I have had some intermittent throttle body codes thrown over the past few times I've driven the car:
P1516 Throttle Actuator Control Module Throttle Actuator Position Performance
P2120 Accelerator Pedal Position Sensor 1 Circuit
and
P2176 Minimum Throttle Position Not Learned
The first two appeared on three occasions, the third on two of those three.
Today, I ran my DashHawk over to the screen where these things are monitored and saw that the two throttle position sensors never differ by more than 1%. One of the two accelerator pedal position sensors is 1-2% from those two (matching) readings. The second accelerator sensor, however, only reads half the value of the first. With the car off, but the DashHawk still running, I can press the accelerator pedal and the 2nd sensor reading is consistently one-half the % of the 1st. Is this normal, or is my pedal sensor going the way of all physical things?
If someone has a DashHawk (or another OBD-II monitor) and could see how their two accelerator position sensor readings perform, I would greatly appreciate it. BTW, I'm driving a 2006 NA with DDM SC, but that should not make a difference.
Thanks.
--Chemist
