Author Topic: Has anyone used this jacking puck?  (Read 26704 times)
Re: Has anyone used this jacking puck?
« Reply #25 on: June 09, 2010, 05:44:26 AM »
Thhe frame rail slots can support my 1,000 heavier CTS-V. I've lifted the whole corner of the car with just the BMW puck.  :)
« Reply #26 on: June 09, 2010, 05:47:57 AM »
And if you think the hydro formed rails are a peak link I've jacked up a 400 lbs heavier C5 Corvette.  :)
Offline Lithium Lotus
« Reply #27 on: June 10, 2010, 12:34:35 AM »
The pucks are used to prevent damage to the fenders when the car is being lifted, especially on a 4-point lift.
Plenty of stories of dealers damaging cars due to lifting on the other two forums. Here's a pic [not my car].
07 GXP: Natsumi "Summer Beauty"
Sold 08/2010
Offline The Marshal
« Last Edit: June 10, 2010, 03:42:44 PM by The Marshal »
« Reply #29 on: June 10, 2010, 04:08:08 PM »
Here are the Service Manual pages..... I won't be lifting from the front slots
I think the point is (at least in my case) to have them there for insurance when you go somewhere else.
« Reply #30 on: June 10, 2010, 07:28:56 PM »
Those slots are not the frame rail where the BMW pucks go.  The pucks go in the frame rail where the tape is in the Lith's pic above.  They put tape there as it is probably reference they use when moving the car down the line.  The tape might be there for a reason.  :)
http://i845.photobucket.com/albums/ab20/The_Marshal/Solstice/Technical/SolsticeLiftingandJackingPage1new.jpg?t=1276198469
http://i845.photobucket.com/albums/ab20/The_Marshal/Solstice/Technical/SolsticeLiftingandJackingPage2new.jpg?t=1276198917
Offline The Marshal
« Reply #31 on: June 10, 2010, 07:58:15 PM »
Tape....?  Forget tape and previous pictures..... this seems a little too complicated than it has to be.   Simply, the Service Manual shows where to lift, and whether by jack, lift, or levitation, the front slots are not to be used.  Just want to make sure incorrect info is not passed along....
« Reply #32 on: June 10, 2010, 09:36:24 PM »
Use the slot with puck where the tape is on the body in the picture above.  You can lift the whole car from there.
Like you, Marshal, I would not put the front of the car on the recommended points.  It very filmsy.  Don't know why you put that up there anyway.
Offline The Marshal
« Reply #33 on: June 11, 2010, 02:40:03 AM »
I think you misunderstood me....  Lift the front from the flat spots under the car, not the front frame slot... this according to GM.   It is very clearly defined (previous versions of the Manual were unclear about front lift points).... I can send you more info on this, if you'd like.....
http://i845.photobucket.com/albums/ab20/The_Marshal/Solstice/Technical/LiftPoints.jpg
« Last Edit: June 11, 2010, 03:12:27 AM by The Marshal »
Offline b0n2a1
« Reply #34 on: June 11, 2010, 08:42:13 PM »
The Marshal Thanks that is a great picture. Gives me a better idea of where I should be lifting. Thanks
« Reply #35 on: June 11, 2010, 09:35:44 PM »
I hope you don't mind, The Marshall, but I posted you pic over on the BB to illustrate a point I was making about one of the front crossmembers blocking removal of the oil pan while the engine was still in the car.   It's a great shot to illustrate the correct lifting points.  Well done.
« Reply #36 on: June 11, 2010, 10:00:35 PM »
That's a good picture for the guys that take their car in for service where all four sources are used.  Four post lifting pads are too big to fit on the frame rail.  But if everyone had BMW jacking pucks the garages would have no problem in knowing where to lift.
Most of us are lift the car in the garage and like you mentioned you don't want to use the front area in your picture without using the rear also.  The front is soft and flimsy that's why guys are using BMW jacking pucks in the frame slots.  The whole car can be lifted on one frame rail slot with the puck as I have lifted most of my 3800 lbs CTS on one corner while putting jack stands underneath it.
Besides Mallett Motorcars does not have a lift.  Everything is on jack stands.  :)
« Reply #37 on: June 13, 2010, 07:52:09 AM »
The pictures speak for themselves. With the BMW puck, everything is fine and there is no downside.
[attachment=1][attachment=2][attachment=3]
« Reply #38 on: June 13, 2010, 08:40:31 AM »
SOB, you didn't!?  :)
« Reply #39 on: June 13, 2010, 11:33:08 AM »
I didn't WHAT??  :huh:
« Reply #40 on: June 13, 2010, 12:49:45 PM »
Marshall is in disagreement with us that you should not be lifting from the frame rails.  :)
« Reply #41 on: June 13, 2010, 02:02:21 PM »
Except it works !!!!! And Hoosier says their 295 A6s "can't" be mounted 18x8 wheels ---- except they CAN.
« Reply #42 on: June 13, 2010, 02:52:39 PM »
This thread is resembling the post about "what happens in a car forum" with the cartoon video....
http://www.kappaperformance.com/forum/index.php?topic=4703.msg62405;topicseen#new
All "The Marshall" is saying is that the manual says not to.  All SOB/NormSky are saying is "Hey, it works Great!"  you guys aren't even arguing.  Your having two different discussions!
This is funny to read from far away  :)
« Reply #43 on: June 13, 2010, 03:24:06 PM »
Are you getting all jacked up about it ?!?!?!   :lol: ;)
A bit more seriously -- if a Kappa is lowered one can not get into the preferred (recommended) jack points. At this point the (low profile) jack will roll under MAYBE another 1-2".  In other words, I MUST use whatever jack point that I can get to. [attachment=1][attachment=2]
« Last Edit: June 13, 2010, 03:29:36 PM by snaponbob »
Offline tallcraig
« Reply #44 on: June 13, 2010, 10:15:08 PM »
How about driving up on four small pieces of 2x6 lumber? Works for me. Low profile 2 ton jacks on sale now at Harbour Freight $59 beans. Craig
« Reply #45 on: June 13, 2010, 10:28:36 PM »
A shade tree solution to a problem that doesn't really exist.  :banghead:
Offline HAMMER DOWN
« Reply #46 on: June 13, 2010, 10:50:00 PM »
:agree: :agree: :agree: :agree: I can do the same thing with my 05 Subaru Legacy GT, Uni-body car (no frame rails).  Put the fool jack under the front jacking point behind the front wheels and lift the whole side of the car. The GXP with a full frame will have no issues.
Mike
