Author Topic: Smoke coming from your tailpipe - must read!!!  (Read 62329 times)
Re: Smoke coming from your tailpipe - must read!!!
« Reply #125 on: September 15, 2010, 12:46:16 PM »
hope that is all it is Chuck.
« Reply #126 on: September 15, 2010, 12:54:16 PM »
Me too. Glad it's hopefully being taken care of.
Offline chuckdoc
« Reply #127 on: September 17, 2010, 06:39:51 PM »
Ok, just got the car back and it is running great and no smoke.
This is what the tech wrote:
Excessive play in turbo shaft causing oil leakage into intake system.  Removed turbo hose and found excessive oil in cooler and pipes.  Removed turbo and found excessive play in shaft. Replaced turbo.
12618667 turbo
12618586 gasket
12609878 gasket
12589435 gasket
12611119 gasket
12626102 gasket
Just incase some more turbos start to go.  If you need the gasket numbers.
Apparently was subtle slow loss of power because when I got the car back it was a huge difference.
Chuck
My KappaPerformance Mod Page
« Reply #128 on: September 17, 2010, 07:33:34 PM »
Hey, that's great!!  Now go out and enjoy that refound power!
Offline Graywolf
« Reply #129 on: September 17, 2010, 07:41:45 PM »
Great news, what's the top boost on the replacement turbo
Offline chuckdoc
« Reply #130 on: September 17, 2010, 07:48:14 PM »
Beats me as the stock gauge can only read to25.
Right now I am only running the gmpp tune.
« Reply #131 on: September 17, 2010, 08:06:24 PM »
Chucky is back in love again :)
Offline chuckdoc
« Reply #132 on: September 17, 2010, 08:47:54 PM »
It's funny, but I am.  Even washed, clay bared,polished and sealed her.  Also a application of ragtopp.
« Reply #133 on: September 17, 2010, 10:41:11 PM »
Chuck  Glad you got it fixed .Now I'm wondering about mine . They told me my seals are blown also .Plus an oil leak .     :idk:      :huh:     :idk:         :huh:      :idk:         :huh:      :gaah:
« Reply #134 on: September 18, 2010, 02:08:26 AM »
chuckdoc, did you check the new turbo the dealer installed.
does it have the metal BPV that spoolin told us about or the plastic one?
Offline chuckdoc
« Reply #135 on: September 18, 2010, 07:12:38 AM »
I will check
Offline chuckdoc
« Reply #136 on: September 18, 2010, 07:25:18 AM »
Make sure you take the car to a dealer that you trust.  once they denied the warranty every dealer will deny the warranty because they put it in the computer. if you can attempt to do it yourself make sure you get all the gaskets I listed, you might want to talk to Joe if he wants to try, cause I'd be happy to help. I got a feeling a lot of cars are going to be having the same problem once enough of them reached the around 50,000 miles or more.  hope it works out for you. Let us know.
If you have to cover costs, there was a half price new one on sale here.
Offline HAMMER DOWN
« Reply #137 on: September 18, 2010, 09:13:55 AM »
Glad you got it fixed. Knock on wood, almost 56k, the only thing my car smoke is tires  :brnout: & other cars  :drag:
What kind of oil do you use & whats your OCI? Not starting an oil bashing thread. Excessive play in turbo shaft is caused, IMO by 3 thing. 1) oil starvation. 2) oil failure, (run your oil pass it's useful life, only OA's can tell your that.) 3) design & manufacturing of the turbo & oiling & cooling systems, ( if OEM don't get it right. The original turbos won't make it pass the 100k warranty.
So maybe if we start having more turbo failures, (hope not) we can start another thread. With more info. so we can find out why these turbos are failing.
Mike
« Last Edit: September 18, 2010, 07:58:10 PM by HAMMER DOWN »
Offline Yogi
« Reply #138 on: September 18, 2010, 12:52:57 PM »
The 3 bar MAP sensors with the GMPP tune are good for 28.8 psig.   :drive:
Is 25 the most that you see?   :idk:
Congrats on getting her fixed!    :thumbs:
2008 Saturn Sky Red Line
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Monsoon Sound System
Leather Seats
Offline chuckdoc
« Reply #139 on: September 18, 2010, 01:12:26 PM »
I am pretty sure the stock gauge only reads to 25
Only use mobile 1 and change it way before it is recommended.
I may have a guess on why it failed but will not post right now.
Joe knows what may be the problem.  Let's just say high boost pressures and leave it at that.
Do not know who reads this outsde of our group.
Offline Yogi
« Reply #140 on: September 18, 2010, 01:17:07 PM »
Maybe you're thinking of the stock LNF 2.7 bar sensors?  They max out at 24.5 psig which may readout as 25.
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
Offline chuckdoc
« Reply #141 on: September 18, 2010, 01:25:03 PM »
Who knows, I just can tell you I am running strong and great and back in love.
Watchout for oil in inntrtcooler on the intake side and the inntercooler hose leading to the inntercooler from the turbo.
There may be some oil in there anyway but the tech used the word excessive. I would assume than some oil was expected there or else why use the adjetive excessive?
« Reply #142 on: September 18, 2010, 02:44:51 PM »
Back in the day, you always let your turbo cooldown, by letting the car idle for a while before you shut it off.  There even created an aftermarked with turbo timers for the aftermarket turbo set up.  Maybe you guys should practice letting them cool down before you twist the key and jump out of the car
« Reply #143 on: September 18, 2010, 03:56:49 PM »
Its only got 20,824 miles on it.and still 18 months  Joe did the removal of the tune from up north .Now it onlf has GMPP on it .I/m taking it to Koons tuesday I took it over today and set it up.Now Time will tell
« Reply #144 on: September 18, 2010, 04:10:52 PM »
Yogi ; I have the GMPP tune also and it maxed out at 25 PSI . my Aero force gauge did the same thing 25
« Reply #145 on: September 18, 2010, 04:14:46 PM »
 Chuck, Koons told me they have a Scanner that over-rides the ECM of any thing they type in it  boost included.
Offline chuckdoc
« Reply #146 on: September 18, 2010, 04:19:56 PM »
Which koons?  There are several!  And I don't understand what they are talking about.  Scanners overide nothing!  Why would they want to overide what they put in.  Not making sense!
« Reply #147 on: September 18, 2010, 04:42:22 PM »
They said this scanner can read ture Boost some how not through PCM  I know as much as you . Koons White Marsh MD they service a lot of Vettes and other performance Veh.
Offline chuckdoc
« Reply #148 on: September 18, 2010, 04:53:25 PM »
Even with my leaking turbo, I still put out plenty of boost.  I sure hope that is not how they are diagnosing the problem.
By the way, you know more than me.  Unfortunately we both know more than 1/2 the dealers.
Offline chuckdoc
« Reply #149 on: September 18, 2010, 04:55:20 PM »
Check out this video on YouTube:
http://www.youtube.com/watch?v=JJ2U1GeLzS8&feature=youtube_gdata_player
Good explanation of a turbo, wait for the middle and it explais the seals.  I forgot how to post a link so maybe Joe can fix?
Don't bother if you really understand the bearing system
