Author Topic: What did you do to your Kappa today - Part 2  (Read 1256906 times)
« Reply #1350 on: May 31, 2012, 10:31:27 AM »
I expect a full report out upon your arrival via PM
What are you having done to your car?
JimmyBaja is picking up his rebuilt motor and having it installed.  we are then pulling my motor, and installing the one that is currently in Jimmy's car.  Deepblue is coming along to help.  My motor will be rebuilt on steroids, and later we will put it back in my car.  Current motor swallowed something and threw up oil all through the intake system.
« Reply #1351 on: May 31, 2012, 10:41:16 AM »
I think it was a sparrow or a wren.
« Reply #1352 on: May 31, 2012, 10:48:02 AM »
Awesome! Talk about utilization!
Also while you are there, go ahead and pull the block out of my car as well. Dave needs a break anyway ;)
« Reply #1353 on: May 31, 2012, 10:52:36 AM »
Bob
Can you on me a link to the post with the file?
PM sent. It's actually a few files as the update had the 3D maps and the voice files for the voice recognition as well.
« Reply #1354 on: May 31, 2012, 11:10:09 AM »
Updated the maps on my Kenwood DNX9960 headunit that we installed a few years ago at one of the mod meets. The maps are now at 2013.10. Kenwoodforums is a great place for everything Kenwood.
Does Kenwood provide free lifetime map upgrades?  If not, how much did it cost?
« Reply #1355 on: May 31, 2012, 11:44:55 AM »
The Kenwood does not have lifetime maps from what I understand. I will PM you the link to the Kenwood forums.
« Reply #1356 on: May 31, 2012, 11:51:51 AM »
Interesting, so where did all those maps come from?  Did someone basically rip it, and make it open source essentially?
« Reply #1357 on: May 31, 2012, 11:54:29 AM »
I suspect so... Certainly works well and although there is a way to put them in the firmware of the unit, if you run them from the SD card what's not to like? Remember though if you run it from the SD card, you have to rename the main map file.
« Reply #1358 on: May 31, 2012, 11:56:34 AM »
Nothing in particular, just trying to figure out the situation as, as far as I knew, these upgrade maps weren't free.  Good to know there's a source for updated maps.
Makes me slightly reconsider not getting the Alpine INA-W910, and considering Kenwood's DNX-9980.  I love lots about the Alpine, but not the nav, nor the visual aesthetics.
« Reply #1359 on: May 31, 2012, 12:01:33 PM »
I have had the Kenwood for a few years now and the fact that the maps could always be found on the 'net was a big factor in my decision at the time. I've never had too much trouble finding them.
« Reply #1360 on: May 31, 2012, 01:28:42 PM »
Could have been a GJ.
Critter since you got an appointment with the doctor does that mean your car will be done before Miller's?
Bob
That's almost a Critterism Elff.
« Reply #1361 on: May 31, 2012, 01:39:06 PM »
Wow
that was an autocorrect
PM = ON
Critter get off my keyboard!!!!!!!!!
Thanks Bob!!
Offline HAMMER DOWN
« Reply #1362 on: May 31, 2012, 05:03:28 PM »
With the plug kit, do you really need the jack?  You could just always roll the car forward or backwards a little exposing the puncture to be worked on.
IMO yes,  it's easier and safer  to repair the tire when it's off the car a long side the road.
Mike
« Reply #1363 on: May 31, 2012, 06:14:58 PM »
Gonna pull Norm's first rear fascia off tonight. Cuz I'm going Solo Saturday morning!
« Reply #1364 on: May 31, 2012, 06:30:09 PM »
Mike
If it's so dangerous at the side of the road, wouldn't you pull over to a safer location?  I mean if it's too unsafe to plug the tire at the side of the road, isn't it also too dangerous to jack up the car, get the lug nuts and wheel off, get the wheel back on, and lower the car again?  If you're going to pull over somewhere safe enough to jack up the car, wouldn't that also be a safe enough place to plug the tire?  And conversely, if it's too dangerous to plug the tire on the car at the side of the road, wouldn't it be too dangerous to jack the car up at the side of the road?
Am I missing something?
« Reply #1365 on: May 31, 2012, 06:56:13 PM »
Between my car being lower and my splash guards, in my car getting access to the hole was an issue. I had to move the car twice to even see what was wrong. Even then I couldn't see it well. I could feel it was big and after looking at the plug kits in the station, I didn't want to try it. Maybe had I been able to pull the tire where I could see it.
