Author Topic: Will solo headers and hi flow cat work with DDM stage 2 supercharger?  (Read 3888 times)
Offline scotthofferphotography
    • FriendlyCarPeople
If they are long tubes then yes, if not DDM makes a long tube header and high flow cat that will work with the SQR2.
    • FriendlyCarPeople
but stage 2 doesnt require headers.
So can I still use the ones on my car?
That is correct, you can use them,  BUT.............
You have a lot more coming in the entrance, you don't want to be hmmm 'obsturcted' on the exit, in my opinion.
Offline 1KULSOL
they will definitely work ... although as Critter says  ....
But if you plan on going to stage III you will need the LT headers and hiflow cat combo from DDM .... plus an upgraded clutch ... DDM's is great!!
    • FriendlyCarPeople
I have solo headers, high flow cat, sqr2 exhaust and its a 2.4 auto.
Can I not use that setup?  I cant afford stage 3 right now. I want the wife to get used to the power anyways.. its her car.
I was gonna get the ddm stuff when I done stage 3.
You will be fine with a stage II
    • FriendlyCarPeople
Thanks.
