Author Topic: Pillar gauge wiring  (Read 5045 times)
Offline Revrent
Pillar gauge wiring
« on: July 05, 2011, 03:23:11 AM »
I put in a DDM pillar with two gauges.  The directions call for hooking the wires to a switched and non switched wiring source.  So I went to the fuse box forward of the passenger foot well.  Well even after using the manual it appears that I hooked into the wrong spot.  I think I hooked the wires into one that the lights go off after a set time.  Would someone know  the location where to hook a switched and non switched wire's to in the fuse box?
Thanks for the info
God bless
John
Redline
Re: Pillar gauge wiring
« Reply #1 on: July 05, 2011, 03:33:53 AM »
i suppose you want them to light up whenever your lights are on? have i understood correctly?
if yes, you can hook it up on the wire that lights up the fog light button, right below the driver's air vent. that;s where i have hooked up mine
« Reply #2 on: July 05, 2011, 05:48:09 AM »
Position 18 and 22 are ignition controlled spares, use either one with a fuse tap
« Reply #3 on: July 05, 2011, 09:49:08 AM »
I went right to the ignition harness for mine
« Reply #4 on: July 05, 2011, 11:10:33 AM »
Like DBG says, you need to use either a fuse tap or an expansion fuse 'box' as I did.  This photo shows mine, the black/yellow wire with the red heatshrink end (fuse position 6) sources "always on" power.  The black/yellow wire with the blue end (fuse position 21) sources Switched/Accessory power:
Offline Revrent
« Reply #5 on: July 08, 2011, 02:05:01 AM »
How do I say thank you to everyone here who has replied.  I am ready when I get home to fix my issue.  You folks are the greatest.
God bless
John
Redline
« Reply #6 on: July 09, 2011, 01:26:01 AM »
God bless
John
Say thank you here:
http://www.kappaperformance.com/forum/index.php?action=treasury
Always glad to help!  Not that I did anything at all in this thread, but you know.. I'm here if you need anything :)
Offline River City Sol
« Reply #7 on: July 11, 2011, 12:16:46 PM »
Where did you guys buy the expansion blocks from ?
2007 Envious
Drilled & slotted Rotors
Razzi Spoiler
Solo SQR-2 Center Duals
ASAP Light Covers
Fujita CAI
B Cool Billet Grilles
Debadged
Offline Hoosier GXP
  • Hoosier GXP
« Reply #8 on: July 11, 2011, 12:42:30 PM »
Got mine here although it was for a different project.
http://www.wiringproducts.com/contents/en-us/d136.html?gclid=CLO2x53d-akCFcrDKgodFmiXZQ
« Reply #9 on: July 11, 2011, 04:53:45 PM »
Got mine from PepBoys in the electrical/fuse aisle.  Around $5-$6.
