KappaPerformance is the only forum withZERO ADS. We need support to continue this, consider premium.KP does not send emails or sell your info. Please email KappaPerformance@gmail.com for account help.
Here are the Service Manual pages..... I won't be lifting from the front slots
Here are the Service Manual pages..... I won't be lifting from the front slotshttp://i845.photobucket.com/albums/ab20/The_Marshal/Solstice/Technical/SolsticeLiftingandJackingPage1new.jpg?t=1276198469http://i845.photobucket.com/albums/ab20/The_Marshal/Solstice/Technical/SolsticeLiftingandJackingPage2new.jpg?t=1276198917
Those slots are not the frame rail where the BMW pucks go. The pucks go in the frame rail where the tape is in the Lith's pic above. They put tape there as it is probably reference they use when moving the car down the line. The tape might be there for a reason.
Tape....? Forget tape and previous pictures..... this seems a little too complicated than it has to be. Simply, the Service Manual shows where to lift, and whether by jack, lift, or levitation, the front slots are not to be used. Just want to make sure incorrect info is not passed along....
Use the slot with puck where the tape is on the body in the picture above. You can lift the whole car from there. Like you, Marshal, I would not put the front of the car on the recommended points. It very filmsy. Don't know why you put that up there anyway.
I think you misunderstood me.... Lift the front from the flat spots under the car, not the front frame slot... this according to GM. It is very clearly defined (previous versions of the Manual were unclear about front lift points).... I can send you more info on this, if you'd like.....http://i845.photobucket.com/albums/ab20/The_Marshal/Solstice/Technical/LiftPoints.jpg
I didn't WHAT??
A shade tree solution to a problem that doesn't really exist.
