Author Topic: The Intercooler Thread  (Read 131740 times)
Re: The Intercooler Thread
« Reply #125 on: July 31, 2012, 10:10:03 AM »
Yup. I always run a fan on the race cars because we used to get delayed in pregrid and some of them don't like to restart once they are hotter than heck sitting idling in the sun. Always gives you a good feeling to just reach out and flick a switch and sit comfortably while those around you without fans start uttering muted (by the helmets) screams at the track crew to get things on the road.  I gladly sacrifice any small reduction in cooling caused by the fan blocking air at speed for that sense of security in pregrid!
I am guessing you are talking about a radiator fan? If so, are you running shrouding on the fan, or is the fan just mounted to the radiator with no shroud?
« Reply #126 on: July 31, 2012, 10:17:05 AM »
Yes, radiator fan, and no, I don't run shrouding - I don't need it at idle and it would just further block the air at speed.  I have the whole nose of the car ducted to the radiator and have no cooling issues once under way.
The IC on the Kappas puts out a fair bit of thermal load, straight into the radiator which must make that component critical as well. Are the racers running upgraded rads as well as ICs?  Kind of compounds the issue.
« Reply #127 on: July 31, 2012, 10:30:27 AM »
On the shrouding we run the rubber flaps like a lot of OEM's are doing now, it allows you to have shrouding for great cooling with the fan, then at speed the flaps open to allow air to flow out of the shroud easier, works really well. You have done the same as we have done though in the past with the fan direct to the radiator, no shrouding on the race car. Gives it enough to keep from over heating for minimal weight penalty and restriction to flow.
« Reply #128 on: September 08, 2012, 05:31:18 PM »
I have a cracked inter cooler :gaah:
Anyone know if it's covered under warranty GMPP?
Don't have the $$ for an aftermarket one right now so suggestions if it's not covered.
Thanks
« Reply #129 on: September 08, 2012, 05:45:38 PM »
I think it is covered under drivetrain warranty
« Reply #130 on: September 08, 2012, 06:01:28 PM »
I hope so but Im not too sure.  Im looking at my warranty booklet and I don't see air charge cooler or inter cooler listed I might be SOL.
« Reply #131 on: September 08, 2012, 06:02:21 PM »
There are definitely some people who have had it replaced out there. I'm sure someone will speak up eventually.
« Reply #132 on: September 08, 2012, 06:13:49 PM »
Reed just had his repaired under warranty no more than 2 months ago.
« Reply #133 on: September 08, 2012, 09:20:10 PM »
It is covered by the exhaust warranty. In CA its 80,000 miles or 8 years. Not sure if that translates through. Found the excerpt for Reed two months ago. Search his thread posts as he posted the whole section. How many miles on your car?
« Reply #134 on: September 08, 2012, 09:40:45 PM »
Cali warranty as well as a few other states are different than the rest of the US.
Other question is since its past 5yrs in service date by 5 mos if covered by the 5yr 100k warranty will it carry over to the GMPP extended warranty?  I'm thinking probably NOT so either way I'm more than likely screwed or possibly might have to something since its past.  Maybe since i have had issue too many to count they might give me a free courtesy NC repair.
Does anyone know if the split can be TIG welded effectively?
« Last Edit: September 08, 2012, 09:57:38 PM by tazz »
« Reply #135 on: September 08, 2012, 09:51:30 PM »
 Did find this though on GM Inside News.
Basically its covered but the 5yrs i think is the deciding factor for me since Im over. J5685       Intercooler Assembly -- Replace
2007 to 2009 model year GM 5yr/100k Powertrain Warranty
EDIT: The following items apply to 2007-2009 vehicles only
Here is a list of the items covered by the powertrain warranty, LONG READ!
Obvious stuff, I just copied this from the GM manual, this is not an absolute guarantee, as things like excessive wear or damage may cause part or failure to lose coverage.
Powertrain Coverage
The information contained herein was correct at the time of dissemination. General Motors reserves the right to change it in the future.
Coverage Code P/P1 see following
Applicable To U.S. Powertrain Warranty
P - Passenger Car and LD Truck Powertrain Components- 5 years/100,00 miles
P1 - Passenger Car and LD Truck Powertrain Components that require maintenance
5 years/ 100,000 without interruption if maintenance was performed in accordance with the GM Maintenance Schedule
Canadian Powertrain Warranty
P - Passenger Car and LD Truck Powertrain Components- 5 years/160,000km
5 years/ 160,000km without interruption if maintenance was performed in accordance with the GM Maintenance Schedule
Refer to GM Service Policy and Procedure Manual for further information regarding policies and coverages, including applicable models and years.
Labor Operations E0000 -- E9999
E0050    Cap, Wheel Nut -- Replace
E0072    Cap, Hub Assembly -- Front -- R&R or Replace
E0073    Cap, Hub Assembly -- Rear -- R&R or Replace
E0077    Cap, Hub Assembly -- All -- R&R or Replace
E2220    Bearing, Front Wheel -- Right -- Adjust
E2221    Bearing, Front Wheel -- Left -- Adjust
E2227    Bearing, Front Wheel -- Both -- Adjust
E2230    Cap, Front Wheel Hub Dust -- Right -- Replace
E2231    Cap, Front Wheel Hub Dust -- Left -- Replace
E2237    Cap, Front Wheel Hub Dust -- Both -- Replace
E2239    Front Wheel Hub, Bearing, and Seal Replacement
E2240    Bearing, Front Wheel -- Inner -- Right -- Replace
E2241    Bearing, Front Wheel -- Inner -- Left -- Replace
E2247    Bearing, Front Wheel -- Inner -- Both -- Replace
E2250    Bearing, Front Wheel -- Outer -- Right -- Replace
E2251    Bearing, Front Wheel -- Outer -- Left -- Replace
E2257    Bearing, Front Wheel -- Outer -- Both -- Replace
E2260    Bearing, Front Wheel -- Inner and Outer -- Right -- Replace
E2261    Bearing, Front Wheel -- Inner and Outer -- Left -- Replace
E2267    Bearing, Front Wheel -- Inner and Outer -- Both -- Replace
E2280    Seal, Front Wheel Bearing -- Right -- Replace
E2281    Seal, Front Wheel Bearing -- Left -- Replace
E2287    Seal, Front Wheel Bearing -- Both -- Replace
E2320    Bearing and Hub Assembly, Front Wheel -- Right -- Replace
E2321    Bearing and Hub Assembly, Front Wheel -- Left -- Replace
E2327    Bearing and Hub Assembly, Front Wheel -- Both -- Replace
E2340    Hub Assembly, Front Wheel -- Right -- Replace
E2341    Hub Assembly, Front Wheel -- Left -- Replace
E2347    Hub Assembly, Front Wheel -- Both -- Replace
E3600    Axle, I-Beam -- Replace
E4230    Bearings, Rear Wheel -- Right -- Adjust
E4231    Bearings, Rear Wheel -- Left -- Adjust
E4237    Bearings, Rear Wheel -- Both -- Adjust
E4240    Bearings, Rear Wheel -- Single or Front Tandem -- Right -- Replace
E4241    Bearings, Rear Wheel -- Single or Front Tandem -- Left -- Replace
E4250    Bearings, Rear Wheel -- Rear Tandem -- Right -- Replace
E4251    Bearings, Rear Wheel -- Rear Tandem -- Left -- Replace
E4260    Bearings, Rear Wheel -- Right -- Replace
E4261    Bearings, Rear Wheel -- Left -- Replace
E4267    Bearings, Rear Wheel -- Both -- Replace
E4270    Seal, Rear Wheel Inner Oil (One Wheel) -- Single or Front Tandem -- Right -- Replace
E4271    Seal, Rear Wheel Inner Oil (One Wheel) -- Single or Front Tandem -- Left -- Replace
