Author Topic: Stiffening your Kappa from WDYDTYKT thread  (Read 6180 times)
« on: June 14, 2011, 10:15:55 PM »
I ordered my front ZOK sway bar from DDMWorks....looking forward to putting it in at the end of the week to compliment the rear ZOK sway that was just put in at the mod meet.
What made you decide to put in the front one?
« Last Edit: June 16, 2011, 08:42:20 AM by DeepBlueGXP »
Z0K Sway Bar from WDYDTYKT thread
« Reply #1 on: June 15, 2011, 05:48:26 AM »
Kenny - since when does Spiky need a reason to install mods? :poke:
« Reply #2 on: June 15, 2011, 07:26:04 AM »
I want more control of the front of the car.  LV's brace will be going on as well. I liked the feel of your car a bit better and I know you have both.
« Reply #3 on: June 15, 2011, 07:33:36 AM »
Yay, I have one convert!
« Reply #4 on: June 15, 2011, 08:33:02 AM »
HA yes, you definitely do!  Your car was super tight...I know those tires you have on their were part of it too, but you could feel a difference in the tightness of the front of the car.
« Reply #5 on: June 15, 2011, 09:10:31 AM »
I'd like to get a front ZOK bar installed, however if I did I'd need to find something stiffer than the rear ZOK bar get the car back to nuetral. I agree the front needs less sway, yet to me the better balance created by not installing the front ZOK bar is going to be more beneficial to my driving style.
« Reply #6 on: June 15, 2011, 02:24:05 PM »
Can't you use your adjustable shocks to overcome the difference? It would be better to use springs, but that's not really an option with Konis.
« Reply #7 on: June 15, 2011, 04:42:36 PM »
That's a question for SnaponBob. I've always used the difference between front and rear sway bars to fine tune the understeer/oversteer balance in long, sweeping corners. Even on other RWD cars in Forza I almost always end up with the rear bars stiffer than the front, just makes it easier to keep your line through the corner somehow.
Offline Rogue
« Reply #8 on: June 15, 2011, 05:59:19 PM »
Adjusting the springs/shocks will affect the transient response, while the sway bars affect the sweeping/long turn response. Which you select to tune is dictated by the response change you're looking for.
Go N.A.K.3.D..
« Reply #9 on: June 15, 2011, 08:07:50 PM »
I've been taught that "fine tuning" goes in order from swaybars being the least granular, to springs, then shocks, than tire pressure to truly fine tune the car.
I don't consider Forza to be perfect, but you can try it on your car as long as you know how to put it back.
« Reply #10 on: June 15, 2011, 09:55:59 PM »
Can we get a mod to split this into a separate thread so we don't keep getting these posts lost in here?
I've always been told that you use shocks and springs to control weight transfer. In a sweeping corner the weight has already been transferred. I'm guessing I'm not getting how spring/shock adjustments could yield the same effect as changing a sway bar.
