Author Topic: custom gauge pod project  (Read 31848 times)
Jebsmith
Re: custom gauge pod project
« Reply #50 on: February 10, 2011, 12:24:11 PM »
I ordered a 20 inch red fiber optic rod.  I will cut it into 3 sections. And mount it in the pod  It will collect the light from the warning lights I am covering and hopfully transmit it to the front of the new pod.
Offline cartmann32
« Reply #51 on: February 10, 2011, 04:45:18 PM »
^^^^ Perfect!
Trax Customs
If we can't do it, you don't need it
Offline IBDRINKEN
  • Donkey Master
« Reply #52 on: February 10, 2011, 06:22:27 PM »
great idea and project..
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
Jebsmith
« Reply #53 on: February 10, 2011, 06:43:08 PM »
SEE FIRST POST FOR NEW CRAP
Offline IBDRINKEN
  • Donkey Master
« Reply #54 on: February 10, 2011, 06:49:26 PM »
nice work so far. cant wait to the the final results..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Jebsmith
« Reply #55 on: February 10, 2011, 07:26:11 PM »
got fiber glass dust in my nose
Jebsmith
« Reply #56 on: February 10, 2011, 10:15:01 PM »
finished.  see op.  im pleased.  I did 100x better than i thought i would
Offline IBDRINKEN
  • Donkey Master
« Reply #57 on: February 10, 2011, 10:46:22 PM »
Great turnout...
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Offline GASNGO
« Reply #58 on: February 10, 2011, 11:13:41 PM »
Nice job Jeb! :yay:
 Jerry  :cool:
GASNGO
« Reply #59 on: February 11, 2011, 02:58:16 AM »
Looking good, now let's see the fun part, the gauge and wiring  :thumbs:
Jebsmith
« Reply #60 on: February 11, 2011, 07:27:02 AM »
Kelu, that is the easy part.  The hard part is putting the dash back together.
Offline joshmass
« Reply #61 on: February 11, 2011, 10:43:24 AM »
Great job Jeb!
« Reply #62 on: February 11, 2011, 01:53:49 PM »
Looks good, can't wait for the finished product.
Jebsmith
« Reply #63 on: February 11, 2011, 02:33:43 PM »
re sanded and bondo'd today.  Looks 1000k times better.  Waiting to get of work to primer and paint.  Now my local shop just has to become a deaer for aeroforce and I'm good to go
« Reply #64 on: February 11, 2011, 03:16:28 PM »
Great choice with aeroforce.
Some time ago I was considering too expensive $400 for two gauges.
After I did my own research now Aeroforce end up being the winner:
-Dozens of critical parameters available for every supported vehicle.  Can view 2 to 8 at a time in large, easy to read numbers without touching the gauge.
 -Record and play back data on gauge, no need for laptop or other device
 -Accepts 2 additional sensors without requiring any additional equipment.  Allows you to read such things as air/fuel ratio, EGT temps, etc. that are not on the vehicle from the factory.
 -High intensity warning lights can be programmed to indicate unsafe vehicle operating conditions.
 -Integrated shift lights.
Displays:
# RPM
# MPH
# Intake Air Temperature (post Intercooler)
# Ambient Air Temperature (pre Intercooler)
# Exhaust Gas Temperature (PCM Calculated)
# Manifold Pressure (vacuum/boost) displayed in PSI
# Battery Voltage
# Injector Pulse Width in msec.
# Injector Duty Cycle (%)
# Air Flow Rate into engine
# Long Term Fuel Trim
# Short Term Fuel Trim
# O2 Sensor Voltage
# Barometric Pressure
# Ignition Advance
# Base Spark
# PCM Spark Adjust
# Fuel Status (open/closed loop)
# Wastegate Solenoid Duty Cycle (%)
# Knock Retard
# Knock Sensor Raw Voltage
# Throttle Position Percentage
# Throttle Position Sensor Raw Volts
# Calculated Net Horsepower
# Engine Load
# Transmission Slip
# Current Transmission Gear
# Torque Delivered to Transmission
# Torque Converter lockup status
# Brake pressure
# Brake Booster Travel
# Steering Angle
# Non-driven Wheel Speed
# Lateral G's
# Yaw
# Fuel economy (instantaneous and average)
# P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
Jebsmith
« Reply #65 on: February 11, 2011, 09:17:20 PM »
Op updated with final product.  Looks factory.
Offline Dr. Gronk
  • carpe diem incoronatus
« Reply #66 on: February 12, 2011, 04:22:23 AM »
Looks awesome! Be sure to post one with it all together.
Jebsmith
« Reply #67 on: February 12, 2011, 08:33:23 AM »
Installing today.
« Reply #68 on: February 12, 2011, 09:40:29 AM »
This is the one I have mounted under the dash on the left hand side.
Maybe:
•Black Universal Dual Dash Pod
•Width: 7" Depth: 4.5" Height: 3"
•Holds two 52mm or 2 1/16th inch gauges
Might be too deep!
Jim :cool:
Offline JimVonBaden
« Reply #69 on: February 12, 2011, 11:37:56 AM »
Good to know. Thanks Norm.
Jim :cool:
Jebsmith
« Reply #70 on: February 12, 2011, 05:44:54 PM »
FINISHED!!!!!!
« Reply #71 on: February 12, 2011, 05:49:44 PM »
FINISHED!!!!!!
I have a problem with my eyes or there is no gauge?  :lol:  :poke:
I know that hardest part was to put all dash back, just teasing you  :poke:
Jebsmith
« Reply #72 on: February 12, 2011, 05:56:52 PM »
waiting on my local shop to get the gauge in stock.
« Reply #73 on: February 12, 2011, 05:57:33 PM »
Any good deals? Or regular price?
Offline GASNGO
« Reply #74 on: February 12, 2011, 06:10:45 PM »
quote author
FINISHED!!!!!!
 VERY COOL!  :yay:
 Jerry :cool:
GASNGO
