Author Topic: Idling issues after engine work  (Read 24640 times)
Offline Aspenrose
« on: April 15, 2011, 06:50:13 PM »
Saying I'm a bit ticked right now is an understatement, but looking for input.
Had the head gasket replaced, and timing cover gasket done, water pump replaced. Couple of new belts.
Picked it up, and the sob is idling at 2k. Caught a glimpse of white smoke leaving a stop, and a %$&**%#$*# banging rattle when I hit a bump. WTF?!?
Also noted that they put dino in the bloody engine.  :slap:
Now, I'm going to start consumption of mass quantities of alcohol to dull the desire to go ram one Solsti up one Service dept's hind port.
Re: Idling issues after engine work
« Reply #1 on: April 15, 2011, 07:04:45 PM »
Still smoking?  fast idle, air leak?
Offline hammy221
« Reply #2 on: April 15, 2011, 07:11:04 PM »
check engine light? any codes
Offline Aspenrose
« Reply #3 on: April 15, 2011, 07:34:35 PM »
no CELs, one thing I am going to do tomorrow, is swap the Lyndon ECM for a stock one, and yea, still smoking, less than last time I drove it, but now, it's almost undrivable, with the insane idle RPM. Now, I did note, when I stopped to put gas in it, until the gas pedal is touched when started, it idles normally. Soon as gas is applied, it's off to the races.
« Reply #4 on: April 15, 2011, 07:56:19 PM »
Since is drive by wire check the sensor inside the car by the accelerator pedal.
« Reply #5 on: April 15, 2011, 08:20:32 PM »
Also check the connections at the throttle body
Offline Aspenrose
« Reply #6 on: April 15, 2011, 08:51:31 PM »
good suggestion!! I'm figuring it has to be something under the hood, having had it all torn down...so glad I have the manuals, they've come in handy far too many times....
Offline Aspenrose
« Reply #7 on: April 16, 2011, 07:46:00 PM »
nothing done today, albiet, I did let him drive ME to work, which was interesting when it's idling like it is. Tomorrow is supposed to be warmer, and not raining/snowing...more fit conditions for playing driveway mechanic...
Offline Aspenrose
« Reply #8 on: April 17, 2011, 12:34:37 PM »
Chatted with Lyndon on the issue, his thought was they got dirt into the PCV system. I've asked him to clone himself  :thumbs:
Wind is whipping like a banshee today...how many times will I get conked on the head with the hood blowing closed...  :gaah:
« Reply #9 on: April 17, 2011, 12:51:07 PM »
maybe it's stupid...could that be a TB stuck half open?
i remember someone here having to replace the TB coz it wouldn't close all the way...
Offline Aspenrose
« Reply #10 on: April 17, 2011, 12:57:43 PM »
Good point, Arabas! (And there are no stupid ideas!)
Did a google for fast idle, and found this list of things that could cause:
Symptom: The engine idles too fast. After the engine has run long enough to be warm, the idle speed does not come down to normal. You really notice it when you come to a stop and must have to push hard on the brake pedal to keep the car from moving.
Possible causes:
If you have a carburetor, you may have a bad accelerator pump or power circuit.  Not
The Fix: Replace accelerator pump or replace carburetor.
The engine may be overheating.  Not
The Fix: Check and repair cooling system.
The fuel pressure regulator may be operating at too low a pressure.
The Fix: Check fuel pressure with a fuel pressure gauge. Replace fuel pressure regulator. (Generally not a DIY job)
The ignition timing may be set wrong.
The Fix: Adjust ignition timing.
There may be some type of ignition problem.
The Fix: Check and replace distributor cap, rotor, ignition wires and spark plugs. new plugs, rest not
There may be a fault in the computerized engine control system.
The Fix: Check engine control systems with a scan tool. Test circuits and repair or replace components as required. (Generally not a DIY job)
There may be a vacuum leak.
The Fix: Check and replace vacuum lines as required.
You have a bad idle speed control unit.
The Fix: Replace idle speed control unit.
The alternator may not be working properly.
The Fix: Replace alternator.
« Last Edit: April 17, 2011, 01:02:55 PM by Aspenrose »
« Reply #11 on: April 17, 2011, 01:23:29 PM »
AspenRose,
I hope that you have not been found by "The Gremlin".  Said Gremlin made his rounds thru Romania, San Diego, a few spots in Maryland and then disappeared for a few weeks...
If you have a second ECM or can reflash yours easily, you can eliminate that.  If you've talked with Lyndon, does that mean you have a Wester's tune?  ........  Just reread the thread.  You were going to swap back to your stock ECM.  What results did you find with that?  I also reread some of the answers / suggestions and if this were an older car, I'd bet you larger amounts of money (like $5.00) that Critterman was right.  Vacuum leak.  Easy to break a hose with all the work they did, or just not reconnect one.
