Author Topic: What would be awesome in an OBDII Option  (Read 7157 times)
Jebsmith
« on: February 13, 2011, 04:32:26 PM »
I would love a simple device that would take OBDII data and convert it to composite video for displaying on head units.  Does this exist?
Re: What would be awesome in an OBDII Option
« Reply #1 on: February 13, 2011, 04:42:36 PM »
Does the new pioneer have that ability?
« Reply #2 on: February 13, 2011, 04:49:13 PM »
you would have to take your eyes too far off the road in front of you.
« Reply #3 on: February 13, 2011, 04:59:18 PM »
Come on, Really?  Who looks at the road any more???
« Reply #4 on: February 13, 2011, 05:02:56 PM »
They were making double-din carputers that would run Windows XP/Vista that you could load HP Tuners on and Wa La, there you have it...  Only problem is, they stopped making it...
« Reply #5 on: February 13, 2011, 05:08:35 PM »
Jebs: CarPC + HP Tuners scanner ;)
Offline Graywolf
« Reply #6 on: February 13, 2011, 09:51:28 PM »
I know patrol cars use computers and it would be no problem monitoring with hp tuners.  The problem is where to mount it?  In front of the air bag ,passenger side would be a good spot if you do not mind losing safety and its probably illegal.
« Reply #7 on: February 14, 2011, 12:05:32 AM »
This was what I was considering for my car.  It was only $2500!
http://www.azentekonline.com/cms/content/view/41/146/
« Reply #8 on: February 14, 2011, 12:44:41 AM »
Did a little research and found this one and I'm seriously considering it.  I can't wait to get my Tax Free and Combat Pay that the government owes me for 14 months!
Revosys X500 Dual Core 2DIN Car PC
http://www.revo-sys.com/CarPC_Pre-built_Systems.php
Features:
•Windows 7 Home Premium (Unlicensed) Pre-Installed
•Intel® Core™ Duo Processor L2400 (15 Watt Max TDP)
•Intel945GME+ICH7M
•2MB L2 Cache, 667MHz FSB
•2GB DDR2 RAM
•Embedded SiLabs FM Tuner with RDS (Software Controlled)
•Built-in 3DSP Bluetooth 2.0+EDR
•Built-in GPS (MediaTek) Receiver
•Built-in 802.11b/g
•Built-in DVD Combo Drive
•Built-in Sierra Wireless 4G HSUPA Modem with SIM Card Slot
•7.2Mbps Download/5.6Mbps Upload Capable (GSM/GPRS/EDGE/HSDPA/HSUPA)
•WCDMA (850/1900/2100MHz) and EDGE, GSM, GPRS (850/900/1800/1900MHz)
•*Approvals: FCC, IC, CE, GCF, AT&T, A-Tick, Telestra, NTT DoCoMo, Softbank, Bell
•320GB 2.5" SATA HDD
•Intelligent Automotive Power Supply
Display:
•6.5 Inch 16:9 Wide-Screen Digital LCD Panel
•800x480 Native Resolution
•400cd/m2 Brightness
•500:1 Contrast Ratio
•10ms Response Time
•1.4mm Thick Resistive Touch Screen
Audio:
•Built-in 4x45Watt Amplifier
•Four Channel RCA Pre-amp Outputs (not independently controlled, only 2 channel stereo output)
Ports:
•(1) Mini-USB Port (Front Panel)
•(2) USB Ports (Rear Panel)
•(1) Video Output for Additional LCD Screens (Independent Content Displayed)
•(1) RCA Video Input
•(1) Backup Camera Input
Accessories:
•Supported OS: Windows 7
•12 Month Warranty
•Standard 2DIN Dimensions: 178x100x160mm
« Reply #9 on: February 15, 2011, 09:11:21 AM »
nice
« Reply #10 on: February 15, 2011, 09:18:11 AM »
Another custom options not so fancy and pricey as Revosys:
http://store.mp3car.com/Car_Computer_Systems_s/25.htm
« Reply #11 on: February 15, 2011, 10:52:01 AM »
Maybe pull the car pc stuff into a separate thread?
« Reply #12 on: February 15, 2011, 11:12:49 AM »
According to his needs, that won't work.  He's looking for a way to take OBDII data and put it on a head unit.  What you were looking at would me he would lose his stereo options and have to view it on a seperate screen...
« Reply #13 on: February 15, 2011, 11:14:26 AM »
I disagree.  It has to do with the original post.  Feel free to start another thread about car PC's if you want.
« Reply #14 on: February 15, 2011, 11:26:08 AM »
Actually, some of the options in the list that Kelu posted could work well, specifically, the ones without screens. (he linked to a list of search results)
My assumption is that he has a head unit with a screen on it that takes composite input that allows you to plug in a game system or something.
If you installed a car PC into the glovebox or somewhere else you can take the SVGA out and  convert to composite and plugged into his head unit. But he would not be able to control the computer from the screen.
Jeb, to answer your question, I don't think there is any device apart from a PC to do what you asked in your original post. So if you end up with doing a Car PC, I would replace the head unit and use the Car PC for all of your in flight entertainment with a touch screen, both GoNDef and Kelu's links are suitable options.
If you don't want to go with the complexity of dealing with a CarPC. Get a DashDaq, which has a seperate screen, or some aeroforce gauges to monitor your OBD parameters.
Jebsmith
« Reply #15 on: February 15, 2011, 06:28:00 PM »
I think a car PC would probably be the best.  Match that with a obd2 to usb input.  Im looking at the 1k range
« Reply #16 on: February 15, 2011, 06:35:34 PM »
Jebs check out my link, prices starts from 350$ for a mini computer and 170$ for a touch screen.
Jebsmith
« Reply #17 on: February 16, 2011, 07:43:08 AM »
Kelu, the machines on that page are either underpowered or too big for a car application imo.  I think the double din carpc will be the best option
« Reply #18 on: February 16, 2011, 09:10:44 AM »
Preassembled Black Double Din LCD Frame with 7" Lilliput 669GL-70NP/C/T-HB-RV HDMI DVI High Brightness
Our Price: $324.95
http://store.mp3car.com/Preassembled_Black_Double_Din_LCD_Frame_with_7_Li_p/mon-125.htm
Power Bundle - Mobile Car Computer System
Price starts: $584.99
http://store.mp3car.com/Power_Bundle_Mobile_Car_Computer_System_p/ccc-206.htm
Intel Motherboard & Processor DG45FC
Intel Core 2 Duo E7500 2.93 GHz Processor
2G Dual-Channel DDR2 800/667 Memory Support
ESATA Port
6 High Speed 2.0 USB Ports external
4 High Speed 2.0 USB Ports internal
Intel High Definition Audio with 7.1 surround sound
