Author Topic: Broken Hose - looking for info  (Read 16344 times)
Offline DCLocal
« on: January 05, 2010, 11:34:02 PM »
Today when checking under my hood I discovered a hose sticking up bobbing in the air.  It is a silver braided hose coming off the right side of the engine (out from under the plastic cover over the plugs) that connects to a hard plastic tube that is part of the plastic intake coming out of the air box.  It seems the plastic connection off the intake snapped off causing the braided hose to spring up.
Does anyone know off hand what this is?  It looks to be a vent hose but the metal braided hose makes me think it is under pressure.  I want to know if I can glue the plastic fitting back on the intake or if I need to replace it all together.  It looks like I'd need to replace the entire plastic intake assembly coming out of the air box.  I'll post a picture tomorrow if my description doesn't make sense.
Topless in the District
Re: Broken Hose - looking for info
« Reply #1 on: January 06, 2010, 12:37:30 AM »
Super Glue will actually hold if the break is clean at least if did for mine until I got it replaced.  The intake tube is around $100 IIRC since mine was replaced by the selling dealership which wasn't a GM dealer but a Ford dealer and they broke it during an inspection.
Have you had anyone check the air filter lately?
If the answer is yes that's when it probably broke.  If you torque the filter cover too much it will snap that little tube like a twig or at least weaken it so that you have problems later on.
« Reply #2 on: January 06, 2010, 09:57:23 AM »
DC - check with the goat, if I remember correctly he went to a local hardware store and replaced that broken plastic fitting with a brass one for a few bucks.
« Reply #3 on: January 06, 2010, 12:42:51 PM »
Critter is correct, I got a barbed brass fitting of the correct size from Lowe's, drilled the cover out a bit and screwed it in, been fine ever since. This is a very common problem, the glue might work but it will happen again. This is not the exact one I got but close, it was easy.
« Reply #4 on: January 06, 2010, 01:24:49 PM »
Hang on - The Comedian is Goat?  But Dr. Disco before that!  You are playing with my brain and giggling happily!!!
« Reply #5 on: January 06, 2010, 01:45:38 PM »
Who knows who I will be next week, I changed to The Comedian after watching "The Watchman" i just like the character, if you have seen the movie and know me at all, you will see why.
Ben L
« Reply #6 on: January 06, 2010, 03:45:46 PM »
The blood-spattered Smiley pin was a dead giveaway . . . .
« Reply #7 on: January 06, 2010, 04:54:16 PM »
Guess I will have to watch the movie - haven't seen it.  Course, by then, you'll be someone else!
« Reply #8 on: January 06, 2010, 04:58:36 PM »
Thanks Ben, I wondered if anyone got that! Not to mention similar character flaws, and the location should be a clue as well, that is exactly where he is when last we see him...alive anyway.
I like this guy!
« Last Edit: January 06, 2010, 05:04:05 PM by The Comedian »
Ben L
« Reply #9 on: January 06, 2010, 05:11:08 PM »
You should see the director's cut version if you haven't already.  Darker than Hell, but great.
« Reply #10 on: January 06, 2010, 05:17:21 PM »
That would be the one I saw, all 3 hours and something of it. Yes, very dark! The ending was ahh, not what I expected, but up until then it was awesome! The scenes with Dr. Manhattan walking around unencumbered were a bit unexpected.
Ben L
« Reply #11 on: January 06, 2010, 05:33:06 PM »
So is your "my ride" designation an oblique reference to that aspect of the film?
« Reply #12 on: January 06, 2010, 05:46:38 PM »
 Mostly it was just an obscure reference to my dream car, I would trade the Solstice for the wiener mobile in a minute!
« Reply #13 on: January 06, 2010, 08:55:55 PM »
Yep - they're both yellow!  So is the smiley face!  Hmmmm........
« Reply #14 on: January 06, 2010, 09:04:00 PM »
If you watch the movie, you have better put aside half a day.  Man is it long.
Offline DCLocal
« Reply #15 on: January 06, 2010, 10:14:44 PM »
Thank you for the info; I'll probably start glue as it is a clean break and I don't have tools to drill etc.  Now I'll have to check out The Watchman.
« Reply #16 on: January 07, 2010, 11:19:11 AM »
I recall seeing a post about this where the author suggested using a (spent) .22 cal shell with the (flat) end cut off.  He inserted it inside the pipe and body across the break, as reinforcement for the glue.
If you dont have a .22, you could try a craft/model shop.  They usually have a selection of small brass pipe/tubing in diff diameters - I'm sure one would fit.
EDIT: Found the link to the post: http://www.solsticeforum.com/forum/f59/justa-fyi-60248/
« Last Edit: January 07, 2010, 11:50:21 AM by TomatoSoup »
Offline DCLocal
« Reply #17 on: January 08, 2010, 12:02:27 AM »
Thank you- that is a creative solution.  I didn't realize this was a common issue but not surprising as it doesn't seem very well reinforced.  What is this anyway, PCV vent?
« Reply #18 on: January 08, 2010, 10:57:50 AM »
I don't know about using a spent bullet, living in DC you could get arrested for not having a bullet carry permit!
« Reply #19 on: January 08, 2010, 04:07:26 PM »
That is the framastan valve it funnels the potassium emissions from the thingamajig down to the dohickey.
Offline chuckdoc
« Reply #20 on: January 08, 2010, 07:43:32 PM »
No way, Jim.  It is a double byfold flammis that forces xanium gas into the framis.
First time I found you to be wrong.
My KappaPerformance Mod Page
« Reply #21 on: January 09, 2010, 08:36:54 PM »
Chuck your thinking of the double by-pole flam-mis that deals with xyanium gas and the phramis.  Its a simple mistake but one that most first year hydrothermal adiabatic molecular dynamic engineer could explain.
Offline chuckdoc
« Reply #22 on: January 10, 2010, 09:26:56 AM »
I stand corrected.  I need to stick to medicine.
Offline xrbvx
« Reply #23 on: December 21, 2012, 11:39:50 AM »
I'm surprised there isn't a write up on how to fix this. I have the same issue and I'm not quite sure how to go about fixing it. I'd rather not glue it and i really don't want to replace it just yet. Lil goats method seems like a great idea I just wish there was more info. thanks guys!
« Reply #24 on: December 21, 2012, 08:58:45 PM »
I guess both methods are so simple that no one has put alot of effort into documenting it.
The other thing is, some aftermarket Intakes have the hard nipple built in
Here is my easiest Writeup that will help you out and prevent this from ever happening again
Click the link below
http://www.ddmworks.com/-LNF-Intake-tube_p_78.html
Then click
Add to Cart
Pay DDM
Wait patiently for the improved part to arrive
Install and be confident you will never deal with this issue again.
FYI - Due to their 12 days of Christmas Sale, this part is currently 15% off
http://www.kappaperformance.com/forum/index.php/topic,9414.0.html
Merry X-Mas!!!!
