1/2" outer the thread (xtreme backbone thick) means less tight...
The 1/2" version does come with longer bolts
The 3/8" and 1/4" version do not.
The stock bolts have a little over 1" of thread to them, so with the 1/4" backbone you are engaging 3/4", with the 3/8" version you are engaging 5/8". The standard is to engage 1.5 times the width of the bolt, so since it is a 8mm bolt, you would want to engage atleast 12mm, or roughly 1/2". Since the 1/2" backbone would put it right at that limit we give longer bolts, but the other 2 thickness backbones exceed the standard.
Hope that helps,
Dave