E4280    Seal, Rear Wheel Bearing Inner Oil (One Wheel) -- Rear Tandem -- Right -- Replace
E4281    Seal, Rear Wheel Bearing Inner Oil (One Wheel) -- Rear Tandem -- Left -- Replace
E4300    Bearing and Hub Assembly, Rear Wheel -- Right -- Replace
E4301    Bearing and Hub Assembly, Rear Wheel -- Left -- Replace
E4307    Bearing and Hub Assembly, Rear Wheel --Both -- Replace
E4360    Hub Assembly, Rear Wheel -- Right -- Replace
E4361    Hub Assembly, Rear Wheel -- Left -- Replace
E4367    Hub Assembly, Rear Wheel -- Both -- Replace
E4370    Hub Assembly, Rear Wheel -- Single or Front Tandem -- Right -- Replace
E4371    Hub Assembly, Rear Wheel -- Single or Front Tandem -- Left -- Replace
E4380    Hub Assembly, Rear Wheel -- Rear Tandem -- Right -- Replace
E4381    Hub Assembly, Rear Wheel -- Rear Tandem --Left -- Replace
E5603    Rear Axle Bushing Replacement
E5622    Rear Axle Upper Control Arm Replacement
E5629    Rear Axle Lower Control Arm Replacement
E5700    Axle Assembly, Rear -- Replace
Labor Operations F0000 -- F9999               F0020    Angularity, Drive Line -- Check and Correct
F0025    Actuator, Front Differential Locking -- Replace
F0028    Seal, Front Differential Shifter -- Replace
F0040    Bearing, Center Support (between Trans and Rear Differential) -- Replace
F0060    Slip Joint, Propeller Shaft (between Trans and Rear Differential) -- Replace
F0092    Universal Joint, Front Propeller Shaft -- Front -- Replace
F0093    Universal Joint, Front Propeller Shaft -- Rear -- Replace
F0097    Universal Joint, Front Propeller Shaft -- Both -- Replace
F1002    Universal Joint, Rear Propeller Shaft -- Front -- Replace
F1003    Universal Joint, Rear Propeller Shaft -- Rear -- Replace
F1006    Universal Joint, Rear Propeller Shaft -- Intermediate -- Replace
F1007    Universal Joint, Rear Propeller Shaft -- Both -- Replace
F1200    Propeller Shaft, Front of Transfer Case -- Replace
F1201    Front Propeller Shaft Replacement
F1220    Propeller Shaft, Intermediate -- Replace
F1240    Propeller Shaft, Rear -- Replace
F1250    Propeller Shaft, Intermediate Axle -- Replace
F1280    Propeller Shaft Assembly (between Trans and Rear Differential) - R&R or Replace
F1295    Bracket, Driveline Support -- Replace
F1298    Support, Driveline -- R&R
F1300    Support, Driveline -- Replace
F1305    Tube, Driveline Torque -- Replace
F1420    Shaft, Front Differential Output -- Front -- Right -- Replace
F1421    Shaft, Front Differential Output -- Front -- Left -- Replace
F1427    Shaft, Front Differential Output -- Front -- Both -- Replace
F1440    Seals, Front Differential Output Shaft -- Front -- Right -- Replace
F1441    Seals, Front Differential Output Shaft -- Front -- Left -- Replace
F1447    Seals, Front Differential Output Shaft -- Front -- Both -- Replace
F1465    Shaft Assembly, Intermediate -- Replace
F1468    Seal, Intermediate Shaft -- Replace
F1469    Bearing, Intermediate Shaft (Front Drive Axle) -- Replace
F1470    Shaft, Inner Axle (Front Drive Axle) -- Replace
F1475    Front Wheel Drive Shaft Replacement -- Right Side
F1476    Front Wheel Drive Shaft Replacement -- Left Side
F1480    Rear Wheel Drive Shaft and Rear Axle Shaft Seal Replacement
F1485    Rear Wheel Drive Shaft Replacement
F1500    Halfshaft, Front Drive -- Front -- Right -- R&R
F1501    Halfshaft, Front Drive -- Front -- Left -- R&R
F1507    Halfshaft, Front Drive -- Front -- Both -- R&R
F1510    Halfshaft, Front Drive -- Front -- Right -- Replace
F1511    Halfshaft, Front Drive -- Front -- Left -- Replace
F1512    Halfshaft, Front Drive -- Front -- Both -- Replace
F1513    Halfshaft, Rear Drive -- Rear -- Right -- Replace
F1514    Halfshaft, Rear Drive -- Rear -- Left -- Replace
F1515    Halfshaft, Rear Drive -- Rear -- Both -- Replace
F1516    Halfshaft, Rear Drive -- Rear -- Right -- R&R
F1517    Halfshaft, Rear Drive -- Rear -- Left -- R&R
F1518    Halfshaft, Rear Drive -- Rear -- Both -- R&R
F1523    Shaft, Axle -- Intermediate -- Replace
F1530    Shaft, Axle -- Rear Axle -- Right -- Replace
F1531    Shaft, Axle -- Rear Axle -- Left -- Replace
F1537    Shaft, Axle -- Rear Axle -- Both -- Replace
F1540    Shaft, Axle -- Single or Front Tandem -- Right -- Replace
F1541    Shaft, Axle -- Single or Front Tandem -- Left -- Replace
F1550    Shaft, Axle -- Rear Tandem -- Right -- Replace
F1551    Shaft, Axle -- Rear Tandem -- Left -- Replace
F1555    Front Wheel Drive Shaft Outer Joint Replacement
F1556    Front Wheel Drive Shaft Inner Joint Replacement
F1566    Front Wheel Drive Shaft Inner Joint Boot Replacement
F1567    Front Wheel Drive Shaft Outer Joint Boot Replacement
F1568    Rear Wheel Drive Shaft Inner Joint Boot Replacement
F1569    Rear Wheel Drive Shaft Outer Joint Boot Replacement
F1575    Boot (Seal), Axle Shaft Joint -- One -- Replace
F1580    Front Wheel Drive Shaft Inner Joint and Boot Replacement
F1581    Front Wheel Drive Shaft Outer Joint and Boot Replacement
F1582    Rear Wheel Drive Shaft Inner Joint and Boot Replacement
F1583    Rear Wheel Drive Shaft Outer Joint and Boot Replacement
F1594    Seal, Axle Shaft Inner -- Rear -- Right -- Replace
F1595    Seal, Axle Shaft Inner -- Rear -- Left -- Replace
F1597    Seal, Axle Shaft Inner -- Rear -- Both -- Replace
F1600    Seal, Axle Shaft Oil -- Front Axle -- Right -- Replace
F1601    Seal, Axle Shaft Oil -- Front Axle -- Left -- Replace
F1607    Seal, Axle Shaft Oil -- Front Axle -- Both -- Replace
F1610    Seal, Axle Shaft Oil -- Rear Axle -- Right -- Replace
F1611    Seal, Axle Shaft Oil -- Rear Axle -- Left -- Replace
F1617    Seal, Axle Shaft Oil -- Rear Axle --Both -- Replace
F1650    Bearing, Axle Shaft -- Rear Axle -- Right -- Replace
F1651    Bearing, Axle Shaft -- Rear Axle -- Left -- Replace
F1657    Bearing, Axle Shaft -- Rear Axle -- Both -- Replace
F1660    Bearing, Rear Wheel -- Right -- Replace
F1661    Bearing, Rear Wheel -- Left -- Replace
F1662    Bearing, Rear Wheel -- Both -- Replace
F1665    Hub Assembly, Rear Wheel -- Right -- Replace
F1666    Hub Assembly, Rear Wheel -- Left -- Replace
F1667    Hub Assembly, Rear Wheel -- Both -- Replace
F1670    Seal, Hub Oil -- Rear Axle -- Right -- Replace
F1671    Seal, Hub Oil -- Rear Axle -- Left -- Replace
F1672    Seal, Hub Oil -- Rear Axle -- Both -- Replace
F1675    Gasket, Axle Oil -- Rear Axle -- Right -- Replace
F1676    Gasket, Axle Oil -- Rear Axle -- Left -- Replace
F1677    Gasket, Axle Oil -- Rear Axle -- Both -- Replace
F1680    Differential Oil Cooler Inlet Hose Replacement
F1681    Differential Oil Pump Inlet Hose Replacement
F1683    Differential Oil Cooler Replacement
F2001    Front Differential Carrier Oil Drain or Filler Plug Replacement
F2002    Cover/Gasket, Differential -- Front -- Replace
F2003    Cover and/or Gasket, Differential -- Rear Differential -- Replace
F2004    Cover and/or Gasket, Differential -- Rear Differential -- Right -- Replace
F2005    Cover and/or Gasket, Differential -- Rear Differential -- Left -- Replace
F2006    Cover and/or Gasket, Differential -- Rear Differential -- Rear -- Replace
F2020    Drive Pinion Flange/Yoke and/or Oil Seal Replacement
F2022    Seal, Pinion Shaft Oil -- Front Differential -- Replace
F2023    Seal, Pinion Shaft Oil -- Rear Differential -- Replace
F2024    Seal, Pinion Shaft Oil -- Single or Front Tandem -- Replace
F2025    Seal, Pinion Shaft Oil -- Rear Tandem -- Replace
F2027    Seal, Differential Carrier Extension Cover -- Replace