I've gone thru water during a run and it loosened some of the chrome off my wheels. That got caught in my brakes making a horrible noise. Luckily we nursed it to a station that had a short jack. That jack would have been nice that day!
« Reply #1366 on: May 31, 2012, 07:07:23 PM »
its a lot easier not to run over nails and bones on the shoulder
Offline HAMMER DOWN
« Reply #1367 on: May 31, 2012, 07:51:59 PM »
If it's so dangerous at the side of the road, wouldn't you pull over to a safer location? Not always a option.   I mean if it's too unsafe to plug the tire at the side of the road, Never said it was" too unsafe to plug the tire at the side of the road." I said, "IMO yes,  it's easier and safer  to repair the tire when it's off the car a long side the road." isn't it also too dangerous to jack up the car, get the lug nuts and wheel off, get the wheel back on, and lower the car again? No, time in the danger zone (time working by the car, beside the road.) is less. The repair can be done away form the car. Compared to moving & getting in and out of the car several times to fine the hole(s) in the tire. Then you have to repair it. The whole time you are working by the car. Not bad if it's the front tire. But for the rear, I for one not going to lay on the ground to plug a tire. If you're going to pull over somewhere safe enough to jack up the car, wouldn't that also be a safe enough place to plug the tire? Yes, if it's a option. And conversely, if it's too dangerous to plug the tire on the car at the side of the road, wouldn't it be too dangerous to jack the car up at the side of the road? Already answered that "?"
Am I missing something? Yes, the jack gives you many more options, then just a plug kit. And IMO it's easier, quicker & safer to fine & plug the hole(s) in the tire when the wheel is off
Mike
« Reply #1368 on: May 31, 2012, 08:56:44 PM »
If it's not an option to pull over to a safer location to try to patch the tire, then that would hold true for jacking the car up.  Think about it, you're at the side of the road, flat tire, etc.  You think, too dangerous to patch this tire here.  But it's safe enough to jack the car up?!?
If you have a flat, you can always creep the car along further to a safer place.  I've never ever had a tire leak that was so catastrophic that I couldn't at least limp it, nor many millions of drivers.  Most nail punctures are such slow leaks, people notice that they have to put air in once a month.  Most screw punctures, you can top up pressure, drive a bit, and repeat indefinitely.  Even a large irregular puncture, which are the worst, which ihawk had, and she could still limp it along.
The only time it would be that catastrophic as to force you to stop in a location so dangerous you shouldn't try to patch/jack, let's say a blow out on a highway in an urban setting with narrow shoulders with concrete barriers at the side so you can't just pull off into the grass like you can in more rural settings.  If you're gonna say it's too dangerous to work on the car at the side of the road, compared to jacking up the car?  It just doesn't make sense . . . have you used one of those patch kits before?
I've used them twice now.  Both time never taking the wheel off the car.  And they both held for tens of thousands of kms until they wore down to the depth markers without issue.  And to be honest, I probably patched each hole faster than I could have loosened each lug nut, jack up the car, remove the wheel, and reverse it all.
Anyways, what I'm trying to say is, if I thought it was too dangerous to patch a tire where I was stopped, I wouldn't jack up the car either.  What I want to clarify from you is would you actually stop and jack up the car if you thought it was too dangerous to patch it on the car in the same location?
I'm not against being prepared . . . I keep multiple sets of nitrile gloves, a small tool set mostly comprised of a quality multi-tool, hand cleaner, plastic bags, duct tape, electrical tape, zip ties, road flares, in the trunk.  Can't even tell because it's mostly tucked between the rear firewall and the drainage for the convertible top.  And in the car, I always keep a few energy bars in the glove box, and a few bottles of water behind each seat for emergencies that I cycle through every couple months (wanna keep them relatively fresh).
These days, there really is no point in keeping a spare, or a jack in the car anymore for the large majority of car owners, and manufacturers are shoving it down our throats whether we like it or not.  Maybe if I were going on a long road trip or something sure . . . let's be over prepared, bring a jack.  But for day to day urban driving, under 20km each way, which is the large majority of us, a jack is just over kill.
