Author Topic: Electrical connections in the stereo  (Read 3891 times)
Offline RufusMacblorf
« on: August 31, 2011, 04:09:22 PM »
I bought a used Sky with a nice aftermarket stereo installed by the previous owner.  Lately some of the speakers have intermittently lost signal, often when I go over a bump in the road.  I'm guessing there are some loose or corroded connections somewhere.  I'm planning to pull apart the stereo wiring and clean the connections.
Does anyone have suggestions on how to prevent future bad contacts, like dielectric grease or something?
Offline ophidia31
Re: Electrical connections in the stereo
« Reply #1 on: August 31, 2011, 04:16:30 PM »
Soldered connections with good electrical tape or heat shrink tubing. Ive used dielectric grease on a few cars Ive worked on, but those were really only if they were door speakers with signs of previous water encounters. Can even solve those issues by just soldering straight to the speaker connections at the speaker.
2013 Grigio Abarth 500
« Reply #2 on: August 31, 2011, 07:02:19 PM »
Soldered connections are a must if you want to eliminate issues such as this.
« Reply #3 on: August 31, 2011, 08:51:47 PM »
      RufusMacblorf ;  If the previous owner used crimped connections any jolt to the harrness will give you problems . Like Sly Bob and  ophidia31 said Solder and heat shrink or a good electrical tape is a Must
« Reply #4 on: August 31, 2011, 11:15:52 PM »
Much appreciated, all.  I have plenty of solder.