F2042    Flange, Pinion Shaft -- Front Differnetial -- Replace
F2043    Flange, Pinion Shaft -- Rear Differnetial -- Replace
F2115    Tube Assembly, Front Differential Output Shaft -- R&R or Replace
F2122    Carrier Assembly -- Front Differential -- R&R
F2123    Carrier Assembly -- Rear Differential -- R&R
F2124    Carrier Assembly -- Single or Front Tandem -- R&R
F2125    Carrier Assembly -- Rear Tandem -- R&R
F2134    Carrier Assembly Complete -- Single or Front Tandem -- Recondition
F2135    Carrier Assembly Complete -- Rear Tandem -- Recondition
F2142    Carrier Assembly Complete -- Front Differential -- Replace
F2143    Carrier Assembly Complete -- Rear Differential -- Replace
F2155    Rear Differential Clutch Control Module Replacement
F2158    Differential Carrier Bushing Replacement -- Front
F2159    Differential Carrier Bushing Replacement -- Rear
F2165    Differential Clutch Drum Assembly Replacement
F2166    Rear Wheel Drive Module Clutch Housing Replacement
F2183    Pinion Shaft, Pinion Gears and/or Side Gears, Differential -- Rear Differential -- Replace
F2185    Gears, Differential Side and Pinion -- Replace
F2186    Electronic Locking Differential Coil Lock Replacement
F2223    Case, Differential -- Rear Differential -- Replace
F2240    Plates, Limited Slip Clutch -- Replace
F2263    Bearings, Side -- Rear Differential -- Replace
F2283    Bearing, Pinion (Front and/or Rear) -- Rear Differential -- Replace
F2382    Ring Gear and Pinion -- Front Differential -- Replace
F2383    Ring Gear and Pinion -- Rear Differential -- Replace
F2620    Pad, Carrier Ring Gear Thrust -- Adjust
F2640    Filter, Carrier Oil -- Replace
F2680    Seal, Thru-Shaft Output -- Replace
F2683    Shaft, Thru-Shaft Output -- Replace
F2684    Bearing and/or Housing, Thru-Shaft -- Replace
F2685    Retainer, Thru-Shaft Output Bearing -- Replace
F2820    Shift Assembly, Axle (Electric) -- R&R or Replace
F2840    Motor, Axle Shift -- Replace
F2880    Block, Axle Shift Sliding -- Replace
F3023    Housing Assembly, Differential -- Rear Differential -- Replace
F3026    Seal, Rear Axle Housing Drain -- Replace
F3030    Bushing, Rear Differential Damping -- Right -- Replace
F3031    Bushing, Rear Differential Damping -- Left -- Replace
F3037    Bushing, Rear Differential Damping -- Both -- Replace
F3062    Housing, Axle -- Single or Front Tandem -- Rear -- Replace
F3063    Housing, Axle -- Rear Tandem -- Replace
F3200    Rear Differential Assembly (Complete) -- Replace
F3201    Rear Wheel Drive Module Replacement
F3262    Axle Assembly, Rear -- Single or Front Tandem -- Replace
F3263    Axle Assembly, Rear Tandem -- Replace
F3269    Ventilator, Axle -- Front -- Replace
F3270    Ventilator, Axle -- Rear -- Replace
F3272    Plug, Differential Carrier Drain -- Replace
F3273    Plug, Differential Carrier Fill -- Replace
Labor Operations J0000 -- J2999 J0100     Manifold, Exhaust -- Right Bank -- Replace
J0101     Manifold, Exhaust -- Left Bank -- Replace
J0102     Manifold Converter Assembly, Exhaust -- Right Bank -- Replace
J0103     Manifold Converter Assembly, Exhaust -- Left Bank -- Replace
J0104     Manifold Converter Assembly, Exhaust -- Single -- Replace
J0106     Manifold and/or Gasket, Exhaust -- Replace
J0108     Manifold, Exhaust -- Replace
J0152     Spacer, Intake -- Replace
J0153     Intake Manifold Tube Replacement
J0194     Cover, Upper Intake Manifold -- Replace
J0207     Cover and/or Gasket, Engine Block Valley -- Replace
J0241     Charge Air Cooler Front Manifold Replacement
J0250     Manifold, Intake -- Replace
J0251     Gasket, Intake Manifold -- Replace
J0254     Manifold, Intake (Upper) -- Replace
J0255     Gasket, Intake Manifold (Upper) -- Replace
J0258     Manifold, Intake (Lower) -- Replace
J0259     Gasket, Intake Manifold (Lower) -- Replace
J0260     Manifold, Intake (Right) -- Replace
J0261     Gasket, Intake Manifold (Right) -- Replace
J0264     Manifold, Intake (Left) -- Replace
J0265     Gasket, Intake Manifold (Left) -- Replace
J0268     Manifold, Intake (Center) -- Replace
J0269     Gasket, Intake Manifold (Center) -- Replace
J0280     Cover, Valve Rocker Arm Upper -- Right -- Replace
J0281     Cover, Valve Rocker Arm Upper -- Left -- Replace
J0282     Cover, Valve Rocker Arm Upper -- Both -- Replace
J0300     Cover and/or Gasket, Rocker -- Right Bank -- Replace
J0301     Cover and/or Gasket, Rocker -- Left Bank -- Replace
J0307     Cover and/or Gasket, Rocker -- Both Banks -- Replace
J0308     Cover and/or Gasket, Rocker -- Replace
J0310     Cover and/or Gasket, Camshaft Housing -- Right -- Replace
J0311     Cover and/or Gasket, Camshaft Housing -- Left -- Replace
J0317     Cover and/or Gasket, Camshaft Housing -- Both -- Replace
J0318     Cover and/or Gasket, Camshaft Housing -- One Piece -- Replace
J0319     Camshaft Housing Replacement
J0336     Rocker Arm, Intake -- One Cyl -- Replace
J0337     Rocker Arm -- One Cylinder, Exhaust -- Replace
J0338     Rocker Arm, Exhaust -- One or All -- Replace
J0340     Rocker Arm, Intake (One or All) -- Right (Rear) Head -- Replace
J0341     Rocker Arm, Intake (One or All) -- Left (Front) Head -- Replace
J0342     Rocker Arm, Exhaust (One or All) -- Right (Rear) Head -- Replace
J0343     Rocker Arm, Exhaust (One or All) -- Left (Front) Head -- Replace
J0350     Rocker Arm - One Cyl -- Right Bank -- Replace
J0351     Rocker Arm - One Cyl -- Left Bank -- Replace
J0357     Rocker Arm - One Cyl -- Both Banks -- Replace
J0358     Rocker Arm - One Cyl -- Replace
J0359     Rocker Arm - One or All -- Replace
J0360     Rocker Arm Shaft and/or Assemblies -- Right Bank -- Replace
J0361     Rocker Arm Shaft and/or Assemblies -- Left Bank -- Replace
J0367     Rocker Arm Shaft and/or Assemblies -- Both Banks -- Replace
J0368     Shaft, Rocker Arm -- One or Both -- Replace
J0370     Arm and/or Pivot, Rocker -- One Cyl -- Right Bank -- Replace
J0371     Arm and/or Pivot, Rocker -- One Cyl -- Left Bank -- Replace
J0377     Arm and/or Pivot, Rocker -- One Cyl -- Both Banks -- Replace
J0380     Stud, Rocker Arm -- One Stud -- Right Bank -- Replace
J0381     Stud, Rocker Arm -- One Stud -- Left Bank -- Replace
J0420     Valve Lash -- Adjust
J0495     Plug, Cylinder Head Oil -- Right Bank -- Replace
J0496     Plug, Cylinder Head Oil -- Left Bank -- Replace
J0500     Gasket, Cylinder Head -- Right Bank -- Replace
J0501     Gasket, Cylinder Head -- Left Bank -- Replace
J0507     Gasket, Cylinder Head -- Both Banks -- Replace
J0508     Gasket, Cylinder Head -- Replace
J0509     Valve, Oil Flow Check -- Replace
J0510     Head, Cylinder -- Right Bank -- Replace
J0511     Head, Cylinder -- Left Bank -- Replace
J0517     Head, Cylinder -- Both Banks -- Replace
J0518     Head, Cylinder -- Replace
J0520     Valve -- One Cyl -- Right Bank -- Recondition or Replace
J0521     Valve -- One Cyl -- Left Bank -- Recondition or Replace
J0527     Valve -- One Cyl -- Both Banks -- Recondition or Replace
J0528     Valve -- One Cyl -- Recondition or Replace
J0529     Valve -- Replace
J0530     Guide, Valve -- One Cyl -- Replace
J0540     Spring, Cap and/or Seal, Valve -- One Cyl -- Right Bank -- Replace
J0541     Spring, Cap and/or Seal, Valve -- One Cyl -- Left Bank -- Replace
J0544     Spring, Cap and/or Seal, Valve -- All Seats -- Intake -- Replace
J0545     Spring, Cap and/or Seal, Valve -- All Seats -- Exhaust -- Replace
J0546     Spring, Cap and/or Seal, Valve -- All Seats -- Both -- Replace
