Author Topic: Help me to reduce my drag racing times  (Read 99259 times)
Re: Help me to reduce my drag racing times
« Reply #50 on: June 03, 2010, 01:44:35 AM »
I'm sorry, but what do those vids show?  Looks like all you are doing it reving the engine?  I am un familiar with the WOTBOX, not trying to be a pill.
« Reply #51 on: June 03, 2010, 01:59:17 AM »
Launch control, it limits the revs to a designated value. Is not 100% clear from the movie but I'm used with it.
« Reply #52 on: June 03, 2010, 02:05:39 AM »
Got it!  Now I understand the videos.
Thanks Kelu!
Offline pantherqs
« Reply #53 on: June 03, 2010, 03:23:14 AM »
Yhup, it's actually different than the launch control on the cobalts because it cuts ignition and spools the turbo which lets you launch the car off the line in boost already.  Those are just to show how ridiculous it sounds at 4-5k, sweet spot on my car seems to be around 2300-ish launch-wise.
And Norm, yes, I'm fat as hell and just fall into the damn car.  God damn thing is so low.
« Reply #54 on: June 03, 2010, 08:13:02 AM »
I have WOB Box installed.  :yay: I installed hidden and brought a LED button at the base of the pillar which is an extension of the WOT Box functions (button and light on the same small LED).
The main issues were nailing the clutch wire (was supposed to be BROWN/WHITE and to me was BLUE/WHITE), the second big issue was setting up because lack of usability of their software it was pretty much a pain because the guy was afraid to push the gas pedal to the max and we had the false impression that we didn't set it up correctly.
I have finally found a USB - Serial cable (20$), guess what, doesn't work, issues with drivers and other shits.  :banghead:
I have tested 2nd step from 2000rpm, it's so nice and launches great. I was thinking whatta hell is not building boost, but than I remember there is no boost at 2000rpm from our turbo  :lol: Set it up for 3000rpm and test it and it builds boost 0.15 bar)  :thumbs:
After that I was wondering myself how to set up the rpm for WOT Shift, than I realized there is no fixed rpm to shift as GMPP NLS, you can basically WOT Shift at any rpm as long you are in the time period (350 ms) setting for this and of course you keep the gas pedal to the floor. pantherqs can you confirm this is true?
I will document this product and make a complete review.
NormSky So I'm not the one which observed that, I wonder how my car makes when I get into it, I'm about 210lbs. What is your weight pantherqs
pantherqs What do you mean different than the launch control on the cobalt?
« Last Edit: June 03, 2010, 08:19:27 AM by Kelu »
Offline pantherqs
« Reply #55 on: June 03, 2010, 01:17:31 PM »
Confirmed, no fixed RPM.  NLSing at 5k produces 8 foot fireballs, just an fyi. ^_^
The NLS is :censor: ing great compared to the GMPP one.
« Reply #56 on: June 03, 2010, 02:54:11 PM »
yeap, that is correct, actually WOT Box comes with an adapter so any USB cable would be good with that:
Tomorrow I will try to install it.
If you want me to pick one of those up and mail it to you, PM me...
EDIT: Never mind, I guess I should read the entire thread... ;)
« Reply #57 on: June 03, 2010, 03:34:12 PM »
LiquidPT: thank for the offer buddy, i give up trying  connecting WOT Box to computer, made the setting from the normal button and hide it under the steering wheel cover.
I will need to connect it when there will be a firmware upgrade for WOT Box, until than stays as it is.
« Reply #58 on: June 04, 2010, 06:57:36 PM »
WOT Box working!!!  :yay:  :yay:  :yay:
What I got from WOT Box:
FIXED - Electronic throttle control (ETC) delay and closing between shifts
FIXED - Loosing all boost between shifts and delay in rebuilding the boost after shift (just a small dip)
FIXED - No airflow between shifts  (just a small dip)
BONUS - 2nd step launch control - my launches will be more consistent and launching from a 5psi boost instead of no boost, all I need now are tires  :devil:
BONUS - because WOT Box Shift the rpm decreases a little bit while I shift so will be a far better match with the tranny, almost impossible to be locked out or risk to hit dangerously high rpms
BONUS over GMPP NLS - I can NLS at any rpm, not only between 6000-6300rpm.
