Author Topic: Compact battery options?  (Read 10667 times)
« on: June 24, 2010, 05:37:40 AM »
I have noticed some discussion regarding compact battery options for our cars. What small battery is robust enough to install and function properly in our cars? Are those batteries a dry cell or a lead acid gel cell?
Re: Compact battery options?
« Reply #1 on: June 24, 2010, 06:42:40 AM »
Theses must be dry cells as they can be mounted in any direction.
http://www.skyroadster.com/forums/f25/my-15lb-battery-26110/
« Reply #2 on: June 24, 2010, 07:05:48 AM »
nice topic!!!
never considered this, but it seems that there are replacement batteries out there to save some weight and space!!
Offline Ben L
« Reply #3 on: June 24, 2010, 07:17:28 AM »
I run a Braille in the Coupe.  12 pounds, mounted sideways, and more than enough cranking power to turn the mighty 347 ci stroker.  Would not be good for running a lot of accessories though.
« Reply #4 on: June 24, 2010, 07:52:13 AM »
Which model do you use?
Offline JimmyBaja
« Reply #5 on: June 24, 2010, 09:34:30 AM »
I am interested in this also, I went to the Braille website & it looks like the 15lb B2015 or B2015C(carbon fiber case) would be the best choice for every day use(daily driving) & the 11.5lb B14115/B14115C would work for racing for our cars.
« Reply #6 on: June 24, 2010, 09:40:47 AM »
Would you be able to get one installed in time for Friday?  :lol: :rofl:
« Reply #7 on: June 24, 2010, 01:20:45 PM »
I'm kinda interested in this. Maybe when my battery dies in a few years.
« Reply #8 on: June 24, 2010, 01:27:44 PM »
There is an e-bay auction active on a B14115 and I am in. I had no idea our battery is so heavy !!!!!
Offline JoshMcMadMac
« Reply #9 on: June 24, 2010, 02:18:34 PM »
Deka Sports Power batteries are alleged to be the same, and much cheaper, than Braille.
« Reply #10 on: June 24, 2010, 02:38:38 PM »
The lithium ion batteries intrique me but the cost is prohibitive at this time. I do like the idea of these small light batteries for our cars though.
Offline Vanguard
« Reply #11 on: June 24, 2010, 04:36:43 PM »
Anyone have a weight on our stock batteries?
« Reply #12 on: June 24, 2010, 04:44:13 PM »
Sky888 on the Sky BB said it's 45 pounds.
« Reply #13 on: June 24, 2010, 04:47:35 PM »
48 lbs? I replaced mine back when my car first started acting up, while it's pretty heavy, I don't think it's anywhere 50 lbs type heavy. My guess would put it in the 30's.
« Reply #14 on: June 24, 2010, 05:00:16 PM »
Well, next week when I get a Braille I will weigh both it and the OEM.
« Reply #15 on: June 24, 2010, 05:34:13 PM »
My digital bathroom scale showed 32 lbs for the Walmart replacement that was in there and 12 lbs for the Braile. I'm sure it does it own rounding but an honest 20 lbs savings.
The terminals are direct mount. They are beveled and SKY888 mentioned them slipping off.
« Reply #16 on: June 24, 2010, 08:55:37 PM »
Good to know.
« Reply #17 on: June 25, 2010, 01:42:03 AM »
with the lightweight batteries, is it enough to throw off weight distribution?  It won't matter much for a daily driver / street car but what about you racers?  Taking 22 pound out of one side have any effect?  It is near the center of the car to begin with so I'm guessing front / rear will be less effected?  Perhaps not enough to really matter?
« Reply #18 on: June 25, 2010, 08:05:46 AM »
The difference is almost 1% of the vehicle weight. Not much, but it's something. Moving that 12-15 pounds to the trunk WOULD be moving it from near the f/r center to above the rear wheel, but on a set of scales there would be nearly zero change.
As for the real affect on performance, I have had passengers (instructors) in the car during solo runs at Evolution Schools and the difference is remarkable. "Adding lightness" works. For daily driving the return on investment would be YEARS. Lots of them.
« Reply #19 on: July 20, 2010, 11:34:15 AM »
i just checked Autowerks, and they have a kit (lightweight battery 14 pounds and a brace to hold it in position).
is this an OEM battery or is it a Braille?
is the autowerks battery any good?
« Reply #20 on: July 20, 2010, 01:02:51 PM »
Just out of curiosity, wouldn't going to a lighter battery throw off the right to left weight distribution?  I just replaced mine with a Powermaster battery that has 40 more cranking amps, was slightly lighter, and was the same dimensions.  I got it for $120.
« Reply #21 on: July 20, 2010, 02:21:58 PM »
It would not be an OEM battery, but a relabeled battery from a supplier. My is a Braille 14115 with $12 worth of hold down hardware. I would think that you could purchase all that in Greece. If not price shop what you want and somebody can mail it to you.
« Reply #22 on: July 20, 2010, 02:56:34 PM »
thx snaponbob!!! i m leaning towards the Braille, since quite a few of you guys have already tested it.
when i make my move, i ll check if i can find the equipment to "lock" the new battery at it's place
« Reply #23 on: July 20, 2010, 04:42:56 PM »
The ONLY caution I will share is this -- mine is fully charged, the weather has been 80's and 90s (NOT Celsius!!!) and the car does crank a bit slower than the OEM battery. It will be interesting what it will be like in cold weather. I guess in six months I'll know, huh?
Offline DirtyMike
« Reply #24 on: July 21, 2010, 07:06:57 AM »
anyone try xs power, shuriken  or kinetic light weight batteries? looking at options since gonna replace mine soon
