Author Topic: Lipstick's WERKS RACE custom intake manifold  (Read 20468 times)
« on: June 01, 2011, 03:05:48 PM »
I would like to thank DAVE of WERKS  for supporting my 700hp compound turbo build, by fabricating the FIRST LNF Kappa RACE custom manifold!
Thank you WERKS!!!
This is what the manifold will look like (this is for the 2.4 Kappa):
« Last Edit: June 01, 2011, 03:11:24 PM by SKY888 »
Re: Lipstick's WERKS RACE custom intake manifold
« Reply #1 on: June 01, 2011, 09:02:44 PM »
The manifold has been designed for mid-range and top end power, large turbos will need a manifold like this.  As you will see In the pictures the location of the throttle body is on the forward end of the manifold
Plenum volume is calculated at 300 cubic inches and the velocity stacked runner length is 2” diameter tubing x 5 1/8”
it can handle up to 60psi
if you guys have other questions (price, when it will be released, etc.), pls feel free to contact WERKS.
thanks!
Offline DirtyMike
« Reply #2 on: June 02, 2011, 09:05:13 AM »
sick
« Reply #3 on: February 22, 2012, 10:02:56 AM »
WERKS almost done with my port injection Race Manifold! :)
I'll just have it powdercoated once I receive the unit!
components:
WERKS custom intake manifold w/ port injection
set of 42lb RC injectors
RMR -8an fuel rail, brackets, and bungs
this system will be controlled by Split second software
and a fuel cell will be used (nitrous express SAFE system)
The DI injectors will still be used during daily driving......and the port injection will start spraying during high boost/WOT to make sure we won't run out fuel.
« Reply #4 on: February 22, 2012, 02:31:01 PM »
nice approach  about fueling :thumbs:
« Reply #5 on: February 22, 2012, 02:32:15 PM »
I'm glad that last year, you told me about the Nitrous Express SAFE system! :)
Thanks again! :)
Offline blackbirdracing
  • Kappa Newb
« Reply #6 on: February 22, 2012, 02:37:12 PM »
ah yes, the old AIC1
Been around for ever. not to mention this is the basis for the Hahn portfueler.
Let us know how easy it it to tune...
« Reply #7 on: February 22, 2012, 02:41:30 PM »
yeah I was deliberating between Mega squirt VS.  Split Second.
both of them have been around for years....and proven dependable.
And I chose Split Second....since it is more "plug and play" compared to mega squirt.
and yeah, I'll update on the tuning
Offline JoshMcMadMac
« Reply #8 on: February 22, 2012, 02:52:04 PM »
Very cool.  How are they coming up with the 60psi rating?
  • Kappa Newb
« Reply #9 on: February 22, 2012, 02:53:55 PM »
hey nothing wrong with the AIC1...
Here's a ecotec cavalier that runs pretty much a stock tune (other than timing) and an AIC1 and manifold injection
Hahn Racecraft equiped Cavalier 10.3 @ 140 mph
they probably pressure tested it to check for leaks in the welds...
« Reply #10 on: February 22, 2012, 03:00:03 PM »
yes pressure tested to 60psi.
I'll probably push my compound to 35-40psi only anyways.
and yeah A1C1 is a very cool gadget :)
that Cavalier.....is fast! :)
« Reply #11 on: February 22, 2012, 04:11:17 PM »
That is what I was figuring.  It is usually a good idea to de-rate or have a factor of safety on numbers like that.  It could (although I am sure will not) pop at 61psi, and that is before any fatigue.  I just like to know where the numbers come from and how they apply; thanks!
« Reply #12 on: February 22, 2012, 06:14:37 PM »
yup..... it's nice to have a unit that will be able to handle 35-40psi easily .....without worrying that intake manifold is about to crack/leak.
« Reply #13 on: May 25, 2012, 11:55:00 AM »
RMR fuel rail -8an
will have a bottom mount .......center feed fuel line
Werks Custom Intake manfild with Port Injectors being prepped right now for powdercoating.
it should be done by next week
« Last Edit: May 25, 2012, 01:09:09 PM by SKY888 »
« Reply #14 on: May 25, 2012, 12:59:13 PM »
awesome! I didnt really look that much, but i was curious if it was possible to squeeze the injectors under the mani. That will make for a completely stealthy install!
Did werks ever decide to make this into a kit? (injectors/rail combo) I think this would intrigue many would think about going this route if they could get a firm price on one/both items.
« Reply #15 on: May 25, 2012, 01:06:15 PM »
I'm not sure if you can put injectors underneath.  If they will even fit including the fuel rail.  Might be very tight fit.  Another vendor did it with the stock manifold....but they were only able to fit the set-up....on top .
i know that WERKS did a 2.4 manifold w/ nitrous ports but different settings.
I did a lot of customizations with this manifold to make it look like this.  I provided Dave my own stuff.   Lots of back and forth with Dave...
he was accomodating enough to help me perfect this piece to "what I want".
« Reply #16 on: May 25, 2012, 01:24:30 PM »
ah... so when you say "bottom mount" you are just referring to the rail feed rather than the rail placement on the manifold... got ya! Thanks for clarifying that.
I still am curious if you can squeeze it in underneath though.
« Reply #17 on: May 25, 2012, 01:25:45 PM »
sorry for the confusion.
yes, the fuel feed line goes underneath the fuel rail....to make it look clean.
and yes, the fuel rail will be top mount! :)
Offline ryansalazan
« Reply #18 on: September 24, 2013, 11:43:33 AM »
so do they still make this manifold anymore? Because I don't see this on their website.
  • Kappa Newb
« Reply #19 on: September 24, 2013, 02:44:08 PM »
They have a lot of fabrication ability that they don't list on there website.
In other words if you want it, they can build it.
Offline Omiotek
  • Performance Autowerks
« Reply #20 on: October 10, 2013, 11:50:17 PM »
Its something that never made it onto the website. Its not a high demand item BUT we can still do it. These will more then likely become rarities soon as we will probablly discontinue them. We have one actually on our shelf that just needs some finishing. pm me if your interested.
Do note that the drivers side intercooler pipe is not the same as stock and either a shop will have to make one for you or we wil have to make one for you.
« Reply #21 on: October 13, 2013, 08:23:10 PM »
Hmmmm maybe if it was on your site it would be a higher demand item. Just saying...
« Reply #22 on: October 14, 2013, 03:38:58 PM »
I am going to put it on the site at some point In the near future do sure, thanks.
Offline Omiotek
« Reply #23 on: October 15, 2013, 12:37:27 AM »
As Dave stated it will be going on the site. We do hope to get some more of these on cars becase they perform great. But a lot of power has been made on the stock manifold so everyone tends to think one is never needed. There is however one other plus to this manifold.... Say GOODBYE to the ugly mess on top of the stocker.