J0547     Spring, Cap and/or Seal, Valve -- One Cyl -- Both Banks -- Replace
J0548     Spring, Cap and/or Seal, Valve -- One Cyl -- Replace
J0550     Spring, Cap and/or Seal, Valve -- Intake -- Replace
J0551     Spring, Cap and/or Seal, Valve -- Exhaust -- Replace
J0556     Spring, Cap and/or Seal, Valve -- Both -- Replace
J0560     Adjuster, Valve -- One Cyl -- Replace
J0565     Adjuster, Hydraulic Valve Lash -- One Cylinder, Intake -- Replace
J0566     Adjuster, Hydraulic Valve Lash -- One Cylinder, Exhaust -- Replace
J0580     Push Rod -- One Cyl -- Right Bank -- Replace
J0581     Push Rod -- One Cyl -- Left Bank -- Replace
J0587     Push Rod -- One Cyl -- Both Banks -- Replace
J0590     Guide, Push Rod -- One Cyl -- Right Bank -- Replace
J0591     Guide, Push Rod -- One Cyl -- Left Bank -- Replace
J0597     Guide, Push Rod -- One Cyl -- Both Banks -- Replace
J0610     Manifold, Valve Lifter Oil -- Replace
J0611     Gasket, Valve Lifter Oil Manifold -- Replace
J0620     Lifter, Valve -- Right Bank -- Replace
J0621     Lifter, Valve -- Left Bank -- Replace
J0627     Lifter, Valve -- Both Banks -- Replace
J0629     Lifter, Valve -- Replace
J0630     Lifter, Valve -- Intake -- Replace
J0631     Lifter, Valve -- Exhaust -- Replace
J0632     Lifter, Valve -- Both -- Replace
J0634     Lifters, Intake (One or All) -- Right Head -- Replace
J0635     Lifters, Intake (One or All) -- Left Head -- Replace
J0636     Lifters, Exhaust (One or All) -- Right Head -- Replace
J0637     Lifters, Exhaust (One or All) -- Left Head -- Replace
J0640     Guide and/or Clamp, Lifter -- One Cyl -- Right Bank -- Replace
J0641     Guide and/or Clamp, Lifter -- One Cyl -- Left Bank -- Replace
J0647     Guide and/or Clamp, Lifter -- One Cyl -- Both Banks -- Replace
J0686     Bracket, Timing Belt Tensioner -- Replace
J0720     Balancer, Harmonic -- Replace
J0736     Timing Belt Rear Cover Replacement
J0737     Timing Belt Upper Front Cover Replacement
J0738     Timing Belt Center Front Cover Replacement
J0739     Timing Belt Lower Front Cover Replacement
J0740     Seal, Crankcase Front Cover -- Replace
J0741     Crankshaft Front Oil Seal Replacement
J0750     Seal, Timing Cover Oil -- Replace
J0770     Cover and/or Gasket, Crankcase Front -- Replace
J0771     Engine Front Cover Replacement
J0772     Engine Front Cover with Oil Pump Replacement
J0778     Secondary Camshaft Intermediate Drive Chain Tensioner Replacement -- Right Side
J0779     Secondary Camshaft Intermediate Drive Chain Tensioner Replacement -- Left Side
J0780     Cover and/or Gasket, Timing -- Replace
J0781     Primary Timing Chain Guide Replacement -- Lower
J0784     Guide, Timing Chain -- Replace
J0785     Guides, Timing Chain -- Replace
J0786     Primary Timing Chain Guide Replacement -- Upper
J0787     Tensioner and/or Shoe, Timing Chain -- Replace
J0788     Tensioner, Secondary Timing Chain - Right Bank -- Replace
J0789     Tensioner, Secondary Timing Chain - Left Bank -- Replace
J0791     Tensioner, Timing Chain -- Replace
J0792     Shoe, Timing Chain -- Replace
J0794     Seal, Front Crankshaft Oil -- Replace
J0795     Dust Cover and/or Gaskets, Camshaft Drive Belt -- Upper -- Replace
J0800     Belt, Camshaft Timing -- Replace
P1
J0802     Belt, Camshaft Timing -- Adjust
P1
J0808     Cover, Camshaft Drive Belt -- Front -- Replace
J0810     Pulley, Camshaft Idler -- Replace
J0815     Tensioner, Timing Belt -- Replace
J0816     Pulley, Timing Belt Idler (One or Both) -- Replace
J0818     Camshaft Position Actuator Adjuster Replacement
J0819     Housing Assembly and/or Seal, Camshaft Position Sensor -- R&R or Replace
J0820     Chain, Camshaft Timing -- Replace
J0821     Oil Filter, Camshaft Position Actuator Solenoid Valve -- Replace
J0822     Solenoid Valve, Camshaft Position Actuator -- Replace
J0823     Actuator Sprocket, Camshaft Position -- Replace
J0824     Camshaft Position Actuator Replacement
J0825     Chain, Camshaft Secondary Drive -- Right Bank -- Replace
J0826     Chain, Camshaft Secondary Drive -- Left Bank -- Replace
J0828     Tensioner and/or Guide, Camshaft Primary Chain -- Replace
J0830     Sprocket, Crankshaft Timing -- Replace
J0835     Sprocket, Camshaft Timing -- Right Bank -- Intake -- Replace
J0836     Sprocket, Camshaft Timing -- Right Bank -- Exhaust -- Replace
J0837     Sprocket, Camshaft Timing -- Left Bank -- Intake -- Replace
J0838     Sprocket, Camshaft Timing -- Left Bank -- Exhaust -- Replace
J0839     Camshaft Timing Gear/Chain Set Replacement
J0840     Sprocket, Camshaft Timing -- Replace
J0842     Housing, Timing Cover -- Replace
J0844     Idler Sprocket and/or Bearing, Timing Chain -- Replace
J0846     Bearings, Camshaft -- Replace
J0849     Gear, Injection Pump Driven -- Replace
J0850     Camshaft -- Replace
J0851     Seal, Camshaft Front Oil -- Replace
J0852     Seal, Camshaft -- One Seal -- Right Bank -- Replace
J0853     Seal, Camshaft -- One Seal -- Left Bank -- Replace
J0855     Camshaft -- Intake -- Replace
J0856     Camshaft -- Exhaust -- Replace
J0857     Camshaft -- Both -- Replace
J0858     Housing and/or Gasket, Camshaft Position Actuator -- Replace
J0859     Valve, Camshaft Position Actuator Spool -- Replace
J0861     Magnet, Camshaft Postion Actuator -- Replace
J0862     Camshaft -- Right Bank -- Intake -- Replace
J0863     Camshaft -- Right Bank -- Exhaust -- Replace
J0864     Camshaft -- Left Bank -- Intake -- Replace
J0865     Camshaft -- Left Bank -- Exhaust -- Replace
J0866     Plate and/or Gasket Assembly, Cylinder Head Opening -- Replace
J0867     Plug and/or Seal, Cam Drive Access -- Replace
J0880     Gear(s), Balance Shaft -- Replace
J0885     Shaft, Intermediate -- Replace
J0890     Shaft and Bearing, Balance -- R&R or Replace
J0900     Cap, Oil Filler -- Replace
J0910     Breather, Crankcase Ventilation -- Replace
J0920     Oil Level Indicator Replacement
J0930     Tube, Oil Level Indicator -- Replace
J0932     Tube, Engine Oil Filler Rear -- Replace
J0933     Engine Oil Cooler Replacement
J0934     Pipe, Oil Intake -- Replace
J0935     Engine Oil Cooler Hose Replacement
J0944     Cap and/or Seal, Oil Filter -- Replace
J0960     Adapter and/or Gasket, Oil Filter -- Replace
J0964     Oil Filter Adapter and Oil Cooler Assembly Replacement
J0970     Valve, Oil Filter By-Pass -- Replace
J0971     Oil Pressure Relief Valve Replacement
J0973     Valve, Valve Lifter Oil Solenoid -- Replace
J0974     Module, Engine Oil Flow Control -- Replace
J0975     Switch, Engine Oil Flow Control -- Replace
J0982     Valve, Oil Pressure Relief -- Replace
J0986     Oil Tank Replacement
J0987     Oil Tank Outlet Hose Replacement
J0990     Plug and/or Gasket, Oil Pan Drain -- Replace
J1000     Pan and/or Gasket, Oil -- Replace
J1005     Baffle, Oil Pan -- Replace
J1008     Deflector, Oil Wheel -- Replace
J1010     Crankcase and/or Gasket -- Replace
J1011     Lower Crankcase Replacement
J1018     Gear, Oil Pump Drive -- R&R or Replace
J1020     Pump, Engine Oil -- Replace
J1040     Pump Cover and/or Gears, Oil -- Recondition or Replace
J1050     Drive, Oil Pump -- Replace
J1055     Cap and/or Seal, Oil Pump Drive -- Replace
J1057     Manifold and/or Gasket, Engine Oil -- Replace
J1059     Oil Pump, Screen, and Crankshaft Oil Deflector Replacement
J1060     Tube/Screen and/or Gasket, Oil Pickup -- Replace
J1080     Housing and/or Gasket, Rear Main Seal -- Replace
J1081     Crankshaft Rear Oil Seal Housing Replacement
J1085     Shaft Assemblies, Balance -- Replace
