Author Topic: I saw a LS7 Solstice for sale on ebay  (Read 26347 times)
Offline melissadunagan
« on: August 21, 2011, 05:28:53 PM »
  Hello all of you V8 lovers, I saw the car you guys
need to by. It is on EBay,far 45,000. Over 600 Hp, being sold by the shop owner that build-ed it. Has 16,000 miles. It is silver with black and
red interior.
« Last Edit: August 21, 2011, 06:07:17 PM by DeepBlueGXP »
Ferret Lady
Re: I saw a LS7 Solstice far sell
« Reply #1 on: August 21, 2011, 06:05:16 PM »
Thanks melissadunagan!  For the right person it would be awesome.  I can't imagine an engine in excess of 600 HP but 16,000 miles is indeed low mileage.  I always kind of get an itch when someone mentions a big V8, having ounce owned a Bird.  Silver and black are "Raiders colors" but the red interior would look good with it!
« Last Edit: August 22, 2011, 05:17:12 PM by GXPinKC »
Re: I saw a LS7 Solstice for sale on ebay
« Reply #2 on: August 21, 2011, 06:54:07 PM »
except that a 900 HP Mallett sold at auction for 26K.
« Reply #3 on: August 21, 2011, 07:59:34 PM »
  What would any one do with 900 HP in a street car other than get in to trouble?
Ferret Lady
« Reply #4 on: August 21, 2011, 08:27:46 PM »
Same thing you would do with 600 - get into trouble
« Reply #5 on: August 21, 2011, 08:52:27 PM »
YAY! TROUBLE!!!
« Reply #6 on: August 21, 2011, 09:13:48 PM »
red interior.
melissadunagan, something doesn't sound quite right.  I am not very familiar with Corvette's however there is a guy that parks his victory red Z06 Corvette near where I park when working out at the Prairie Life Fitness Center here in Olathe, Kansas and today after working out I checked it out and I looked at the id on the vehicle and it stated 405 HP and I was kind of surprised cause I expected a bit more out of a Z06!
Next time I work out there I will try to notice if it's there and find out who the guy or gal is that owns it.  To be honest, our 2007 Aggressive (Victory Red) Pontiac Solstice has better lines than the Z06!  As I have stated before you see so many of them that they loose their charm.  Anyway anyone who has had the opportunity to drive one please chime in on the thread.  Next time I go to workout, I will try to look for the ZO6 again to see if I can identify the owner.
« Last Edit: August 21, 2011, 09:25:42 PM by GXPinKC »
« Reply #7 on: August 21, 2011, 09:48:21 PM »
  I am sorry GXPinKC not sure what you are asking. The car I am talking about is a Solstice with a LS7 engine in it.
   Now the top Corvette is ZR1, and it has the LS7 I think. There is also one that is supercharged. And both of these have more power that the  Z06. The Z06 is one set up from the base Corvette. Does this answer your question?
  Now I have a 96 Corvette with the LT4 and it is a very fun car to drive, love the low speed torque. And I do feel it does handle some better than my Solstice.
Now the Solstice has lots less squeaks in it.
Ferret Lady
« Reply #8 on: August 21, 2011, 10:06:04 PM »
Thanks melissadunagan, I was a bit surprised that the Z06 Corvette was only 405 HP!  I guess I expecting more out of it!  Thanks!
« Reply #9 on: August 21, 2011, 10:38:46 PM »
Z06's came with 3 different engines. Early ones had a 5.7, followed quickly by the 405HP 6 liter. The LS 7 is a 7 liter 505HP engine. I quick tune and POOF !!!!!!!!! Well north of 600hp without forced induction. THIS is a Solstice I could learn to love, but there are forty five thousand reasons while it will not happen !!!!!!!!!!!!
« Reply #10 on: August 22, 2011, 12:04:40 AM »
And just think about if you added heads and a good cam to that...:drool:
« Reply #11 on: August 22, 2011, 12:12:20 AM »
  The reason I mention seeing this car far sell is because I saw where some of you guys where talking about putting in a V8 in their car. I thought this would be a lot lest of a headache that doing this swap them seft.
Ferret Lady
« Reply #12 on: August 22, 2011, 08:15:21 AM »
In reality, adding the cost of a decent GXP, Tremec, LS7, install, harnesses and computer, etc., $45K is not too out of line.
« Reply #13 on: August 22, 2011, 09:29:18 AM »
Ok, let's set the record straight about modern Z06 here.
