Author Topic: LatinVenom Front Chassis Brace project  (Read 111219 times)
Offline Cheers
Re: LatinVenom Front Chassis Brace project
« Reply #200 on: November 07, 2011, 12:42:55 PM »
Many thanks to LatinVenom for another great product.
Just a question that I have not found an answer to -- why are the bolts in the frame for in the first place?
« Reply #201 on: November 07, 2011, 02:20:43 PM »
They are probably used for manufacturing tooling.
Offline Cheers
« Reply #202 on: November 07, 2011, 07:32:59 PM »
THANKS
Offline Cheers
« Reply #203 on: November 09, 2011, 01:43:44 PM »
The first photo shows my tools used to reach the bolts on the sides.  Then the photos start with my placement of the brace in the drivers side, I accidentally placed it under a line on the passenger side and had to reposition it, then I was able to get the brace on the spot as described in the instructions.  Very good instructions by the way.  Even though the inside bolt on the driver side was a "B" it took me about 30 minutes to install.   I haven't had much time to test as the traffic sucked going to and from work.
Thanks for the photos and advice on the AC line and you a right-on on the inside bolt on the driver side was a "B"!!
« Reply #204 on: November 09, 2011, 11:54:02 PM »
They were put there so the LVFCB could be installed." GM must have known it was coming."
« Reply #205 on: November 10, 2011, 08:26:41 AM »
The LVFCB cannot be installed with those of us with DDM S/C kits. I looked at mine yesterday because I was curious to see where the mounting holes were and happened to notice that the passenger side mounting hole is obstructed by one of the S/C intercooler tubes.