 If I shift faster the dips in boost and airflow will be smaller.
Log with the 2nd step launch control:
Log with 2nd step launch control and two WOT Shifts:
Very happy about this product.
All I need to do now is to get used to it and to set it up for best performance.
Offline JimmyBaja
« Reply #59 on: June 05, 2010, 01:24:25 AM »
Congrats Kelu that's awsome!
Now you just need to see how it does at the strip.
« Reply #60 on: June 05, 2010, 04:44:42 AM »
Tomorrow new drag race  :devil: I hope this time their timekeeper will work
« Reply #61 on: June 06, 2010, 02:34:39 AM »
results?
« Reply #62 on: June 06, 2010, 09:46:57 AM »
I just texted him, I assume he's at the track right now.
« Reply #63 on: June 06, 2010, 01:07:36 PM »
Yeah, I was hoping his WOT box was the solution to his woes.  Seems like a great way to launch, but I don't think it is going to help his end of the track issues.  He will still be shifting in to 4th with 80 feet left.  Right?
« Reply #64 on: June 06, 2010, 01:41:55 PM »
Maybe 90-100 feet left.  nature of the beast i am afraid
« Reply #65 on: June 06, 2010, 01:57:52 PM »
Just a thought but has anyone ever looked into an add on overdrive unit for the Kappa?  Basically its a bolt on unit that you install between the trans and the drive shaft.  You can then change the gear ratio of the gear you are in simply by flipping a switch.
http://www.gearvendors.com/index.html
Something like this might be all you need to finish the last 100 feet in third.
« Reply #66 on: June 06, 2010, 03:06:54 PM »
Yes, did helped, launches are very consisted, my races for today weren't a solid prove for it, TONS of dust and concrete pebbles. Barely launched from 3000rpm. Lacking a timekeeper didn't helped at all to prove black and white, I did logged almost all my races and I scared the shit out of the 1500 people public with WOT Shift backfires. I will make a report about the race. I did lost all my races AGAIN on the last part of the strip  :mad: I'm thinking to another way, more powa will compensate that weak 1:1 4th gear. As long I don't get out of power band should be ok, am I thinking wrong?
Sol Asylum: GREAT IDEA SIR  :thumbs:, petty costs only almost $3000  :cryin:
Offline HAMMER DOWN
« Reply #67 on: June 06, 2010, 03:12:35 PM »
Sometime Kelu you have to pay to play :poke: I see a 3.91 rear end or more HP's in your future. Or maybe both. :drive:
Offline HAMMER DOWN
« Reply #68 on: June 06, 2010, 03:15:08 PM »
Someone once told me to go quick, you have to make HP or match you HP with the right gearing. Neither one is cheep.
Mike
« Reply #69 on: June 06, 2010, 04:14:59 PM »
Mike  :thumbs: correct, for the moment I think I will think to power for improving my ET.
« Reply #70 on: June 06, 2010, 04:21:28 PM »
how high would you have to increase your redline in order to be able to stay in 3rd? also what about the tires idea?
« Reply #71 on: June 06, 2010, 04:31:27 PM »
Kelu,
Now that you have the WOT box, couldn't you put a bigger wheel in your turbo?  You and Kenny have way more experience talking this stuff over, but I was of the understanding that the larger was going to take longer to spin, but had more power at the top end.  With the WOT box allowing you to rev better to launch, wouldn't that help?  Or am I way off?
« Reply #72 on: June 06, 2010, 06:04:05 PM »
And how much have you got in all your other mods?  If you could find a used setup that would work I bet it wouldn't cost the $3k.
« Reply #73 on: June 06, 2010, 06:33:56 PM »
GJ: bigger wheel gains are around 20-40 whp above my setup, I wouldn't spend $1500 (shipping back and forth will be a pain, or buying a spare turbo) for that, I would spend $3000 if there will be a turbo kit around 350whp-400whp with tq flat and no later than 4000rpm. Big wheel's tq is even shorter in rpm vs our stock turbo because we are limited by hot side housing.
Sol Asylum: do you think I could find a used converter like that and much cheaper which will bolt-on our tranny?
Offline HAMMER DOWN
