Aware of the sensors at the top, this might help , what the actuator solenoid typically looks like:
I looked around but there are so many electrical connections hate to start popping stuff off in an attempt to find something that might not be so obvious.
This is a nice to know for me now as cleaning my MAF made the problem go away. A little spray on alcohol and all is well again. Funny how the software on these machines works, transmission starts acting funny with a root cause in a contaminated MAF. In some ways I get it, having taken programming back in college , once you start getting outside normal parameters funny things happen between the ECM and TCM. Engine had just one code, P0172 , running rich, cleared now. Time will tell if there is more to this issue but engine and tranny working great for past two days.
Some suggest the MAF contamination comes from the K&N oiled filter, don't know, K&N says this is a urban myth. When you look at the actual sensors in the MAF they are so small just about anything could impact the info being sent to the ECM. You can't see contamination with the your eye (at least not with mine) as the sensor itself is tiny, tiny, tiny. Cheap fix cleaning the MAF off.
