Author Topic: RUST  (Read 8411 times)
Offline SolNut
RUST
« on: March 24, 2011, 12:48:03 PM »
Last week I installed the new Rotors that I baked the previous week.  :D
When I started to remove the OLD (<2YO, 25K miles) Rotors that have only been driven in the rain never snow or ice, I had to use PB Blaster to get them loose.  The Rust on the hub and back of the Rotor was much more that I expected.  I had to use a soft faced BFH to get them off.  :banghead:
QUESTIONS:
1. Have anyone else experienced this?  :idk:
2. What can I do to stop this from happening in the future?  :huh:
Steve
 :drive:
Re: RUST
« Reply #1 on: March 24, 2011, 12:58:22 PM »
Put a very thin coating of anti-seize compound on the interacting surfaces.
Re: RUST
« Reply #2 on: March 24, 2011, 01:41:06 PM »
I had to smash the crap out of my rotors with a rubber mallet to get them off. Pretty sure that is normal.
Re: RUST
« Reply #3 on: March 24, 2011, 02:41:51 PM »
Rust is what holds my jeep together.   Who needs bolts????
 :idk:
This is normal
Hell, when I went to rotate my tires, the centering rings on the OZ's were stuck to the rotors.
I normally need a hammer to assist as well.  Nothing to sweat about.
This does make the plated rotors DDM sells all that much nicer.
Antiseize is your friend, but even it has its limitations.
Re: RUST
« Reply #4 on: March 24, 2011, 02:46:03 PM »
WHY:  The aluminum rims are mounted to bare steel hub and rotor which makes for some seriouse galvanic corrosion.  Compound that with brake dust, it rusts or siezes together.  When trying to remove the the wheels, sometimes they feel like the won't come off.  Rotor had to be beat off too.
Solution: I coated the inside of my wheels around the hub with Lithium grease.  and painted the "top hats" of the rotors.  Everytime I rotate the wheels, I clean them and recoat.  No problems since.
« Last Edit: March 25, 2011, 07:22:44 AM by DeepBlueGXP »
Offline SolNut
Re: RUST
« Reply #5 on: March 24, 2011, 07:09:59 PM »
WOW, guess you and I are the only folks that have had this problem.  :idk:
WHY?
Steve
 :drive:
Offline duckSol
  • Onward through the fog
Re: RUST
« Reply #6 on: March 24, 2011, 07:45:14 PM »
Neh,
Last week, had to take a can of lithium spray lube to a PTO drive shaft slip ring locking latch on the 42 inch power tiller.
Offline SolNut
Re: RUST
« Reply #7 on: March 25, 2011, 07:55:14 AM »
Thanks for the tips! :yay:
Another task is in the queue.  :thumbs:
Steve
 :drive:
Re: RUST
« Reply #8 on: March 25, 2011, 08:02:27 AM »
WHY?
Steve
 :drive:
cuz not many people have changed their own rotors :)
Re: RUST
« Reply #9 on: March 25, 2011, 09:02:57 AM »
Our rotors rust badly, just take a look at the after a rain, before you drive off, and that surface rust is just from the time it has been standing.  Now add that to everyday you have own the car and the answer is a BFH
Re: RUST
« Reply #10 on: March 25, 2011, 09:15:23 AM »
Rusty rotors are as common as mice. Just was working on a friends 88 BMW 325 which had new rotors installed a year ago. Guess what? Three needed help to remove. Anything with iron in it will rust to some degree, and adding heat and dissimilar metals creates the perfect storm for corrosion.
Re: RUST
« Reply #11 on: March 25, 2011, 09:26:06 AM »
This makes me want to pull off all 4 rotors and apply some anti-seize.
Offline SolNut
Re: RUST
« Reply #12 on: March 25, 2011, 02:06:20 PM »
Got a FREE sample of this coming to try?  :idk:  http://www.corroseal.com/
Steve
 :drive:
Re: RUST
« Reply #13 on: March 25, 2011, 02:57:37 PM »
That FREE sample costs TEN DOLLARS to ship, while a QUART ships for $11.50.
Offline SolNut
Re: RUST
« Reply #14 on: March 25, 2011, 03:35:58 PM »
Actually USPS was half of the Ten $, but I want to try it before I get a large quantity.
Steve
 :drive:
Re: RUST
« Reply #15 on: March 25, 2011, 04:27:27 PM »
There are a number of similar products out there, such as Eastwood's Rust Encapsulator.  They're all basically Naval Jelly (phosphoric acid) + a primer.  Be interesting to see how it holds up on rotors though - let us know.
Offline SolNut
Re: RUST
« Reply #16 on: March 25, 2011, 06:24:12 PM »
I already have phosphoric acid, but I'll give this new stuff a try.
Steve
 :drive:
Offline spider
Re: RUST
« Reply #17 on: March 25, 2011, 07:00:24 PM »
A light smear of antiseize as pos vette said will do the trick. Phosphoric acid works best if followed with a light film of oil. Like seasoning an iron skillet.
Re: RUST
« Reply #18 on: March 25, 2011, 08:41:28 PM »
Thinking about Naval Rust Inhibitor. Turns Carbon Steel Black and stops the galvanic and general corrosion. Not too sure if it would hold it up the heat though.
Would be an interesting experiment just before my brakes upgrade to seeif it would work.
Re: RUST
« Reply #19 on: March 25, 2011, 09:46:05 PM »
This would be just TOOOOOO easy !!!!!!!!!!!!!!!!!!!!!!!!!!  :lol: :rofl:
Offline G8TR
Re: RUST
« Reply #20 on: March 26, 2011, 04:07:36 PM »
 Absolutely!!!!!! :D
Re: RUST
« Reply #21 on: March 27, 2011, 10:35:41 AM »
Speaking of RUST
Swapping bumpers on the jeep turned into a nightmare.
total of 12 bolts 6 on the frame, 4 holding the winch to the winchplate. 3 of the frame ones snapped, of the winch ones snapped all 10 required heat and loads of pb blaster.
We eventually had to weld nuts onto the broken studs to extract them.   :banghead:
20 minutes turned into 3 hrs.    :gaah:
 What a Pita, and these were installed with antiseize.  Just 6 years of use
Re: RUST
« Reply #22 on: March 27, 2011, 11:44:04 AM »
That's what happens when you crawl all over rocks and mud banks.  You got to pay to play
Re: RUST
« Reply #23 on: March 27, 2011, 12:15:23 PM »
everyone keeps saying this....  why?  I think it's better to get paid to play.  That's my story and I'm sticking to it!
Re: RUST
« Reply #24 on: March 27, 2011, 01:07:37 PM »
Very few actually do Steven, very few do
