I've got the grinding during low speed turns problem. I've had my Solstice into my favorite dealership in the Detroit area a few times over the last year to address this problem. Each time they've done a differential fluid change, which makes the noise go away for a while but never attacks the root problem. They suggest the solution is to do a clutch pack replacement.
It's expensive, but the charge for the differential fluid replacement isn't cheap either. So I'm ready to do the clutch pack replacement.
Since the last time I've had the car into my Detroit dealership, I've moved into the DC area. I commute from Frederick, MD to Rockville, MD everyday. Can someone recommend a competent dealership that can do this work?
I'd hate to be the first Solstice to have that work done at a dealership. So if you had the same work done at a dealership around here, please let me know your experience, good or bad.