J1086     Bearings, Balance Shaft -- Replace
J1087     Drive Chain, Balance Shaft -- Replace
J1088     Tensioner, Balance Shaft -- Replace
J1089     Drive Sprocket, Balance Shaft -- Replace
J1090     Driven Sprocket, Balance Shaft -- Replace
J1093     Chain Guide, Balance Shaft -- Replace
J1120     Seal, Crankshaft Rear Main -- Replace
J1150     Bearing, Crankshaft Main -- One Bearing -- Replace
J1180     Bearing, Connecting Rod -- One Bearing -- Replace
J1190     Seal, Lower Crankcase -- Replace
J1195     Scraper, Crankshaft Oil -- Replace
J1200     Crankshaft -- Replace
J1300     Piston, Rod and/or Rings -- One Cyl -- Right Bank -- Replace
J1301     Piston, Rod and/or Rings -- One Cyl -- Left Bank -- Replace
J1307     Piston, Rod and/or Rings -- One Cyl -- Both Banks -- Replace
J1308     Piston, Rod and/or Rings -- One Cyl -- Replace
J1335     Sleeve, Cylinder Liner -- Replace
J1400     Flywheel (Automatic Transmission/Transaxle) -- Replace
J1420     Flywheel (Manual Transmission/Transaxle) -- Replace
J1440     Cover, Flywheel -- Replace
J1460     Housing, Flywheel -- Replace
J1500     Mount, Engine -- Front -- Right -- Replace
J1501     Mount, Engine -- Front -- Left -- Replace
J1502     Mount, Engine -- Front -- Replace
J1505     Engine Mount Replacement
J1506     Mount, Engine -- Front of Engine -- Replace
J1507     Mount, Engine -- Front - Both -- Replace
J1508     Engine Mount Replacement -- Right Side
J1509     Engine Mount Replacement -- Left Side
J1510     Mount, Engine -- Rear - Right -- Replace
J1511     Mount, Engine -- Rear - Left -- Replace
J1515     Engine Rear Mount Replacement
J1516     Mount, Engine -- Rear - Center -- Replace
J1517     Mount, Engine -- Rear - Both -- Replace
J1520     Strut, Engine Mounting -- Replace
J1540     Bracket, Engine Torque Strut -- Right -- Replace
J1541     Bracket, Engine Torque Strut -- Left -- Replace
J1600     Plug, Expansion -- Replace
J1640     Plug, Oil Gallery -- Replace
J1660     Plug or Cover and/or Gasket, Camshaft Rear Bearing -- Replace
J1800     Block, Engine Fitted -- Replace
J1810     Block, Engine Cylinder -- Replace
J1820     Engine, Partial -- Replace
J1840     Engine, Universal -- Replace
J1880     Engine Assembly -- Replace
Labor Operations J3000 -- J9999 J3128     Cover and/or Gasket, Oil Pan -- Replace
J3470     Cover and/or Gaskets, Coolant Pump -- Replace
J3475     Housing and/or Gasket, Coolant Pump -- Replace
J3480     Pump and/or Gasket, Coolant -- Replace
J3500     Thermostat, Outlet and/or Gasket -- Replace
J3508     Exhaust Gas Recirculation Cooling Pipe Replacement -- Upper
J3509     Exhaust Gas Recirculation Cooling Pipe Replacement -- Lower
J3512     Oil Pump Screen Replacement
J3514     Engine Coolant Air Bleed Pipe Replacement
J3519     Engine Coolant Thermostat Lower Housing Replacement
J3529     Engine Coolant Crossover Pipe Replacement
J3532     Plug, Water Jacket -- Right -- Replace
J3533     Plug, Water Jacket -- Left -- Replace
J3580     Pump, Electric Auxiliary Coolant -- Replace
J4353     Interrupter, Camshaft -- Replace
J4356     Ring, Crankshaft Position Sensor Reluctor -- Replace
J4620     Motor Assembly, Starter -- R&R
J4640     Starter Replacement
J5185     Regulator (Limiter), Fuel Pressure -- Replace
J5430     Pump and/or Gasket, Fuel -- Replace
J5467     Pump, Auxiliary Fuel Tank Transfer -- Replace
J5475     Fuel Return Hose Replacement -- Fuel Return Pipe to Fuel Injection Pump
J5476     Fuel Hose Replacement -- Fuel Injection Pump to Fuel Feed Block
J5490     Throttle Body Assembly Replacement
J5528     Camshaft Position Actuator Solenoid Valve Solenoid Replacement -- Bank 1 (Right Side) Intake
J5529     Camshaft Position Actuator Solenoid Valve Solenoid Replacement -- Bank 2 (Left Side) Intake
J5550     Injector, Sequential Central Port Fuel -- One -- Replace
J5560     Regulator and/or Gaskets, Fuel Pressure -- Replace
J5561     Fuel Pulse Dampener Replacement
J5590     Pump, Fuel (Engine Mounted) -- R&R or Replace
J5603     Fuel Pressure Sensor Replacement
J5646     Fuel Pressure Service Valve Replacement
J5650     Injector, Fuel -- Replace
J5654     Direct Fuel Injector Replacement
J5660     Rail, Fuel -- Replace
J5661     Fuel Injection Fuel Rail Crossover Tube Replacement
J5662     Fuel Injection Fuel Rail Fuel Pressure Sensor Replacement
J5663     Fuel Pressure Sensor Replacement -- Fuel Feed Pipe
J5664     Fuel Pressure Sensor Replacement -- Fuel Injection Fuel Rail
J5665     Fuel Feed Pipe Replacement
J5666     Fuel Feed Intermediate Pipe Replacement
J5688     Pipe/Duct, Turbo Outlet (to Change Air Cooler) -- Replace
J5689     Pipe/Duct, Charge Air Cooler Outlet (to Intake Manifold) -- Replace
J5690     Pipe, Inlet (Turbo to Intercooler) -- Replace
J5691     Pipe, Turbo to Intercooler Inlet (Both) -- Replace
J5694     Flexible Hose (Intercooler) (One) -- Replace
J5696     Flexible Hose (Intercooler) (Two) -- Replace
J5697     Inlet Pipe, Turbo to Charge Air Cooler (Intercooler) -- Replace
J5698     Rubber Hose, Turbo to Inlet Pipe (Intercooler) -- Replace
J5773     Charge Air Cooler Replacement
J5776     Pump Assembly, Charge Air Cooler Coolant -- Replace
J5787     Exhaust Turbocharger Inlet Pipe Adapter Replacement
J5788     Exhaust Manifold Outlet Pipe Replacement -- Right Side
J5789     Exhaust Manifold Outlet Pipe Replacement -- Left Side
J5790     Pipe, Turbocharger Outlet -- Replace
J5793     Pipe, Charge Air Cooler Inlet -- Replace
J5794     Pipe, Charge Air Cooler Outlet -- Replace
J5796     Hose, Charge Air Cooler Inlet -- Replace
J5797     Hose, Charge Air Cooler Outlet -- Replace
J5800     Actuator, Turbocharger Waste Gate -- Replace
J5805     Solenoid, Waste Gate -- Replace
J5807     Valve, Turbocharger Vane Position Solenoid -- Replace
J5812     Hose, Turbocharger to Charge Air Cooler -- One -- Replace
J5813     Hose, Turbocharger to Charge Air Cooler -- Both -- Replace
J5858     Turbocharger Assembly -- R&R
J5860     Turbocharger Assembly -- Replace
J5865     Pipe/Hose, Turbocharger Oil -- Replace
J5870     Hose and/or Pipe, Turbocharger Oil Return -- Replace
J5880     Line and/or Pipe, Turbocharger Oil Feed -- R&R or Replace
J5890     Cable, Charge Air Bypass -- Replace
J5891     Actuator, Supercharger Boost Control -- Replace
J5892     Manifold, Vacuum Source Supercharger Boost -- Replace
J5894     Solenoid, Supercharger Boost -- Replace
J5905     Gasket, Supercharger -- Replace
J5908     Supercharger Assembly -- Replace
J5928     Dampener, Fuel Injection Fuel Rail -- Replace
J5929     Rail, Common Fuel (Diesel) -- Replace
J5930     Line, Fuel Injection High Pressure (Diesel) -- Right -- R&R or Replace
J5931     Line, Fuel Injection High Pressure (Diesel) -- Left -- R&R or Replace
J5935     Line, Fuel Injection High Pressure (Diesel) -- One -- R&R or Replace
J5937     Line, Fuel Injection High Pressure (Diesel) -- All -- R&R or Replace
J5940     Nozzle and/or Seal, Fuel Injection (Diesel) -- One Nozzle -- Right -- Clean or Replace
J5941     Nozzle and/or Seal, Fuel Injection (Diesel) -- One Nozzle -- Left -- Clean or Replace
J5947     Nozzle and/or Seal, Fuel Injection (Diesel) -- All Nozzles -- Clean or Replace
J5948     Vacuum Pump Assembly Replacement
J5950     Pump, Fuel Injection (Diesel) -- R&R
J5955     Pump, Fuel Injection (Diesel) -- Replace
J5956     Connector Assembly, Fuel Return Line (Diesel) -- R&R or Replace
J5962     Gear and/or Advance Timing Mechanism, Fuel Injection Pump -- Replace