« Reply #1369 on: May 31, 2012, 09:00:52 PM »
OK let me repeat...It wasn't the passenger side and I didn't run over the nail!  :banghead:  Mark caught a nail before we even left Cleveland!  He called me that morning when I was getting ready to meet him and said his tire was flat at the gas station and they weren't going.  Said he caught a nail between the sidewall and tread.  He and his buddy plugged it later that day.  He drove it Monday and it seems to be holding.
I do take credit for the bone, but seeing as how it was in my driver's side rear tire, I would have had to be driving on the opposite shoulder to catch it!  Wartie can vouch for me that I never caught the left shoulder on 26!!  And you know if I had been...that would have been a really, really bad thing on that road!  :lol:
You saw the picture of the tire with the missing plasti-dip from when they took the tire off the rim.  If you look at the pic, it's definitely the driver's side.  Yeah, I need to wash the car again due to the off-roading adventure!  I'll wait until I get back from Hellinois.  It's gonna rain tomorrow anyway. ;)
Any yes...this is what happens when you don't go!  Your luck rubs off onto me when you're not around!!  :gaah:
« Last Edit: May 31, 2012, 09:11:38 PM by ihawk95 »
« Reply #1370 on: May 31, 2012, 09:07:15 PM »
So Mission Not Accomplished tonight with the rear fascia.  I could barely get my head under the rear of the car.  Once I did, I find there are almost no clips holding the valance at the bottom except for the 2 on each side.  I tried to work one loose, but didn't want to break it off as the rubber seemed brittle, so figured it was better to wait.  I couldn't see around the exhaust well enough to get to anything at the top.  Measured the fascia to make sure it will fit in the passenger's seat for the ride back from Hellinois.  This can wait until Saturday morning when the car is on jacks and I can see what's going on.
Worst case, it should be nice on Saturday and Sunday, so I can pull my usual ghetto move and ride with the top down and fascia sticking out.  Should be a fun 6 hrs back!  :lol:
Offline HAMMER DOWN
« Reply #1371 on: May 31, 2012, 09:59:41 PM »
Holy shit  man  :chill: I never said too dangerous to patch this tire here.  But it's safe enough to jack the car up?!? I said, "IMO yes,  it's easier and safer  to repair the tire when it's off the car a long side the road." I have a 120 mile around trip to work & back. Depends on where & the time the flat happens. I can be 7 mile from the next town & 14 mile to a service station, because not all small town have service station, part store and none of the are open when I drive through in the morning..
Why would I pay someone to fix my tire if I can do it myself.  And what about IMO don't you under stand. Unlike you, I respect you opinion that you think a jack is over kill. But for me it's standard equipment. For  the distant between towns, the miles & the time of day I start my drive into work.  I like to be as self reliant as much possible.
Mike
Offline reedred
  • Turgid
« Reply #1372 on: May 31, 2012, 10:23:14 PM »
Now that fleet week is over I figured the line wouldn't be so long.  Have you considered a Fast Pass system like they have for the attractions at Disneyland?  You'd have to call it something else so they don't sue you.  Fast Ass, perhaps?
« Reply #1373 on: May 31, 2012, 10:24:29 PM »
I have to say I'm really lucky I didn't completely ruin the tire.  I'm not sure how long it was flat before I got into town.  Maybe it wasn't completely, but I hear the thumping noise a few miles outside of town during the run.
And I'm very lucky it got me to the NTB 30 miles away.  I pumped it up to 35 psi, then I stopped, opened the door to peek out the back and check the tire, then started moving again.  I didn't even waste time getting out of the car.  The leak was bad enough it was hissing air and you could feel it, so I wanted to get there as quickly as possible but without risking any further damage.  I took it easy on a really twisty road.  Maybe that helped buy me time with the leak...no idea.  But it was flat as a pancake by the time I made it to the town.  Within 10 minutes it went from low to nothing.
Like I said, I wasn't comfortable trying to plug it.  It was a rear tire and not very accessible with my car being lowered.  Even with a jack.  But I can tell you a jack would have been real nice the day I picked up the chrome piece between the brake and rotor.  I got very lucky that day!  Because we were in Amish country and miles from any town!
Will I get one...maybe.  It kinda looks like it's gonna interfere with my golf clubs!  Ahh...priorities!  :lol:
« Reply #1374 on: May 31, 2012, 10:25:31 PM »
I love you Reed!!!!  Bahahahahahahahahahaha!!!
The Fast Pass was already discussed!  Did you miss that?? :D
