Author Topic: Diagnostic Scanner Tool Recommendation?  (Read 5021 times)
« on: May 27, 2010, 08:07:04 AM »
Diagnostic Scanner Tool Recommendation for our Kappa's?  Searched on ebay, seems to be quite a price differance between brands.  Any scanner tool recommendations for the home hobbyist person?
Also, went to Amazon, and found a book for "How to Use Automotive Scanner".  Listed 22 new, but business's were selling the book from $18-$118.  Even though Amazon shows the list price as $29.95 for the paperback book.  So why such a price difference in new book prices?
Some of the used one's are priced more than the one Amazon list price.  Is this one of those products that are constantly updated, rendering the old one obsolete?
Re: Diagnostic Scanner Tool Recommendation?
« Reply #1 on: May 27, 2010, 08:22:07 AM »
Scan tools and books are not the way to compare Amazon's pricing. Books are easy to deal with - you know which book you want and fine the lowest price. Finding a scanner based on price is not the right method. But, once you nail down which scanner you want, THEN prices can be compared.
WHAT scanner to buy depends on WHAT you want to do with it. If you just want to read codes and data streams, Google searches will provide endless choices in "generic" scan tools. If you want to dig deeper, you'll be in the lower four figures for an aftermarket scanner that will need updates, and that can get expensive, but aftermarket scanners ALWAYS lag the most current model year by 1.5-2 years. The ultimate scan tool for a GM car is the Vetronix Tech2, as that is the factory scan tool. CHA CHING !!!!!!!!!!!!!!! And updates are not cheap. If you want to tweak the stock ECM software, you will need a tuning suite for a laptop, and that is HP Tuners for the Kappa, and can be used as a basic scanner as well.
HTH.
« Reply #2 on: May 27, 2010, 08:42:52 AM »
Someone on ebay bought one yesterday.  It's listed for$2699.00   oooouch!
« Reply #3 on: May 27, 2010, 08:54:29 AM »
  Did it say how current it was or did it need updating?
« Reply #4 on: May 27, 2010, 09:25:40 AM »
Good question for Scanner.  Perhaps the Maryland club chips in for one?
« Reply #5 on: May 27, 2010, 10:51:52 AM »
Is the Tech2 what Lyndon uses to tune? or is it just for scanning?
« Reply #6 on: May 27, 2010, 11:47:36 AM »
DickW says Lyndon uses his own software to edit the tunes and uses HPTuners to write it.
Offline scanner
« Reply #7 on: May 27, 2010, 06:47:43 PM »
Tech 2 is a required dealer technician tool since 1995.  The tool does not do tuning at all. It is used to get DTCs and parameters from control modules. It will also exercise outputs where the CM allows it. With up to date software it works on all GM models from 1991 - 2009. It requires a 32MB memory card designed for Tech 2 to do that and a CAN diagnostic interface (CANdi).
It will work on all your GM vehicles in those years but not others.
Ebay sale #180509135457 sounds complete and describes why there may be many for sale.  This plus using the tool to its full capability is why technician work is expensive.  If you use one to work on one car problem you will not learn much. If you have ready access to one and use it one weekend every eight weeks or more you could get good with it. Any less use will be rusty.
So a club purchase would be best served if the club elected a steward and primary operator. That is, someone most likely to take care of it and learn to use it with skill.  The tool does not fix cars, technicians do with tools and information.  Tech2 provides CM information.
If you want to see what a skilled operator does with it see Jim Wilson's site, www.flatrater.com.  There are some free case studies, see this one: http://www.flatrater.com/Free/News2/P0446.html
or this one: http://www.flatrater.com/Free/News1/S10/S10Inspector.htm
If you're in Southern California he can fix your car too.
Scanner
« Reply #8 on: May 27, 2010, 08:32:35 PM »
There you go Bubblegum - go see Jim
« Reply #9 on: June 02, 2010, 07:42:48 AM »
I guess I was thinking of one that just gave you codes.  Anytime anyone post a check engine light (CEL) question on a forum, someone also replys go to Autozone (or a similar place) to find out what codes are being recorded.  My understanding of codes is they do not give you (or the techs) the specific reason why something happened, only that something did happen and a starting point to begin investigating.  For example:  A misfire code could be a bad spark plug, a bad wire, bad fuel injector, or even fuel related.
« Reply #10 on: June 03, 2010, 02:38:00 AM »
ChopTop,
The simplest and cheapest I have seen is a "code readerl" and is / was available at Costco for under 50 bucks.  It will read the codes and clear them if you chose.  As everyone will tell you, that is the tip of the iceberg.  All it will do is tell you why your check engine light came on or if you have a pending code.
I have one, and it helps only to give others some info and try to go from there.  It has been flawless in what it is made to do so far.
It is not the answer to world peace or even a bad spark plug, but it is easy to use.
Scanner-
Where is Jim?  Is he in the LA area? or San Diego?
Hmmmm.....
« Last Edit: June 03, 2010, 02:49:17 AM by Gentleman Jack aka Bubble Gum »
« Reply #11 on: June 03, 2010, 10:42:34 AM »
Since I have an iPhone, I ended up downloading the application
REV
and have it wirelessly paired with a PLX Device called a Kiwi Wifi
http://www.plxkiwi.com/kiwiwifi/hardware.html
A little bit more expensive than some other options, but it works great and does some good logging.
I also use it with DashCommand which does some nice Dashboards for easy reading.
Offline scanner
« Reply #12 on: June 03, 2010, 04:40:48 PM »
Jim's toolbox is on wheels.  Using his contact link at the the flatrater.com website is the best option I know to find Jim. Else, try IATN.net
Scanner