J5963     Coupling Assembly, Fuel Injection Pump Drive (Diesel) -- Replace
J6000     Valve, PCV -- Replace
J6036     Tank Assembly, Intake Manifold Tuning Valve Actuator Vacuum -- Replace
J6354     Powertrain Control Module Engine Reprogramming with SPS
J6355     Pwertrain Control Module Transmission Reprogramming wiht SPS
J6360     Powertrain Control Module Replacement
Labor Operations K0000 -- K4999               K0280    Arm, Clutch -- Replace
K0300    Shaft and/or Bushings, Clutch Fork -- Replace
K0610    Cylinder, Concentric Slave -- Replace
K0620    Cylinder, Clutch Actuator -- R&R or Replace
K0700    Bearing, Clutch Release -- Replace
K0720    Fork and/or Ball Stud, Clutch Release -- Replace
K0850    Housing, Clutch -- Replace
K2150    Plug and/or Washer, Transaxle Fluid Drain -- Replace
K2160    Seal, Transmission Extension Rear Oil -- Replace
K2162    Seal, Main Shaft Rear -- Replace
K2164    Flange, Propeller Shaft Transmission -- Replace
K2200    Gasket, Mainshaft Rear Bearing Retainer -- Replace
K2205    Retainer and/or Gasket, Front Bearing -- Replace
K2240    Cover and/or Gasket, Transmission/Transaxle Shift -- R&R or Replace
K2250    Cover and/or Gasket, Shift Detent -- Replace
K2280    Mount, Transmission/Transaxle -- Right -- Replace
K2281    Mount, Transmission/Transaxle -- Left -- Replace
K2282    Mount, Transmission/Transaxle -- Front -- Replace
K2283    Mount, Transmission/Transaxle -- Rear -- Replace
K2284    Transmission Mount Replacement
K2287    Mount, Transmission/Transaxle -- Both -- Replace
K2290    Bracket, Transmission/Transaxle Mount -- Replace
K2295    Bracket, Transaxle Strut Mount (to Cradle) -- Replace
K2400    Valve, Air Slave -- R&R or Replace
K2420    Valve, Transmission Splitter (Three Position) -- Replace
K2440    Valve, Range Control (Two Position) -- Replace
K2500    Cover and/or Gasket, Reverse Idler -- Replace
K2560    Rear Cover, Transaxle -- R&R or Replace
K2570    Hose and/or Tube, Transaxle Vent -- Replace
K2600    Case Assembly, Auto Transaxle -- Replace
K2700    Transmisson Assembly -- Recondition
K2720    Transmission/Transaxle Assembly -- Replace
K2738    Case -- R&R or Replace
K2739    Input Shaft Bearing Replacement
K2740    Transmission Fluid Pump Replacement
K2744    Cover and/or Gasket, Power Take-Off -- R&R or Replace
K2748    Gear -- 6th Speed Gear -- R&R or Replace
K2749    Gear -- 4th Speed Gear -- R&R or Replace
K2750    Gear -- Reverse Gear -- R&R or Replace
K2751    Gear --5th Speed Gear -- R&R or Replace
K2752    Gear --3rd Speed Gear -- R&R or Replace
K2753    Gear --2nd Speed Gear -- R&R or Replace
K2754    Gear --1st Speed Gear -- R&R or Replace
K2755    Synchronizers -- 1st-2nd -- R&R or Replace
K2756    Synchronizers -- 3rd-4th -- R&R or Replace
K2757    Synchronizers -- 5th-Reverse -- R&R or Replace
K2758    Shaft, Input -- R&R or Replace
K2759    Mainshaft -- R&R or Replace
K2760    Idler Assembly, Reverse -- R&R or Replace
K2761    Countershaft and/or Bearing(s) -- Countershaft -- R&R or Replace
K2762    Countershaft and/or Bearing(s) -- Countershaft Bearing(s) -- R&R or Replace
K2763    Front Housing/Sealer -- R&R or Replace
K2764    Rear Housing/Sealer -- R&R or Replace
K2765    Fork and/or Shaft, Shift -- 1st-2nd -- R&R or Replace
K2766    Fork and/or Shaft, Shift -- 3rd-4th -- R&R or Replace
K2767    Fork and/or Shaft, Shift -- 5th-Reverse -- R&R or Replace
K2768    Socket, Shift -- R&R or Replace
K2769    Tower, Shift -- R&R or Replace
K2773    Gear -- 5th & 6th Driven -- R&R or Replace
K2775    Gear -- 6th Drive -- R&R or Replace
K2778    Synchronizers -- 5th-6th -- R&R or Replace
K2780    Synchronizers -- Reverse -- R&R or Replace
K2785    Fork and/or Shaft, Shift -- 5th-6th -- R&R or Replace
K2788    Fork and/or Shaft, Shift -- Reverse -- R&R or Replace
K2789    Fork and/or Shaft, Shift -- 5th-6th and Reverse Shaft -- R&R or Replace
K2790    Shaft and/or Bearing, Counter Shaft Extension -- Replace
K2792    Plate and/or Sealant, Adapter -- Replace
K2818    Seal, Selector Shaft -- Replace
K2822    Retainer, Main Shaft Bearing -- Replace
K2823    Seal, Input Shaft -- Replace
K2824    Bracket, Shift Control Lever -- Replace
K2826    Shaft, Shift Control Lever -- Replace
K2828    Lever Assembly, Reverse Shift -- Replace
K2830    Shaft Assembly, Shift Control -- Replace
K2832    Synchronizers -- 6th -- R&R or Replace
K2834    Synchronizers -- 4th-6th -- R&R or Replace
K2836    Synchronizers -- 2nd-3rd -- R&R or Replace
K2932    Fork, Shift -- 1st-Reverse -- R&R or Replace
K2934    Fork, Shift -- 2nd-3rd -- R&R or Replace
K2936    Fork, Shift -- 4th-5th -- R&R or Replace
K2938    Fork, Shift -- 6th -- R&R or Replace
K3010    Seals, Axle (Transaxle) -- Right -- Replace
K3011    Seals, Axle (Transaxle) -- Left -- Replace
K3012    Front Wheel Drive Shaft Seal Replacement
K3017    Seals, Axle (Transaxle) -- Both -- Replace
K3120    Transaxle Assembly -- Replace
K3130    Differential Assembly -- R&R or Replace
K3131    Bearings, Differential Gear Assembly Side -- R&R or Replace
K3132    Ring Gear, Differential Gear Assembly -- R&R or Replace
K3133    Pinion and Side Gears, Differential Gear Assembly -- R&R or Replace
K3134    Speedometer Gear, Differential Case Assembly -- R&R or Replace
K3135    Case, Differential -- R&R or Replace
K3137    Shaft and/or Gears, Intermediate -- Shaft -- Replace
K3138    Shaft and/or Gears, Intermediate -- 1st Gear -- Replace
K3139    Shaft and/or Gears, Intermediate -- 2nd Gear -- Replace
K3140    Shaft and/or Gears, Input -- 5th Gear -- R&R or Replace
K3141    Shaft and/or Gears, Input -- 4th Gear -- R&R or Replace
K3142    Shaft and/or Gears, Input -- 3rd Gear -- R&R or Replace
K3145    Shaft and/or Gears, Input -- Input Shaft -- R&R or Replace
K3146    Shaft and/or Gears, Input Cluster -- R&R or Replace
K3150    Shaft and/or Gears, Output - 5th Gear -- R&R or Replace
K3151    Shaft and/or Gears, Output - 4th Gear -- R&R or Replace
K3152    Shaft and/or Gears, Output - 3rd Gear -- R&R or Replace
K3153    Shaft and/or Gears, Output - 2nd Gear -- R&R or Replace
K3154    Shaft and/or Gears, Output - 1st Gear -- R&R or Replace
K3155    Shaft and/or Gears, Output -- Output Shaft -- R&R or Replace
K3157    Shaft and/or Gears, Output -- Reverse -- R&R or Replace
K3158    Housing, Bearing Plate -- Replace
K3160    Synchronizers -- 5th -- R&R or Replace
K3161    Synchronizers -- 3rd-4th -- R&R or Replace
K3162    Synchronizers -- 1st-2nd -- R&R or Replace
K3165    Idler Assembly, Reverse -- R&R or Replace
K3170    Clutch or Differential Housing -- R&R or Replace
K3175    Bearing/Sleeve Assembly, Input Shaft -- R&R or Replace
K3176    Bearing, Input Shaft Roller (Quill) -- Replace
K3178    Bearing/Sleeve Assembly, Output Shaft -- R&R or Replace
K3179    Bearing, Output Shaft Roller -- Replace
K3180    Transaxle Case -- R&R or Replace
K3185    Fork and/or Shaft, Shift -- 1st-2nd -- R&R or Replace
K3186    Fork and/or Shaft, Shift -- 3rd-4th -- R&R or Replace
K3187    Fork and/or Shaft, Shift -- 5th -- R&R or Replace
K3189    Fork and/or Shaft, Shift -- Reverse Enable -- R&R or Replace
K4121    Transfer Case Module Reprogramming wth SPS
K4122    Module, Transfer Case Shift -- Replace
K4126    Actuator Assembly, Transfer Case -- Replace
K4129    Transfer Case Two/Four Wheel Drive Actuator Replacement
K4160    Seal, Transfer Case -- Replace
K4162    Seal, Transfer Case Front Output Shaft -- Replace
