Author Topic: Kappa engine swap with Supra's 2JZ twin-turbocharged inline-six  (Read 24745 times)
we have a thread for V8 swaps, but this is way different.
an engine swap in a Sol with the Supra's 2JZ twin-turbocharged inline-six !!!
seems interesting, hope we could learn more about this
http://carscoop.blogspot.com/2011/06/pontiac-solstice-gets-engine-transplant.html
Offline Brazen17
Re: Kappa engine swap with Supra's 2JZ twin-turbocharged inline-six
« Reply #1 on: June 18, 2011, 09:20:20 AM »
Do you know what kind of power that engine makes?
Offline 2.0 tspeed
« Reply #2 on: June 18, 2011, 09:22:10 AM »
2jz easily will make 600-1,000 hp
2013 verano turbo
Offline JoshMcMadMac
« Reply #3 on: June 18, 2011, 10:09:08 AM »
Yep, he has threads running on the "commercial" forums.
« Reply #4 on: June 18, 2011, 10:48:05 AM »
i just found the topic on the other forums....
sorry, i don't visit other forums often so i hadn't seen that.
hope we can keep this interesting swap topic running in this forum for other strange people like me who are not visiting the other kappa forums :)
« Reply #5 on: June 18, 2011, 01:01:33 PM »
he will NOT be running a twin turbo set up on this 2jz engine.
it currently has a SINGLE T-60 turbo.
it will easily get to 700hp  :)
« Reply #6 on: June 18, 2011, 05:26:30 PM »
I played with one coming back for Joe's before the meet, he had it in an older square box Corolla.  I had him up to around 60 where he finally started to get traction then he would shoot by me,  10 second car at the track.
Offline Brazen17
« Reply #7 on: June 18, 2011, 09:15:40 PM »
And I thought I had traction problems!!!
Offline Kuprito
« Reply #8 on: June 20, 2011, 08:23:56 AM »
Perfect combination
2jz + kappa
Solo + Magnaflow 3" exhaust
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Custom Backbone (1/2")
« Reply #9 on: June 20, 2011, 08:28:14 AM »
Perfect combination
2jz + kappa
2 jz + t60 turbo + kappa :)
although the 2jz block is super strong and can easily handle 800-1000hp.......it is about 200lbs heavier than a LS engine :(
so weight balance is an issue on a kappa like that.
But the owner/builder stated that he's not really concerned about the weight issue since he just wana do it.  This project hasn't been done before, so he just wana make it work....and deal with the other issues once the car is up and running.
I give this guy lots of props.......
« Reply #10 on: June 20, 2011, 08:43:35 AM »
Lots of pics and detail on the big board.
It's quite impressive.
« Reply #11 on: June 20, 2011, 09:24:26 AM »
Yeah he may need to tune the suspension a bit to make up for the weight balance, but I'd get over that with so much power :)
Offline Mihela816
« Reply #12 on: June 20, 2011, 11:48:47 AM »
This swap has got me thinking that it might be possible to swap a 1UZ-FE into the Kappa. There are bellhousing adapters.
2006 Solstice, Cool, 5MT
Werks Tune
Offline Racer_X
« Reply #13 on: June 20, 2011, 04:58:42 PM »
Why would you use a 1uz, when any LSx series bolts up without a hitch- not to mention you're not going to make are much power as an LS v8 Vs. 1/2UZ v8s. AND the LS is cheaper to find and maintain. I get using a 2JZ or an RB-26, or even a 20B 3 rotor, but- the 1UZ?
2008 Sly GXP (Z0K) Custom Tune, Dejon Precision 5557B Kit, Wiseco/ARP/K1 Built Bottom End, AEM Meth Injection, SPEC Stage III Clutch, DDMworks Backbone, Kappasphere ReBar, DDM Crossbrace, Custom Front Splitter, HKS SSQV, NORMS ZR-1 fenders, Cobalt SS BBK.
414rwhp/ 436tq @ 26.5psi
Offline Mihela816
« Reply #14 on: June 20, 2011, 05:46:14 PM »
Why not? Have you seen and heard videos of those things with ITB setups? Rev to 7000 RPM in less than 1/2 second. There are adapters to bolt it to a R154 and therefore by extension the AR-5. There are also adapters to TR6060. If the 2jz bolds into the stock mount locations then  the LS400 mounts will also bolt in.
Werks Tune
Offline pantherqs
« Reply #15 on: June 22, 2011, 02:03:12 PM »
o... sup ^_^
« Reply #16 on: June 22, 2011, 02:09:00 PM »
welcome back ;)
Offline pantherqs
« Reply #17 on: June 22, 2011, 02:18:49 PM »
hayyyyyyy budddyyyyy... still nitrousing ?
« Reply #18 on: June 22, 2011, 02:32:48 PM »
waiting for EFRing :))
Offline Racer_X
« Reply #19 on: June 22, 2011, 03:17:54 PM »
Are you kidding? Had a supercharged LS430- I know that 1/2UZ inside and out and you won't make more power than an LS, and the ITB's cost more than the motor and an aftermarket ECU with harness. Not to mention, you'd still have to build the 1/2UZ to handle the ITBs- bottomline it's ur money if you wanna blow it like that, you most certainly may.
Offline frictionfighter
  • Squirrel!
    • Friction Fighters
« Reply #20 on: June 22, 2011, 03:22:27 PM »
I personally gravitate towards the LS.  There is a reason that Formula Drift is employing them so steadily.  Cheap, tons of power under the curve, and reliable.  Hard to beat...
That said, I have a huge soft spot in my heart for straight sixs.  They also generally belong in a car that came with a straight six IMO.  That is a HEAVY motor but does make diesel like torque....
Offline pantherqs
« Reply #22 on: July 04, 2011, 12:04:39 AM »
Man that sounds mean.
Offline pantherqs
« Reply #23 on: July 04, 2011, 01:33:26 AM »
http://www.justin.tv/pantherqs#/w/1423632448
live stream up... gonna be starting it with the rad and ic in a little bit...
« Reply #24 on: July 04, 2011, 02:31:50 AM »
is that yours pantherqs???
sounds sweet!!!
pls keep us updated!!!