In light of the fact that this is not an older car, I'm not sure I'd bet against Lyndon.... he does appear to be rather good with cars :)
The fast idle is not nearly as big a concern to me as the continued white smoke.  If you only saw it when leaving the dealership, it could be left over from all the work they did.  If it is continuing to happen, they did not do the job right or did not do it all the way.
Either way, keep us posted and good luck.  Oh, and watch your head.  A secondary prop rod will keep the headaches to a minimum.  Or, if you've got 2 people, just remove the hood all together!
« Reply #12 on: April 17, 2011, 01:55:39 PM »
Sorry to hear about your back luck with Kenny! I am sure it will be something simple that will make him all better. Amazing that the dealership did not test drive him before they. Let you have him back to make sure all is okay. I definitely would be having a discussion with them about this poor work practice. They should have caught it before you!
Offline Aspenrose
« Reply #13 on: April 17, 2011, 02:27:27 PM »
Oh they drove it, and the SW's comment was the tech said it seemed to be idling a 'bit' fast, but the SW said it's probably been tuned...dun, what a dolt! Knows not of what a tune is for, yea, let's make it scream like a banshee at stops, daring those who are game to think it's a race when the light turns  :lol:
Didn't do the ECM swap yesterday, as it rained/snowed the whole bloody day. My stealer has a habit of failing to reconnect everything properly...read: hood, battery cables...
Offline Aspenrose
« Reply #14 on: April 18, 2011, 10:42:31 AM »
After much internal debate, I've decided that my stealership owes me, so I am putting the stock ECM back in this morning and taking the screaming thing in. I think once I roll into the service building I'll let it idle for a gallon or two...  :devil:
« Reply #15 on: April 18, 2011, 10:53:22 AM »
Is it still screaming with the stock ECM in it? and did you check the connections to the throttle body?  Good luck with the stealer, keep us in the loop please.
Offline Aspenrose
« Reply #16 on: April 18, 2011, 02:03:32 PM »
As we (Kathy and I both tried to get my ECM out, in vain) were under the hood, I checked, and every hose  line etc was connected.
So,  when I dropped it off, I told them "IF they think the high idle is somehow (incorrectly, under my breath) connected to the tuned ECM, then they may swap the tuned with the stock...the stock one is in the bag on the pass seat.  However, it idled normally before the work was done, and it was driven by one of the techs before the work was done."
So now I wait....but I'll let y'all know what they come up with.....
« Reply #17 on: April 18, 2011, 02:08:34 PM »
Good Luck.
« Reply #18 on: April 18, 2011, 02:13:22 PM »
What stopped you the wires or the clip holding it in?
Offline Aspenrose
« Reply #19 on: April 18, 2011, 04:10:35 PM »
Couldn't get the clip to release.
UPDATE:
   They have no clue what they screwed up, they've called in GM Technical assistance.
I *knew*  I should not take it back to them, owe me or not. This is beyond my comprehension that such incompetent techs can keep their jobs. I know that if every time I fixed  a server issue, I created a new problem, I'd be looking for a new job.
Needless to say, they've screwed up the last of my vehicles, time to shop farther afield for a decent place to have it serviced.
« Reply #20 on: April 18, 2011, 04:24:50 PM »
wow, what a PITA they are.  Sorry you're having so many issues.
« Reply #21 on: April 18, 2011, 04:27:45 PM »
That sucks.   I agree with you.  I could only imagine how fast I'd be in the unemployment line if I did my job like that.
"What do you mean you lost all of the company data?"
Well, it was supposed to be on the backup tape, but we didn't put the tapes in all last month
WHAT?????
Here's to GM Tech getting you fixed.  Hang in there.
Offline DaveOC
  • Running Wisconsin
« Reply #22 on: April 18, 2011, 07:58:26 PM »
UPDATE:
Please ignore the following attempt at a humorous comment (4/21/11):
What is it they say about doing something the same way and expecting the results to be different?
 :slap:  :sorry:
« Last Edit: April 21, 2011, 05:47:15 PM by DaveOC »
Aggressive #000741
Offline Aspenrose
« Reply #23 on: April 18, 2011, 11:13:02 PM »
Oh, and it is indeed still smoking, Kathy witnessed the small cumulus cloud this morning...
Please let tomorrow bring news...rather than the BSl I got today!
 :idk:
Offline MomsSol
« Reply #24 on: April 19, 2011, 08:37:29 AM »
As I told Melanie last night .... it may come to the point where I have to call one of two phone numbers on my cell phone.  I have done this twice before - a direct call to GM Headquarters personnel - and each time things were taken care, much to the chagrin of at least one dealership.
True Lady Gearhead :)
