All,
I have had some issues with the P0101 DTC. In the end, mine may have been caused by a defect in an aftermarket tune that has since been remidied (quite well actually
) In all of my research, I never saw this TSB, but stumbled across it today and thought it might help others with that gd code:
Service Bulletins - Search Results
1 Record(s) Displayed.
Report Date : February 15, 2011 at 04:25 PM
Search Type : VEHICLE
Year : 2007
Make : PONTIAC
Model : SOLSTICE GXP
Make : PONTIAC Model : SOLSTICE GXP Year : 2007
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Number : TB-PIP-4520 Date of Bulletin : NOV 01, 2008
NHTSA Item Number : 10030004
Component : ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:TURBO-CHARGER
Summary :
GENERAL MOTORS: TECH MAY ENCOUNTER A VEHICLE WITH A LOW BOOST/POWER CONDITION AND/OR DTC P0299 AND OR P0101 SETTING. THIS MAY BE THE RESULT OF A CRACKED OR BROKEN FITTING AT THE TURBOCHARGER ASSEMBLY. *PE
______________------------------------------------------------------------------------------------
That's how it ends, *pe... not sure if there is supposed to be more.
Anybody know what fitting they might be refering to? I want to check mine out when I get home to see if I can figure it out. Perhaps mine is starting to fail and only giving issues under certain conditions that no longer exist with the updated programming? Anybody had a P0299?
