A couple of weeks ago I had posted in the Trunk Springs Thread that I could not find those darn springs in any of the hardware stores in my area. The next day, Dick was in a hardware store, so he picked up a set and mailed them out to me!!
What a nice gesture Dick, I really appreciated you doing that, out of the blue for me. Thanks, and I owe you a few beer!
This evening I finally had a chance to attempt the spring mod. I didn't drill any holes or anything as I wasn't sure if the mod was going to be something I liked or not. What I did was take one end of the spring between a couple pairs of needle nose pliers and open up the hook a little. This allowed me to slip that end over the bar in the trunk. I then slipped the other spring loop over the pin that sticks out. It appeared that the spring may slip off that pin so I took some electrical tape and made a Goalie Stick Knob on the end of the pin. It actually is hardly noticeable and holds the spring in place nicely.
For now, I'll leave this set up and if all is good after some usage, I'll probably drill them in permanently.
I tested it out after installing just the 1 spring on the drivers side. Hit the button and it popped wide open. Put the top up, connected the sails and tried it again. Sails released and the trunk popped wide open. I think for now I will go with just the 1 spring in place and see how it goes. If needed later on, I'll do the other side.
Thanks again to DickW for the springs, and to the forum in general for the mod idea!!!
