This is how i installed my HID kit.....
ATTENTION!!! It is recommended that you wear gloves when installing the the bulbs so that you don't get the oils from your hands on the bulb.
1st) I attached the wire harness to the side of the fuse box underhood
2nd) I ran the longest set of wire from the hardest behind the intake manifold to the leftside of the car
3rd) After that I drilled a couple holes in both of the wheel wells and mounted the ballast mounts on each side(make sure not to push the drill to far and puncture the tires)
4th) After that was bolted and secured I put the grounding wire for the left side to the left pillar where the hood strut is mounted which also has the air bag sensor attached to it
5th) Then I went to the right side and attached the ground wire to the power steering mount
6th) Once that was connected i attached the positive wire to the battery terminal (there is a little screw on there you can connect it to)
7th) When that is done i attached the left ballast to it's mount and connected the wires to it(the wires are self explanatory of where they get connected to). Remove the stock bulbs and install the light bulb adapter then the HID bulb
(On the left side u dont have to worry about the light plug because the kit only uses one side. On mines the bulb did not fit tightly so what I did was take the rubber ring from the stock bulb and place it on top of the rubber ring around the HID rubber ring and then screwed it in....it made the fit tighter)
8th) Then repeat for the same thing for the right side. Then connect the stock light plug into the HID plug and then your set
This is what the finished setup looks like on my car
