Author Topic: Bright pedal removal  (Read 5593 times)
Offline LiquidPT
  • TechHead
    • LiquidPT's website
« on: December 27, 2009, 01:12:30 AM »
I just got a set of aftermarket racing pedals for Xmas, and need some help. My car came with the "bright pedal" (i.e. metal) option. Here's what I've figured out.
1) Dead pedal: I have to remove the whole trim piece and swap it to the stock (non-bright) one (got one on the way). Then I can screw my new dead pedal in.
2) Brake and clutch pedals: The back part of these covers seem to be rubber, so I think i can just pry them off. Then my new pedal covers bolt to the metal pedal underneath. Can anyone confirm this is how these overs come off?
3) Acelerator: There look to be a couple studs on the back of the accelerator pedal. I can't see the side close to the tunnel though. Do I take the whole pedal off here? How do I take this apart? Then swap it with a stock plastic one, and screw the new pedal to that...
Anybody done a pedal swap? Anybody got a spare stock plastic accelerator pedal and/or a part number?
Thanks
Matt
LiquidPT aka Matt
driving Black Sun
Re: Bright pedal removal
« Reply #1 on: December 27, 2009, 02:11:45 PM »
Matt  I haven't taken any off , But if you have a little inspection mirror and a small led lite you can look behind them to see if there are any Screws holding them .
 Hold mirror under or behind them and shine the lite into the mirror .hope this helps
Bobby
« Reply #2 on: December 27, 2009, 02:54:30 PM »
You are correct on the dead pedal and the brake and clutch pedals.  gas pedal you have to pull the sending unit which is attached to the firewall by two or three bolts.  There are two press pins holding the pedal to the arm.  You can remove them but it is difficult to remove and even harder to put back in.  A replacement pedal comes with the sending unit as well so it is not cheap.
Offline ccanepa50
« Reply #3 on: December 27, 2009, 03:02:37 PM »
Matt, please keep us informed how it goes, this is the first car in a while that i havent changed to racing type pedal covers (see summitracing.com Mr gasket 4733G $36.)  and i sure do miss them, the spacing is just too wide with a proper (ie:narrow & soft) driving type shoe (see: Simpson Impression shoe) to use all 3 pedals at once........
Q-if the stock metal pedals are not just removable 'bling covers' can't you just bolt to/thru them?
not sure but i might not bother with the dead pedal, as long as one is there it doesnt need to match for me......
chuck
Offline LiquidPT
  • TechHead
« Reply #4 on: December 27, 2009, 05:27:55 PM »
chuck
The thing is they have rubber inlays, so it's not a nice flat surface... And I have a feeling the accelerator is thin metal over plastic. I'd rather just deal with the plastic if it's possible.
LiquidPT aka Matt
driving Black Sun
Offline LiquidPT
  • TechHead
« Reply #5 on: December 28, 2009, 08:43:00 PM »
So far, not so good. I broke a drill bit off in the brake pedal. Looks to me like the only way I'm gonna get it out is to pull the brake pedal assembly. Of course, this requires also removing the clutch and accelerator pedals...
Anybody know if you actually have to do the position sensor re-program for the clutch position sensor if all I'm doing is pulling it out and putting the same one back in? Doesn't seem like I would, but then I've heard of stranger things.
Thanks
Matt
LiquidPT aka Matt
driving Black Sun
« Reply #6 on: December 28, 2009, 09:56:42 PM »
Well I bought Joe's Magna Flo the 5 lb hammer must have worked Great ,Cause Dave did my Pro-Beam and didn't say anything  of a problem ( Thanks Joe ) for the mod fitting.
Offline LiquidPT
  • TechHead
« Reply #7 on: December 28, 2009, 11:33:16 PM »
 :idk:
Was this posted in the wrong spot, cuz I'm not sure what it has to do with pedals...
LiquidPT aka Matt
driving Black Sun
Offline PubliusE
« Reply #8 on: December 29, 2009, 12:31:45 AM »
Thanks
Matt
I added the GMPP pedal cover to my stock pedals.
The dead pedal is a plastic cover and is removed by the two screws.  The clutch and brake pedal are just covers you can pull off the pedals. Reach behind and pull the rubber off the metal pedal.  The gas pedal is a one piece unit.  You need to disconnect the electrical connector and remove the entire pedal.  I probably have the original instructions in the attic and can search for them if you need me to. To add an aftermarket cover to the gas pedal will require some interesting modification.
Offline LiquidPT
  • TechHead
« Reply #9 on: December 29, 2009, 12:43:17 AM »
Got the brake and clutch off, and figured out the dead. Had a feeling I was gonna have to replace the whole accelerator unit. I have the service manual here, but thanks.
« Last Edit: December 29, 2009, 05:27:24 PM by LiquidPT »
LiquidPT aka Matt
driving Black Sun
Offline LiquidPT
  • TechHead
« Reply #10 on: December 29, 2009, 05:27:39 PM »
OK, I feel like such a noob. I'm trying to remove the accelerator pedal assembly, and this is the electrical connector:
It looks kinda like the "pull the tab out and squeeze" type (like our headlights), but it doesn't look like it'll pull out cuz it's got an extra tab... to complicate matters, the tether implies (to me) that it'll pull all the way out.
I don't want to break this thing. Anybody know what the trick here is?
Thanks
LiquidPT aka Matt
driving Black Sun
« Reply #11 on: December 29, 2009, 08:16:47 PM »
It has been a while since I didn mine, but I believe you need to pull the pink tab off of the black lock bump, then work the connector off.  I think you have to wiggle it back and forth
Offline PubliusE
« Reply #12 on: December 29, 2009, 08:50:44 PM »
Thanks
Ok, I just took mine off twice.  The hardest part is lying on your back under the dash.  Stick a very small screw driver between the pink part and the black part while gently pulling on the pink cord.   Here is a picture of the connector removed. This should help you see what you need to do.  You want to push the tab back so it slips behind the black connector.
« Last Edit: December 29, 2009, 09:06:11 PM by PubliusE »
Offline LiquidPT
  • TechHead
« Reply #13 on: December 29, 2009, 10:40:37 PM »
Ok, I just took mine off twice.  The hardest part is lying on your back under the dash.  Stick a very small screw driver between the pink part and the black part while gently pulling on the pink cord...
Yay! That was exactly it. I just needed to know exactly where to put that screwdriver, and pop!
Thanks. Tomorrow: remove the brake and clutch pedals
LiquidPT aka Matt
driving Black Sun
Offline LiquidPT
  • TechHead
« Reply #14 on: January 02, 2010, 12:58:02 AM »
OK, got all the pedals back in. only one hangup. I can't get the connection to the clutch cylinder back onto the pin on the pedal assembly.
(Note: this pic is taken while lying on my back under the dash. The driver's side is on the right)
I've tried several things including a c-clamp... that HELPED, but only got it a bit further one before bending metal on the other side of what I was clamping to... There's not really any room to get my hand in there, let alone a "persuader" of some sort. How the heck to I get this on in order to get the clip over the end?
Thanks
Matt
LiquidPT aka Matt
driving Black Sun