K4163    Seal, Transfer Case Rear Output Shaft -- Replace
K4164    Seal, Transfer Case Input Shaft -- Replace
K4165    Input Shaft Seal Replacement -- Right
K4166    Input Shaft Seal Replacement -- Left
K4175    Front Output Shaft Front Bearing Replacement
K4176    Input Shaft Bearing Replacement
K4177    Rear Output Shaft Rear Bearing Replacement
K4182    Gasket, Transfer Case Bearing Retainer -- Front Output Shaft (Front) -- Replace
K4183    Gasket, Transfer Case Bearing Retainer -- Front Output Shaft (Rear) -- Replace
K4188    Shaft, Transfer Case Output -- Replace
K4250    Gasket, Transfer Case to Adapter -- Replace
K4260    Gasket or Sealer, Transfer Case Rear Output Shaft Housing -- Replace
K4265    Bushing, Transfer Case Output -- Replace
K4280    Housing, Rear Output Shaft -- Replace
K4290    Plug, Transfer Case Drain -- Replace
K4291    Plug, Transfer Case Fill -- Replace
K4400    Transfer Case Assembly -- R&R
K4410    Transfer Case Assembly -- Replace
Labor Operations K5000 -- K9999               K5125    Actuator, Automatic Transmission Shift Lock Control -- Replace
K5126    Actuator, Automatic Transmission Shift Lock Control -- Adjust
K5140    Seal, Shift Lever -- Replace
K5364    Transmission Control Module Transmission Reprogramming with SPS
K5365    Module, Transmission Control -- Replace
K6130    Indicator, Transmission/Transaxle Oil Level (Dipstick) -- Replace
K6140    Tube and/or Seal, Transmission/Transaxle Filler -- Replace
K6150    Plug and/or Seal, Transmssion/Transaxle Fluid Drain -- Replace
K6263    Flange, Propeller Shaft Drive -- Replace
K6280    Cover and/or Gasket, Power Take-Off -- Replace
K6295    Transmisson Converter Cover Replacement
K6300    Bolts, Converter to Flywheel -- Replace
K6311    Sensor Assembly, Speed Input -- Replace
K6350    Switch, Automatic Transmission Manual Shift Shaft Position -- Replace
K6351    Switch Assembly, Auto Trans Fluid Pressure -- Replace
K6353    Solenoid, Pressure Control -- Replace
K6360    Seal, Extension Housing Rear -- Replace
K6361    Output Shaft Bearing Replacement -- Case
K6362    Bearing, Extension Housing -- Replace
K6364    Sensor, Input/Output Speed -- Replace
K6365    Flange, Transmission Companion -- Replace
K6367    Plug, Transmission Sealed -- Replace
K6370    Seal, Transmission Rear Oil -- Replace
K6388    Rear Case Replacement
K6390    Housing and/or Housing to Case O-Ring Seal or Gasket, Extension -- Replace
K6391    Scavenger Pipe and/or Seal -- Replace
K6395    Differential Carrier and Differential Final Assembly -- R&R or Replace
K6396    Final Drive Sun Gear -- R&R or Replace
K6397    Parking Gear -- R&R or Replace
K6398    Final Drive Sun Gear Shaft -- R&R or Replace
K6399    Gear, Final Drive Internal -- R&R or Replace
K6425    4th Servo -- R&R or Replace
K6431    Governor Assembly -- Replace
K6485    Timing Solenoid -- Replace
K6486    Lock-Up Solenoid -- Replace
K6491    Clutch, Sprag -- Replace
K6500    Pan and/or Gasket, Transmisison/Transaxle Oil -- Replace
K6501    Shaft Manual -- Replace
K6502    Lever, Detent -- Replace
K6503    Rod, Park Actuator -- Replace
K6504    Screens and/or Seals, Scavenger -- Replace
K6506    Accumulator, 1-2 -- R&R or Replace
K6507    Accumulator Assembly, 1-2, 2-3 -- R&R or Replace
K6508    Servo Assembly, Manual 2-1 -- R&R or Replace
K6509    Tube Assembly or Seals, Oil Feed -- Replace
K6511    Servo, Intermediate/4th -- R&R or Replace
K6512    Servo, Low/Reverse -- R&R or Replace
K6514    Valve, Oil Level Control -- Replace
K6519    Cover, Side or Seals -- Replace
K6520    Solenoid, Check Ball and Wiring Assembly -- Replace
K6523    Solenoids, A/B Shift -- Replace
K6528    Solenoid/Valve, 3-4, 4-5 Shift Control -- Replace
K6529    Seal, Manual Shaft -- Replace
K6533    Solenoid, Transmission Kickdown Shfit -- Replace
K6534    Switch and/or Seal, 3rd Clutch Pressure -- Replace
K6535    Switch and/or Seal, 4th Clutch Pressure -- Replace
K6536    Accumulator, Forward -- R&R or Replace
K6538    Manifold and/or Gasket, Clutch Pressure Control Solenoid -- Replace
K6539    Automatic Transmission Electrical Connector Passage Sleeve Replacement
K6540    Cover and/or Gasket, Valve Body -- Replace
K6543    Pump Assembly, Transaxle Oil -- R&R or Replace
K6550    Valve, Pressure Regulator -- Replace
K6552    Valve Assembly, TCC Apply -- R&R or Replace
K6554    Wiring Harness and/or Solenoid -- Harness Assembly -- Replace
K6555    Wiring Harness and/or Solenoid -- 1-2 Shift Solenoid -- Replace
K6556    Wiring Harness and/or Solenoid -- 2-3 Shift Solenoid -- Replace
K6557    Wiring Harness and/or Solenoid -- TCC PWM Solenoid -- Replace
K6558    Wiring Harness and/or Solenoid -- (On/Off) Solenoid -- Replace
K6559    Solenoid, 3-2 Control -- Replace
K6560    Valve Body, Transmission/Transaxle -- R&R or Replace
K6561    Accumulator, 3-4 -- R&R or Replace
K6562    Control Solenoid Valve and Transmission Control Module Assembly Replacement
K6564    Control Valve Body Replacement
K6567    Wiring Harness ans/or Solenoid, Torque Converter Clutch Solenoid -- Replace
K6569    Solenoid, 1-2, 3-4 Shift -- Replace
K6610    Valve Assembly, Lower Control -- R&R or Replace
K6611    Spacer Plate and Gasket Assembly -- Replace
K6615    Plate, Lower Channel -- Replace
K6620    Servo Assembly, Intermediate -- R&R or Replace
K6623    Servo Assembly, Reverse -- R&R or Replace
K6624    Servo Assembly, Forward -- R&R or Replace
K6626    Servo Assembly, 1-2 -- R&R or Replace
K6630    Servo Assembly, 2-4 -- R&R or Replace
K6640    Pawl, Shaft, Rod or Spring, Parking -- Replace
K6645    Detent Spring and Roller Assembly -- Replace
K6650    Piston and/or Spring, Accumulator -- Replace
K6660    Piston and/or Spring, 1-2 Accumulator -- R&R or Replace
K6675    Accumulator, Reverse -- R&R or Replace
K6685    Servo, Front -- R&R or Replace
K6686    Servo, Rear -- R&R or Replace
K6720    Mount, Transmission/Transaxle -- Right -- Replace
K6721    Mount, Transmission/Transaxle -- Left -- Replace
K6722    Mount, Transaxle -- Front -- Replace
K6723    Mount, Transmission/Transaxle -- Rear -- Replace
K6724    Transmission Mount Replacement
K6726    Mount, Transaxle -- Center -- Replace
K6727    Mount, Tranmission/Transaxle -- Both -- Replace
K6732    Bracket, Transaxle Mount -- Replace
K6733    Bracket, Transaxle Mount -- Right -- R&R or Replace
K6734    Bracket, Transaxle Mount -- Left -- R&R or Replace
K6738    Brace, Transaxle Support -- Replace
K6900    Seal, Transaxle Shaft Oil -- Right -- Replace
K6901    Seal, Transaxle Shaft Oil -- Left -- Replace
K6902    Front Differential Carrier Seal Replacement
K6907    Seal, Transaxle Shaft Oil -- Both -- Replace
K6925    Sleeve and/or Output Stub Shaft (Right) -- Replace
K6930    Gear and/or Output Shaft Bearing, Speedometer Drive -- Replace
K6940    Shaft, Transmission/Transaxle Output -- Replace
K6941    Output Shaft Seal Replacement
K6942    Sleeve, Output Shaft (Left) -- Replace
K7000    Transmission/Transaxle Assembly -- Replace
K7011    Torque Dampener Replacement
K7012    Torque Dampener Housing Replacement
K7020    Converter Assembly, Transmission/Transaxle -- Replace
K7023    Seal, Converter Hub Lip -- Replace
K7024    Shaft Assembly,
« Last Edit: September 09, 2012, 04:57:12 PM by DeepBlueGXP, Reason: reduced read, still long though »
« Reply #136 on: September 08, 2012, 10:26:26 PM »
Do you think it may have been possible to get the Cliffnotes version of that?
