Author Topic: Buttress not releasing?  (Read 6265 times)
« on: March 18, 2010, 01:35:59 PM »
I have had a problem (in warranty and now out) of the buttresses not readily releasing. Well, with such crappy weather I decided to see what the real issue was on my car. (Sorry, no pics.)
At first I tried some spray lube into the release area and grease on the pins. No luck. So, once I DID get the trunk open, I pulled the black sound insulation panel off of the trunk lid. There is a "Y" shaped cable assembly that attaches the servo to the two release mechanisms at the buttress pins. At the junction there is a black plastic assembly that has the main cable coming in from the servo which is attached to a coupler. The two cables that go out to the releases are coupled there as well. There are two (male and female) enclosures that snap together to contain the three cable ends and the couple. My enclosure had broken, and this allowed everything to flop around, and thus the proper tension could not be maintained so the releases were not sufficiently retracted. I used couple of large cotter keys (one on each side) for support of the broken housing and aggressively taped up this reinforced assembly. Bingo, winner winner.
Total time = 1 hour. Result = smooooooooooth truck release.
Re: Buttress not releasing?
« Reply #1 on: March 18, 2010, 01:47:34 PM »
Were you out of bailing wire?  You did use duct tape right?
« Reply #2 on: March 18, 2010, 04:24:11 PM »
Thanks Bob for the heads up. I'm thinkin' this is something I should look at on the car before I have problems.
« Reply #3 on: March 18, 2010, 04:28:09 PM »
Eh HEM !!!!!!!!!!!
Bailing wire and duct tape are for Pontiacs.  :poke:  Streak is a Redline. More sophisticated car owners prefer proper color coordination - hence BLACK tape on black parts such as the plastic pieces and cable assemblies mention.   :thumbs:
 :kwh: :kwh: :kwh:
« Reply #4 on: March 18, 2010, 04:44:25 PM »
 :rofl:
« Reply #5 on: March 18, 2010, 07:38:44 PM »
« Reply #6 on: March 18, 2010, 08:35:10 PM »
I have my moments.
Offline GaryH
« Reply #7 on: March 18, 2010, 09:19:55 PM »
Duct tape now comes in colors.  So black tape for black parts is no problem.
Eh HEM !!!!!!!!!!!
 :kwh: :kwh: :kwh:
07 Sky
VIN  1745
Magnaflow Quad Tip exhaust
Tail of the Dragon 2008
Denver 2009
Ohio 2010
08 Sky DDM SC stage ll
Solo Mach exhaust
« Reply #8 on: March 19, 2010, 01:13:35 AM »
It should go with out saying but just for the record I use Speed Tape on the Pontiac. :poke:
I also use safety wire in place of bailing wire, its one of those things I picked up from working in the aviation industry, it's stainless steel so I don't have to worry about it rusting.
« Reply #9 on: March 19, 2010, 09:06:39 AM »
Redlines don't rust.  ;)  Break, maybe, but that's the Kappa gene pool at work. :lol: :rofl:  Your turn.   :poke:
« Reply #10 on: March 19, 2010, 09:38:06 AM »
Everyone knows plastic kiddie cars don't rust
back to you Bob
« Reply #11 on: March 19, 2010, 12:59:22 PM »
back to you Bob
The ONLY plastic/metal differences are the front "fenders". Next, please.
