how tough is installing this stuff? apart from the mess of fluids
Kenny -------------- it takes NINE HOURS flat rate. And THAT assumes a lift and the tools. Fluids? Refill the master cylinder if needed !
Specifically - once in the air (lift of stands) remove the exhaust, diff, torque arm, drive shaft, turbo, and after detaching the linkage remove the gear box. Then the clutch and flywheel. Assemble in reverse and do NOT get any dirt, grease, or fingerprints on the clutch, pressure plate, or flywheel. Piece of cake, huh? As soon as I smoke my stock stuff I will be laying under Streak for a while.