« Reply #137 on: September 08, 2012, 10:29:32 PM »
I did in RED but then I just posted everything anyway.
Offline reedred
  • Turgid
« Reply #138 on: September 08, 2012, 10:39:48 PM »
The warranty information booklet that came in the packet with my 2009 manual says the 'Long-Term Emission Control System Defects Warranty' is 7 years/70,000 miles.  You get more time and miles in CA emissions states, which are CT, ME, MA, NJ, OR, PA, RI, VT, and WA (not NY- apparently we adopted the standards but not the warranty).  Specifically listed under the Air Management System subsection are the following: Charge Air Control Actuator, Charge Air Control Solenoid Valve, Charge Air Control Valve, Charge Air Cooler, and Charge Air Cooler Fan.
Good luck!
« Reply #139 on: September 08, 2012, 10:45:46 PM »
Mines an 07 GXP with GMPP major guard $0 deductable until 81K or Aug 2014 whichever comes first.
Found this on the GMPP website.
http://www.gmprotectionplan.com/majorguard.html
Component Coverage
 Covered Parts
 •It's as simple as this: If it's not on the very short list of what's not covered, it's covered!
•For years, millions of Major Guard customers have known that, "From the engine to the trunk lock, if a part breaks - even if it results from wear and tear *Wear and Tear Coverage: The applicable coverage in the event an orginal or like replacement part is unable to function in normal service. - and it's not on the list of the few items not covered, Major Guard will pay for the repair less any applicable deductible - whatever the part!"
 Non-Covered Parts
 •Sheet metal
•Body parts, panels and rails
•Bumpers
•Chassis frame
•Cross members
•Hinges
•Trim, moldings, and bright metal
•Paint
•Rust damage
•Convertible and vinyl tops
•Weather-strips
•Carpet and upholstery
 •Exhaust component and catalytic converter
•Tires
•Glass
•Lenses
•Sealed Beams
•Light Bulbs
•Batteries
•Brake drums
•Shock absorbers
•Squeaks , rattles, wind noise and odors
•Correction of air and water leaks
 Unless required in connection with a covered part we will not pay for: engine tune-up, suspension alignment, wheel balancing, filters, lubricants, engine coolant, drive belts, radiator hoses, heater and vacuum hoses, windshield wiper blades, air conditioning recharging, fluids, spark/glow plugs and wires, brake pads/linings and brake shoes/rotors, manual clutch disc, vehicle manufacturer recommended maintenance services and parts.
Every other part is covered
Not on the list of NOT covered so I guess GMPP should cover it but we'll see.  I can see them trying to say it's an Exhaust component so as not to cover.
« Last Edit: September 08, 2012, 10:56:01 PM by tazz »
« Reply #140 on: September 09, 2012, 01:32:25 AM »
Tazz,
How many miles?  If you posted already, im sorry, i missed it.
« Reply #141 on: September 09, 2012, 07:16:09 AM »
51K
I'll findout on Monday but my guess is that it has run out on the 5yr 100K part of the standard warranty since it is whichever comes first but they could decide to honor or at least have me pay a percentage.   The GMPP extended major Guard warranty should kick in but it's all going to hinge on wheather they consider the air charge cooler an exhaust component and if they do it's not covered since exhaust and or cat converter partsare not covered under GMPP major guard.  I think this may be the case because if you do a search via on GM-partsgiant the inter cooler is listed under the exhaust and fuel tab but who knows I still think I have a good shot at getting at least some if not all paid for since Ive had nothing but issues with this vehicle.
« Reply #142 on: September 09, 2012, 11:09:05 AM »
Tazz,
You're good to go. The IC will be covered under either one of the following (they will only choose one warranty to utilize)
Exhaust covered 7 years or 70 K miles (this is the one that covered Reed's IC i think)
Or
If not covered by the 7 yr 70K exhaust, then GMPP covers it.
You are good to go. If they try not to cover it, go somewhere else or just simply throw the book in their face. I don't even see a minor dispute here.
« Reply #143 on: September 09, 2012, 11:30:18 AM »
Hey SA
Told Ya
« Reply #144 on: September 09, 2012, 11:42:18 AM »
Okay, here is the deal, forget everything you have read, everything you have been told.  Go to the dealer, you either will have to pay or not.  Don't say anything about the federally mandated emissions coverage which most likely will cover you as it has others.  Just bite the bullet and pay if they ask for it.  Do not ask why it isn't covered.
« Reply #145 on: September 09, 2012, 02:27:03 PM »
Thats great advice Critter. I should have thought of that.
« Reply #146 on: September 09, 2012, 02:28:05 PM »
« Reply #147 on: September 09, 2012, 02:42:35 PM »
I talked to the asst service manager and he said it was NOT covered but he just did a quick check and they were closing so I really don't know if he actually looked it up.  As far as the 7yr 70K to my knowledge that extended warranty is only available to CA and the handful of other States mentioned if you live in another State then it reverts back to the 5yr 100K WHICHEVER COMES FIRST.   That's the way it have worked for YEARS on all my other vehicles.
I will call GMPP on Monday and ask THEM and then relay the message to the dealership.  As it is now unless I trip a code the dealer will not look at it so I have to diagnose it myself and prove to them it is the cause.  Last two issues Ive diagnosed the issue and had them replace part and guess what it fixed the problem.
Quite frankly they just don't really want to deal with me anymore since I usually tell them whats wrong and it pisses them off.  The next dealer is about 30 miles away then would be KC at 60 miles way so Im seriously thinking about taking my vehicle to KC from now on but who knows.  I don't know I really don't think any dealership unless they are a huge dealer really knows much about our vehicles and how to diagnose the isses.  Seems like there are some issues that are common but others that can vary from car to car.
« Last Edit: September 09, 2012, 04:50:50 PM by tazz »
« Reply #148 on: September 10, 2012, 10:02:02 PM »
Covered under the GMPP Major Gaurd warranty.
Not covered under CA and the 5(?) other States more Stringent emissions mandate since I do not live in one of those States.
Not covered under the Revised 7yr 70K emissions warranty for the 2009 like Reed because mine is an 2007.
Not covered under the 5yr 100K warranty for the 2007 model yr since my in service date was in early 2007 so it's past 5yrs.
The dealer tried to say that the inter cooler was part of the exhaust system since when they look it up via parts diagram it's part of the exhaust since the turbo is tied to the exhaust and the inter cooler is tied to the turbo.  Called GMPP and they said It's covered have the dealer call them for the warranty code.  Then the dealer tried to say it was a software glitch that caused the error in saying it was not covered.  Did findout though if a COVERED part breaks because of WEAR and TEAR it's covered but most items that wear out are exempt anyway so im not sure what that would really cover i guess like gears and hinges?
« Reply #149 on: September 11, 2012, 02:00:22 AM »
Well, that was easy.
