Author Topic: 2010 Annual Southern Maryland Mod Meet April 29 - May 2 Discussion  (Read 239179 times)
Re: 2010 Annual Southern Maryland Mod Meet April 29 - May 2 Discussion
« Reply #250 on: February 02, 2010, 08:42:49 AM »
no of course thats not it, and dont forget the plastic baby inside
« Reply #251 on: February 02, 2010, 10:53:44 AM »
All the talk of cake aside, put me down for my world famous (in our household) Brownies.
« Reply #252 on: February 02, 2010, 10:58:22 AM »
Yum! :drool:
« Reply #253 on: February 02, 2010, 11:40:47 AM »
If I remember correctly, whomever gets the baby, brings the cake next time.
« Reply #254 on: February 02, 2010, 01:55:29 PM »
Attendee List updated - all spaces in my place and cabin are taken.   You can always bring a tent.  Three is a link to the attendees list in my signature so you can check it often.
If local attendees wants to offer up a room for someone coming in town, let me know on this thread.
JPM, DDM and Solo Performance (Spiky) are attending.  If you require products from vendors, you must contact them to make arrangements for the meet.
If you are attending, let me know on the discussion thread so this thread will remain small.
Thanks.
Joe
« Reply #255 on: February 02, 2010, 02:28:50 PM »
that is correct critter
Offline DickW
« Reply #256 on: February 02, 2010, 02:50:51 PM »
Rogue, don't forget to fillup with gas just before you get to DBG. Makes it easier to set gas gauge.
Offline G8TR
« Reply #257 on: February 02, 2010, 03:23:46 PM »
Are they "special" Brownies? (You know us hippies )
« Reply #258 on: February 02, 2010, 03:56:28 PM »
^ There you go being shameless! :D :poke:
« Reply #259 on: February 02, 2010, 05:02:14 PM »
I sure hope not, as most of us work in enviroments that do not take kindly to 'special brownies'
« Reply #260 on: February 02, 2010, 05:05:38 PM »
Make two batches :)
Offline nolanb
« Reply #261 on: February 02, 2010, 06:14:54 PM »
Brownies are always good..
I just noticed that I didn't make it on the attending list so please add me for the 30th, 1st and 2nd.  I will be there to help out and maybe work on a few small upgrades I have been putting off...
Thanks
« Reply #262 on: February 02, 2010, 08:05:18 PM »
Added ya...
« Reply #263 on: February 02, 2010, 08:10:31 PM »
Ackshully, don't need to do that.  I have the "reset needles" trick down to a fine art...  I've been meaning to write this down, so this is a good a time as any.
For those of you changing faces but not at the meet, do as follows:
1. Start with the front ("glass") screen still off, wiring connector plugged into the back off the cluster, ignition off.
2. VERY lightly place at least one needle(s) on shaft(s) at roughly the 0 position. DO NOT PRESS DOWN (you will need to adjust placement later).  This will allow you to see what's happening in the next steps.
3. Turn on ignition and then off again, wait 30 secs, needles will settle to 'negative' position (below 0's).
4. Turn on ignition and fake start the car by turning key to the start postion with foot off the clutch (if you have an autobox, I guess you can start the car and turn off again).  Needles will do the test sweep and return to zero.
5. Turn off ignition. During the 15secs or so while all needles are at zero positions, gently remove and replace needles to point exactly at zeros and push the needles down on shafts - but no more than halfway.  NOTE: be careful, it's easy to knock/turn the shafts round while doing this.  If you run out of time just do one or two of the needles at a time.
6. Repeat steps above to verify that needles are set correctly.  If not remove/repeat. If they are correct, then push down all the way.
7. Clip front screen back on and put everything back together.
(Doesn't matter how much gas you have, gas gauge will read 0 at step 5.)
Offline sunnygator
« Reply #264 on: February 02, 2010, 08:37:21 PM »
I'll be there FRI, SAT & SUN (30APR-2MAY), staying at the HG Inn on the 30th and the 1st.
I'll drive down FRI morning, should be there before lunch or so.....
I'll bring some a dessert for the Pot Luck SAT, and will also make a run (or runs) to the grocery for whatever seems to be lacking, from plates to cups to sodas to water to beer to GJ to ?????
sunnygator
« Reply #265 on: February 02, 2010, 09:19:25 PM »
im staying at the hd to
« Reply #266 on: February 02, 2010, 10:24:10 PM »
HG? Is the Hilton Garden Inn?
« Reply #267 on: February 02, 2010, 10:36:47 PM »
lol im slow
Offline sunnygator
« Reply #268 on: February 02, 2010, 10:54:07 PM »
  Yes, I'm staying at the Hilton Garden Inn.....sorry for any confusion....
Offline DickW
« Reply #269 on: February 03, 2010, 09:23:23 AM »
I made my reservation at the Back Creek Inn(B&B) in Solomons.
« Reply #270 on: February 03, 2010, 10:10:17 AM »
I may be sleeping on the pier :)
Offline Whip
  • Global Moderator
  • Air Force Retired
« Reply #271 on: February 03, 2010, 12:09:37 PM »
Barb and I are staying at the Back Creek Inn also, DickW.  We will be in Chamomile and will be arriving Friday.  See you there.
GMPP Stage II Tune
Deepblue turn signal mod
Burl wood dash
« Reply #272 on: February 03, 2010, 12:09:59 PM »
Hey, that's my spot!!! LOL!!!  :gaah:
« Reply #273 on: February 03, 2010, 02:44:02 PM »
At least I won't get cold, nor bitten by the bugs as they like sweet things.  :rofl:
« Reply #274 on: February 03, 2010, 03:23:11 PM »
That's not what Joe and Chuck said....
