Here is my list of repairs in case anyone has any questions:
Service/Dealer Repair Log:
* Wiring Connection for Fog Light- 4,265 miles- 6/8/07
* Control Assembly Floor Shifter Replacement- 4,265 miles- 6/8/07
* Folding Top Cover Replacement Pads- 6,714 miles- 8/8/07
* Shock Left Front Replaced- 8,386 miles- 9/25/07
* Hood Refinish/Clear Coat- 10,569 miles- 11/12/07
* Transmission Clunk- Supposedly "Within GM Specifications"
* Repair Rear Differential Vent- 10,569 miles- 11/12/07
* Repair Front Stabilizer Links as per TSB 07 03 08 003
* Repair Rear Differential Vent (again)
* Repair Rear Differential Vent (for a third time)- they placed a filter in the vent as per TECH SERVICE- the filter is part # 5651682 and the clamp is part # 22518665
* Convertible Top B-Pillar Tabs Installed for Roof Tearing
* Driver's Side Door Handle Replacement (dealer broke it off)- replaced with part number 15773795 (handle)
* Repair Differential Vent Tube (4th time)
* Vent Tube Deemed Unrepairable- they replaced the entire differential using part numbers 2585822 (carrier), 89021677 (gear lubrication), and 1052358 (additive)
* Called GM Customer Service to file complaint- Regional Manager declined any compensation for being in a rental over 1 month for warranty
* Turbo gasket leak because of loosened OEM bolts- used new SOLO gasket to fix and high-temp Lok-Tite on OEM bolts
* Convertible Top bolt backed out and passenger side became flimsy and did not align- piece replaced and convertible top repaired
* Rear Decklid rubber stopper fell off- replaced deck lid rubber stopper
* Hood Misaligned- paint scratched off of inner hood, wheel well plastic scrathed, insulator ripped- dealer will not fix- purchased insulating foam
* Driver's seat latch linkage broken- seat does not lock into place- dealer ordered the wrong piece- repair finally completed with new seat assembly
* Damaged fender to to dealer's improper lift- they refuse to accept responsibility so I put on Norm's Fenders
Changed Dealerships: From Morrissey Pontiac (Rockville Centre) to Van Buuren Pontiac (Garden City)- 7/14/08
* Convertible Top Alignment- dealer installed new catch piece
* A/C Issue (not cooling consistently)- repaired with a new sensor
* Hood/Front Bumper Alignment (aligned correctly by Newbridge Auto Body)
* Hard Downshifting from 2nd to 1st Gear- repaired with 2nd new differential carrier
* Wheel stud stripped- replaced by dealer with new hub assembly
* Noise from right rear wheel- wheel hub assembly replaced
* Thermostat Replaced (coolant temperature jumping all over and hose fluid temperatures were varying from the norm)
Van Buuren Pontiac has been a GREAT dealership!
