #13 on: November 28, 2009, 04:40:40 PM »
So your name isn't Bob then?  :fishing:
Nice setup for the taps. Here's mine in the garage. They are old laundry taps that I had given to me 20 years ago so I don't know how old they are but I haven't so much as had to change a washer. They were originally fed from the top and had a swivel spout where the center valve is now.
[attachment=1]
« Reply #14 on: November 28, 2009, 04:56:43 PM »
Well they look like Gerber,  About 30 yr old were the better sets inverted all Brass works. ita easier to have a mixing valve  I have Gerbers in my bathroom 28 yr got a rebuils kit and still brand new Best faucet made I think
     OH    My given Name is Robert but I think YOUNG  I go by Bobby
« Last Edit: November 28, 2009, 05:02:29 PM by 1 LIL NDN »
« Reply #15 on: November 29, 2009, 12:25:50 AM »
Yeah my given name is actually Robert as well.
This is what the taps that I have in my garage would have looked like when they were new. The site I got the picture from says they sell them for $45 US. By the time you modify them and add a backflow preventer it'd be cheaper to buy the Moen ones.
Offline ccanepa50
« Reply #16 on: November 29, 2009, 02:00:15 AM »
I am surprised no one has mentioned that washing the car with hot water can  mean  waxing more often (as the heat can break wax  down)......
BTW, i notice that in these faucet pix that a few installations have a valve on the outlet,  if you were to leave the outlet valve off or hose end off and the other 2 valves open you can  get hot and cold crossing over leading to interesting results (as  water flows the path of least resistance), things like hot water to the toilet, tepid hot water,  etc..... some faucets have check valves built in to prevent this potential.
(and yes, its my occupation)..........chuck
« Reply #17 on: November 29, 2009, 10:04:30 AM »
Yes you probably would wax more with HOT water but I just use the hot to warm up the cold. Using hot water wouldn't be comfortable, you would risk burning yourself and why waste hot water?
Your concern about a cross connection is valid. I turn off all 3 taps when I am done. I use the center one to turn the water off and on but when the job is done they all are off. I found this out shortly after installation because of the tepid hot water that I found when using the hot in the house.
Overall, it's been great and has served me well for that time as 20 years ago there weren't the options that there are today.
I would definitely go the Moen route if I were to do it today.
Plumbers sure have great tastes in cars...  :D
Offline Poorboy
  • Expired Vendor
    • Poorboys World
« Reply #18 on: November 30, 2009, 11:53:03 AM »
well here's my take on it and BTW those are some nice set ups  :drool: ....
no problem washing with hot water, but would you take a shower with only hot water? I don't think !! so unless you turn the temperature on the water heater way down ... you need one of the set ups above .. to give a moderately warm wash not hot ...you would have to wash over 200* F to remove wax ... warm or cold makes no difference ...
Professional Polishing and Detailing Products
www.poorboysworld.com website
www.poorboysworld.net  detailing forum
www.Ultrafinish.com/store  microfiber only store
life is short ...do it while you can!
« Reply #19 on: November 30, 2009, 04:51:11 PM »
Now THERE'S a man that knows what he's talking about! Thanks Poorboy for chiming in.  :thumbs:
« Last Edit: June 09, 2010, 03:28:26 PM by Sly Bob »