The C5 Z06 came only with LS6 engine (5.7l).  In 2001, the power was rated at 385 hp and in 2002-2004 model years, the power was rated at 405 hp.  A C5 always has a 5.7l V8, whether it's an LS1 (345-350 hp) or an LS6 with updates throughout the model years.  BTW, LS1 and LS6 actual displacement is 346ci.
The C6 line up is a bit more complicated.  A C6 Z06, so far, has only been given the LS7 (505 hp, 7.0l).  A base C6 in model years 2005 through 2007 has the LS2 (400 hp, 6.0l).  Model year 2008 through current has the LS3 (430-436 hp, 6.2l).  The ZR1 (C6, not to be confused with the ZR-1 which is a C4) has a supercharged LS3 dubbed the LS9 (638 hp, 6.2l SC).  The supercharged 6.2l in the current generation Cadillac CTS-V is called an LSA (556 hp, 6.2l SC) and it's considered a detuned LS9.
Recently, I looked into V8-converted Kappas and I found I could not justify it.  It cost about the same as a C6 Corvette after everything is said and done.  The power-to-weight ratio is similar to a C6 as well since the conversion adds weight and puts it right to a C6 weight.   A couple other shortcomings are the weaker differential/final drive and the fender wells of a Kappa can't take wider tires.  And if the aim is the Z06, it will be very hard to match its aluminum frame, composite body panels, and magnesium cradles/subframes.
That said, I still want a Kappa with an LS7 or LS9, I just need a lot more money to overcome my common sense.  Yes, I fully understand the saying, "more money than sense" ...
« Reply #14 on: August 22, 2011, 09:56:48 AM »
I have an 07 cammed and pumped up c6 in my driveway. Its north of the stock C6 Z06 power level
As it sits, its terrifying to stand on. I would never take of traction control. And it has the Z06 wheels (345mm tire)
A kappa will never get that power on the ground at any speed under 60. Short of tubbing the rear out and getting some huge tires on it. At that point, you will pretty much be making a custom car with a kappa body sitting on it. It would probably be cheaper and less time consuming to set kappa panels on a custom corvette frame.
Corvettes have their place, and Kappas have theirs. I am not a huge fan of trying to mix the two.
« Reply #15 on: August 22, 2011, 11:44:50 AM »
The point of the LS7 is that it already has those.  It is very close to a race motor for the street. Which is why they cost $13K!
2007 BMW Z4M coupe
Recently sold:
« Reply #16 on: August 22, 2011, 05:01:56 PM »
POS VETT, Thanks for the history, enjoyed the read.
« Reply #17 on: August 22, 2011, 05:25:06 PM »
The LS9 also has a 2.3L TVS supercharger vs. the smaller 1.9L unit found on the LSA.
« Reply #18 on: August 23, 2011, 05:57:50 AM »
With a motor that big, I am not sure why you would want forced induction, unless it was a drag car. But that is just my opinion.
« Reply #19 on: August 23, 2011, 10:41:35 AM »
Because you can?
« Reply #20 on: August 23, 2011, 10:51:30 AM »
Miller,
I just lost all respect for you.  Not that i had any to begin with.
« Reply #21 on: August 23, 2011, 08:20:48 PM »
Touche` GJ
Offline RedSkyMan
« Reply #23 on: September 30, 2011, 08:01:33 PM »
I have the LS-2 in mine and It put 368HP to the rear wheels, but with the stock Goodyear tires, It's hard to get It to hook-up to the pavement but I'm not into racing anyway. As is It is a beast :devil: of a car (hence the name) and It cost sightly less then a basic Corvette and In my opinion looks a lot better (sorry Corvette owners). Bottom line is It has more then enough power for such a light roadster, is a blast to drive and sounds awesome.  :drive:
Chili Pepper Red Sky
Ordered 3-28-06
Delivered 6-29-06
Vin# 3963
Sent to Mallett 2-21-07
Delivered 5-11-07 #007 "Beast"
LS-2 400 HP/368 RWHP
Dual Exhaust
Offline FASTER THAN MOST
« Reply #24 on: November 12, 2012, 09:32:16 PM »
beyond redline in green bay is completeing my 2010 coupe it now has a ls 2 stroked to 6.6. ls3 ported heads new. nice cam. fast intake and good headers.   ls7 clutch.we have a dino and hope to tune in a few days. also have a 95 rx7 and a gtr plus a 99 allwheel drive eclipse 440 all wheel hp to ground . i will be 76 in feb. but still like fast cars.  FASTER THAN MOST.
« Last Edit: November 12, 2012, 09:37:10 PM by FASTER THAN MOST »
