Author Topic: Help adding a fuse circuit  (Read 2176 times)
DarkSlySol
« on: April 22, 2011, 05:49:47 AM »
I recently put fog lights in my grills which I love but the only thing is that seem to keep forgetting that they are on when I leave. Does anyone know which fuse slot under the hood or in the car I can a a circuit to that only hot when the ignition is on?
Re: Help adding a fuse circuit
« Reply #1 on: April 25, 2011, 01:33:10 PM »
If you look at your fuse block under the hood, 53/54 are for the fog lights.
« Reply #2 on: April 25, 2011, 02:41:21 PM »
Be careful with the load if these are not stock lamps. If these draw more than stock lamps, you may want to put a relay into the circuit.
DarkSlySol
« Reply #3 on: April 27, 2011, 08:00:11 AM »
I added it to the fog fuse already but hte problem is that its constant hot from the fuse, and Ive had to get my car jumped too many times thats why i need to find a circuit that only gets power when the ignition is on :(
« Reply #4 on: April 27, 2011, 10:11:38 AM »
Since you have a switch inside, Fuse 18 and 22 in the fuse panel in the passenger footwell are ACC switched.  off with the key out.  Tap in there for your power source.
