Author Topic: Has anyone swapped the 3.91 into a GXP/Redline?  (Read 5426 times)
Offline epbrown
« on: April 16, 2010, 08:10:17 PM »
I did a search and didn't find anything. I'm curious if anyone has swapped a 3.91 final drive into a 2.0L. I swapped the 3.62 in my Z4 M Coupe for a 3.91 and I like the bump in gitalong, and wonder what it would be like in the torquier (now that it's been chipped) GXP if I replaced the 3.73. Can the 3.91 even handle the additional power?
Re: Has anyone swapped the 3.91 into a GXP/Redline?
« Reply #1 on: April 16, 2010, 08:12:01 PM »
I'm running 245 rwhp in my 06
« Reply #2 on: April 16, 2010, 09:34:10 PM »
I don't know if anyone has changed the gears in the rear diff.   I like the current one for the gas mileage.
« Reply #3 on: April 16, 2010, 09:37:38 PM »
Once the mods start you'll need taller gears, not shorter.
Norm
« Reply #4 on: April 16, 2010, 11:01:25 PM »
Norm is correct. With the silly gear set we have, 1st and 2nd are already way too short. I'd love a 3.5x rear.
Offline epbrown
« Reply #5 on: April 17, 2010, 02:43:26 AM »
The grass is always greener, I guess:
Solstice GXP Gears:
1st - 3.75
2nd - 2.26
3rd - 1.37
4th - 1.00
5th -  .73
BMW Z4 M Coupe:
1st - 4.35
2nd - 2.50
3rd - 1.66
4th - 1.23
5th - 1.00
6th -  .85
The M can afford the taller gears with the 8000rpm redline, but I figure I wouldn't rev the GXP as much with all that torque anyway. This would be the only performance mod I'd do to the car, btw. Only other thing I want is nicer wheels with stickier tires.
« Reply #6 on: April 17, 2010, 10:39:19 AM »
Revving higher with the stock turbo is pretty much useless, it's better to short shift which is why I think changing the gearing or the rear could be helpful.
Does anyone have the specs handy on the rear ends for other cars that will pop into our cars easily? If any are a good match would swapping rears be easier/cheaper than swapping gears in our rear?
« Reply #7 on: April 17, 2010, 01:30:19 PM »
 :agree:  ....but not enough to make the change.
« Reply #8 on: April 17, 2010, 06:59:13 PM »
I do not think there is anything more than the 3:91 as a complete swap.
Offline SolNut
« Reply #9 on: April 17, 2010, 08:28:33 PM »
Cadillac CTS has 3.23, 3.42 and 4.15 Ratios available in different power combos.  :yay:
Should swap right in.  :thumbs:
Steve
 :drive:
Offline G8TR
« Reply #10 on: April 17, 2010, 09:25:03 PM »
Okay, so who's first to do this mod? :idk:
« Reply #11 on: April 17, 2010, 09:44:08 PM »
Drifting solstices have diferrent rears but I don't recall the ratio
Offline Graywolf
« Reply #12 on: April 17, 2010, 09:56:28 PM »
Since I race my car in high speed driving events, Road racing tracks, I always thought 3rd gear should be 1.5, 4th gear1.25 and 5th 1.0.  Switching to the cts 4.15 may give me better . Will the CTS 4.15 gear fit in our diff?
Offline shabby
« Reply #13 on: April 17, 2010, 10:46:41 PM »
Shorter gears make sense on a miata/s2k, but with the torque that our engines put out you'd want taller gears, don't understand why you'd want less traction.
