Yes to let you know I am the MASTER at breaking a sky/ unleashing the gremlins.
Took the car out today and drove to work with no issues.
I replaced the seal (from IC pipe to BOV) that as suspect at SMMM8 and got a really good seal on it.
On the way home the car ran almost as if it had a boost leak. When I pulled in the the local advance auto the car was in limp mode.
Read codes and the car showed a P0236. I reset the code and went home. When I pulled in the drive, I popped the hood again, and saw that the BOV was WIDE OPEN at idle!
Knowing I didn't want to throw a thread up first (as GJ would have a field day), I started to plug away... cleaning sensors and poking around.
Because I played with the valve last, I started there. Pulled it all apart and this is what I found:
The preload spring was in pieces inside the back of the BOV.
Anyway I called synapse and they are sending me new springs for both the broken spring on the anti-stall piece (from a while ago) and the preload spring from the valve, free of charge
I was even able to take the largest piece of the spring, adjust the preload to max, and get the car running normally again. Took a test run and it is good to go for now.
Just wanted to give all you synapse users a heads up. However I must say its a very simple fix and Synapse was more than happy to send me free replacement parts!
