Author Topic: Removing grille (GXP)  (Read 7791 times)
Offline BlkDragon
« on: June 01, 2010, 11:32:17 PM »
OK - I know that I will sound like the dumb one on this forum but I think this would be the easiest way for me to get this information.
I want to put a couple of LED strips behind my front grille before I go to a car show in August.  It seems that you can't get to the space behind the grille from either under the hood or under the car.  I can't figure out how to take the grille off!!   :gaah:  (OK - cue laughter!)
Mike
2007 Black GXP - Black Dragon
Re: Removing grille (GXP)
« Reply #1 on: June 01, 2010, 11:35:07 PM »
To pull the grill off, you need to pull sume clips from the back side. I think it might take removing the bumper (that's how I got the clips off, and it was tricky even then...)
Offline BlkDragon
« Reply #2 on: June 01, 2010, 11:40:54 PM »
Thanks - I guess I won't be putting any LEDs in there.
Mike
« Reply #3 on: June 02, 2010, 05:33:58 AM »
There's a thread on the forum I believe that tells ya' how to take it off. It only takes about 10 minutes and really isn't difficult at all.
There are 5 screws across the top, 3 in each wheel well and 5 or 6 christmas tree push pins along the bottom edge.
« Reply #4 on: June 02, 2010, 08:57:51 AM »
The grills can be pulled without taking the bumper off.  Randy of DDM did mine, and there may be a thread on the big board.  Joe probably knows how as well, but bottom line is you do not have to pull the bumper, you just need to know where those metal clips are and a screw driver.
Offline BlkDragon
« Reply #5 on: June 02, 2010, 11:55:38 AM »
Hmmm - I have a dremel saw.
Mike
« Reply #6 on: June 03, 2010, 02:52:30 AM »
Just use a sledge hammer.  It should work quickly and cleanly.
Offline BlkDragon
« Reply #7 on: June 03, 2010, 11:49:14 AM »
OK - the sledge hammer worked but I only had to do one side.  I could reach around to the other side.  Front end looks a bit odd though.
Mike
« Reply #8 on: June 03, 2010, 02:39:09 PM »
BlkDragon,
It's supposed to look odd.  It's a show car!  That will make the judges remember you when they go do their voting.  Very unique.  Awaiting the pictures... :)
« Reply #9 on: June 03, 2010, 02:45:06 PM »
Get a big rubber corrigatted tube and tell everyone it is your air intake for the engine.
Offline BlkDragon
« Reply #10 on: June 03, 2010, 06:23:13 PM »
« Last Edit: June 04, 2010, 01:57:22 AM by BlkDragon »
Mike
« Reply #11 on: June 03, 2010, 06:39:30 PM »
That's hilarious Mike!    :rofl: :rofl: :rofl:
« Reply #12 on: June 03, 2010, 07:54:55 PM »
I blew my coke Coca Cola through my nose all over my keyboard.  Love it.  But I would trim it a bit closer to the body.
« Last Edit: June 04, 2010, 09:18:15 AM by Critterman, Reason: Jackknife »
Offline Jackknife
« Reply #13 on: June 03, 2010, 09:45:57 PM »
I blew my coke through my nose all over my keyboard.  Love it.  But I would trim it a bit closer to the body.
Aren't you supposed to inhale that stuff?
Recessed Grills ... Debadged
DDM Pro-Beam and back brace
Solo Hi-Flo Cat
« Reply #14 on: June 04, 2010, 09:16:13 AM »
 :rofl:make me edit my post to protect my job why don't you  :rofl:
Okay Drgn quick and dirty removal
I talked to Randy last night as he took mine out 3 years ago.  You need a flashlight and a long screwdriver.  There are 4 metal clips, two in each grill.  One on the bottom inside edge and one on the top outside edge.  You can find them with the flashlight.
Insert your screwdriver into the grill and under the clip, push hard and break the clip, the metal will fall loose.  Once you have done both you will need to go around the grill and gently release the remaider of the plastic clips and pull it out.   You will destroy the clips with the metal retainer but you do not need them for the grills to stay in place.  Mine have been there without those clips for 3 years and over 30k miles.
Offline BlkDragon
« Reply #15 on: June 04, 2010, 11:37:56 AM »
Thanks Critterman - it sounds like something I am a little wary of doing myself.  My brother in Vancouver is a mechanic so I might ask him to give me a hand next time I go over.  Any more suggested mods for me?  Your last one is garnering a lot of attention and comments on the street!
Mike
« Reply #16 on: June 04, 2010, 01:31:48 PM »
As so it should.
« Reply #17 on: June 04, 2010, 09:28:23 PM »
Critter was that rubber tube what you used for your coke coca cola?
