Author Topic: New Member: Opel GT from germany  (Read 14026 times)
Yps
« on: April 22, 2011, 12:43:26 PM »
Hey all,
i wanted to introduce myself before starting to ask many funny questions regarding my project.  :D
I'm from south germany - close to Stuttgart - and got an Opel GT in 2008. I saw the car and fall in Love with it within a sec.  :)
I'm pretty active in the Opel-GT-Forum and maybe some of the greek fellas in here might know me from there.
So far i made some mods to the car:
  • KW V3 suspension
  • ATS X-Treme rims 9x20
  • Magnaflow exhaust
  • K-Sport 356mm brakes on front, 330mm on rear
  • EDS intercooler
  • EDS software tune to 335 hp
  • some more mods which i already forgot
Now i wanted to take the next step and make some more serious modifications for more horse power.  :devil:
I found this forum and read a while and must really say:  :urock:
Haven't found anything like this in the www with so much profound knowledge and excellent ideas!
Looking forward to learn more and hopefully sooner or later also to be able to help.
Tom
Offline Kuprito
Re: New Member: Opel GT from germany
« Reply #1 on: April 22, 2011, 12:49:38 PM »
Willkommen!!!
Can you explain your rear brake set up? Do you keep the handbrake cable?
I am messed with a pair of front boxster calipers to fit on the rear axle with the stock front rotors.
Solo + Magnaflow 3" exhaust
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Custom Backbone (1/2")
Yps
« Reply #2 on: April 22, 2011, 01:04:45 PM »
Hey Kuprito,
i got no pics of it but one of the GT Forum members made some good ones.
Take a look at: "Eurospeeds HT-car site"
scroll down or find the text: "Umbau Bremse hinten"
As you will see the cable is still in use and it pulls the 2 brake pads to "block" the disc. It's not a highly sophisticated solution but it works.  :D
With the 356/330 brake conversion kit, breaking becomes a new experience :thumbs: Especially on the track it's worth every cent.
Offline Gregory
« Reply #3 on: April 22, 2011, 01:16:38 PM »
Welcome Yps! Nice mods :)
« Reply #4 on: April 22, 2011, 01:23:56 PM »
Welcome! Hope you enjoy the forum. You have some very cool mods. :thumbs:
Offline DickW
« Reply #5 on: April 22, 2011, 01:27:12 PM »
Welcome. We are a true international forum with members in at least 7 countries. Some one on this forum has done about every mad imaginable.
« Reply #6 on: April 22, 2011, 01:41:59 PM »
Welcome Yps from Germany.  I like you already as half my blood lines are German.  This is a performance oriented car forum.  Make yourself at home.  We here, enjoy all things Kappa.  Look forward to your future posts!!!  :thumbs: :drag: :brnout: :urock: :usa:
« Reply #7 on: April 22, 2011, 02:07:54 PM »
Great looking ride, welcome to the forum.
Yps
« Reply #8 on: April 22, 2011, 02:29:43 PM »
Thanks!
my plans for a 400-450 hp mod:
  • Garret manifold - ordered
  • Borg Warner EFR 6758
  • downpipe with cat - not found yet
  • SPEC stage 3+ clutch
Anything else you could recommend?
Any ideas where to get a down-pipe with the cat in order to get rid of the bottle neck as much as possible?
Thank you all!
« Reply #9 on: April 22, 2011, 02:49:20 PM »
Solo Performance has a high flow cat http://solo-performance.com/, pm spicy3480 on this forum to order. http://www.kappaperformance.com/forum/index.php?action=pm;sa=send;u=23
Offline Kagem
« Reply #10 on: April 22, 2011, 04:03:21 PM »
Welcome pal! Three opel gt's from Greece we were in Stuttgart in September 2009, stayed there 1 day and then to Nurburgring for another 2 days. The roads your country has rock, autobahn is a masterpiece! Have a good stay here, this place is a mine of knowledge!
Offline Gregory
« Reply #11 on: April 22, 2011, 05:38:31 PM »
Hey Kuprito,
Does the suspension affect the brakes? Is there a need for bigger rear breaks when the front are big? I have a brembo 4piston junior kit in front (328x28). If you consider that I need and a rear brake upgrade are there any ideas? Of course there is a need for the handbrake (sorry if I am offtopic) :sorry:
Yps
« Reply #12 on: April 22, 2011, 06:31:01 PM »
1. Does the suspension affect the brakes?
2. Is there a need for bigger rear breaks when the front are big?
3. If you consider that I need and a rear brake upgrade are there any ideas? Of course there is a need for the handbrake (sorry if I am offtopic) :sorry:
1. Wouldn't say that it affects the brake but a harder setting on the front makes handling much easier while/after hard braking.
2. In the beginning i had the bigger brake just on the front. In combination with the original rear brake dimension this felt a bit weird. Especially on track days it was a very unbalanced braking which caused that the rear was way too unstable in hard braking.
3. I'd consider a rear brake disc of app. 300mm with 4 pistons. Makes it more balanced.
Another important item are the tyres. In europe i'd recommend the Hankook's.
Offline Gregory
« Reply #13 on: April 22, 2011, 07:07:24 PM »
I use the falken fk452 and i am very happy with them! I am thinking of a two piston rear brake but are there any rear brakes for the kappa?
« Reply #14 on: April 22, 2011, 07:20:23 PM »
Welcome to the forum Yps.
Gregory.
A better set of pads in the rear would be all you need.
Unless you are doing some serious track racing or autocross.
Offline Gregory
« Reply #15 on: April 22, 2011, 07:36:26 PM »
Gregory.
This is my only everyday car. Driving it fast but that is all. I use the ebc yellow stuff plus stainless steel brakelines :)
« Reply #16 on: April 22, 2011, 07:40:35 PM »
Then a good set of tires and you are all set.
Offline Gregory
« Reply #17 on: April 22, 2011, 07:43:28 PM »
Thanks a lot LV, waiting for the brace :)
Offline G8TR
« Reply #18 on: April 22, 2011, 08:09:27 PM »
Beautiful country, but then I am prejudiced, I was born there.
Yps
« Reply #19 on: April 22, 2011, 11:56:27 PM »
Gregory.
:agree: for every day driving.
@Gregory
sorry for the misleading, I'm almost every 2 weeks on the track (Hockenheim is 15mi(25km) away from where i live). With the original brakes i had fading after 1 lap - it was impossible to have more than 1 fast lap in a row.
@all
thank you for the welcome
« Reply #20 on: April 23, 2011, 02:03:08 PM »
Welcome to the KP forum! It is nice to expand our community with more international knowledge. Looking forward to hearing about you current and future mods and track experience.
Offline cruiservic
« Reply #21 on: April 24, 2011, 02:33:42 PM »
Welcome to the group. Yes, you will enjoy the group and they are very knowledgeable and enjoy helping us with problem solving expertise. My ancestors are from Aushoffenburg (sp), Bavaria.
« Reply #22 on: April 24, 2011, 07:17:27 PM »
Welcome onboard :)
« Reply #23 on: April 25, 2011, 11:49:50 AM »
Welcome aboard Yps!
Glad to see other europeans around here  :yay:
« Reply #24 on: April 25, 2011, 08:03:50 PM »
Welcome Yps!!
