Author Topic: Anyone using CTEK battery charger ??  (Read 2327 times)
Offline ThunderSky
« on: December 07, 2009, 09:49:48 PM »
Hi all
Is anybody using the CTEK 3300 battery charger ?
I've heard good things about them and picked one up a few weeks ago.
Now that the snow has arrived I guess the dreaded "storage season" is upon us, so  I need to get it installed. Came with 2 sets of connectors, one with alligator clamps and the other with Ring Terminals for a permenent connection with sealed disconnect plug to the main unit.
So, anyone using it, where did you make your connections ??
Would there be any difference between direct at the battery or at the big terminals on the fuse block ??
ThunderSky
Graphite RedLine,
Red / Black Leather,
Manual Tranny, Windrestrictor,
Monsoon with XM , Spoiler,
8000K HIDs on Low Beams and Fogs
Drilled/Slotted Rotors, Painted calipers,
Magnaflow 3" Quad Tip Exhaust, CAI
Re: Anyone using CTEK battery charger ??
« Reply #1 on: December 08, 2009, 12:02:59 PM »
I would connect it at the battery
« Reply #2 on: December 08, 2009, 05:29:10 PM »
Hi all
I agree with Critterman.
FYI, the two terminals on the fuse block are both positive (+).  If you connect there, you will blow the fan fuse.
« Reply #3 on: December 08, 2009, 07:55:29 PM »
In my experience, there is no need for a charger.  I put mine in storage for an entire year and all I did was disconnect the ground wire from the battery.  After a FULL year, I reconnected it and the car started up on the first try.
This was the stock battery and it was 2 years old when I put it into storage.
