So, just to add a quick review of the installed brace...
I put mine in on Saturday morning. Worst parts of the install were removing the PS fluid hose and draining without trying to get fluid all over the chassis (I failed). Then routing the longer hoses while keeping them away from the turbo was a struggle. As for the brace itself, cutting the liners was the worst part, closely followed by trying to tighten the front passenger side tower nut. TIP: to save you time, the only way to tighten that nut is to use an open-ended wrench from inside the wheel liner (over the tire). Other tower nuts work with a socket+extension.
OK, onto driving. I did a fair bit of street driving to try it out. I did feel a bit more directness in the steering - though I have to admit I'm not sure if that's "emperor's new clothes" syndrome or not. One thing that was obvious though was the reduction in cowl shake. Now the Kappa is pretty stiff for a 'vert and it takes a decent pothole to set up a quiver, but this brace makes it noticeably better. More solid feeling, less rattle. Recommended if only for that!
EDIT: One other thing I forgot to mention, there seems to be a tad more oversteer - certainly on sharp turns - with the brace in place. Nothing startling, mind, but interesting.
Thanks DDM!
