Author Topic: service parts identification tag  (Read 15946 times)
Offline bluegxp
« on: October 12, 2011, 03:10:18 PM »
What does all this indicate?
2008 GXP (stock)
Re: service parts identification tag
« Reply #1 on: October 12, 2011, 03:40:35 PM »
Not to remove it!
They are option codes and installed features like paint color, tires, wheels, ect...
Offline DaveOC
  • Running Wisconsin
« Reply #2 on: October 12, 2011, 03:42:39 PM »
This shows the RPO codes of the options installed on your car.  "G80", for instance, indicates a limited slip differential.
The 722J is the paint code, IOW "Deep" or Dark Ming Blue Metallic.   The 2MB67 is the model identifier, indicating a Solstice Convertible, not a GXP.
The GXP is identified as 2MG67.
Hmm . . .  the MF in the first part of the VIN number indicates a Solstice GXP Convertible w/ auto trans.
Leave it to GM to mess up a tag.  Trust the VIN#, it's a GXP.
« Last Edit: October 12, 2011, 03:48:11 PM by DaveOC »
Aggressive #000741
Offline bluegxp
« Reply #3 on: October 12, 2011, 03:49:09 PM »
Well, this car does have the direct fuel injected 2.0 and turbo.........
2008 GXP (stock)
Offline sirmeili
« Reply #4 on: October 12, 2011, 03:57:01 PM »
Are you sure? I just checked my '07 GXP's vin and it has MG in it instead of MF. (I also have an automatic transmission)
Offline brad_wp
« Reply #5 on: October 12, 2011, 04:35:57 PM »
My '08 Sky RL manual is 1G8MG.  From all my looking at VIN's while on my searching to find a car to buy I'm pretty sure MF should be the code for auto and MG for manual.   The 8th character is for the engine:  X for the 2.0 (RL), B for the 2.4 (base).  I'm pretty sure this is GM standard, so applies to Solstice and Sky.
If you've not seen it you can go to http://www.compnine.com/ and go to the VIN search to see what original option codes your car came with, and a description of them.
Well, after posting it appears compnine has shut down.  Anybody know of a site with similar function?
Sent from my Inspire 4G using Tapatalk.
« Last Edit: October 12, 2011, 05:18:49 PM by brad_wp »
Brad
'08 Redline Manual
Polar White, Black on Black, Single Disc Monsoon
"Fly Navy"
Offline DaveOC
  • Running Wisconsin
« Reply #6 on: October 12, 2011, 07:03:48 PM »
The 2MB67 and 2MG67 are model numbers, not a part of the VIN#
The characters in position 4 and 5 of the VIN change meaning depending on the model year.
For 2008:
MB  = Solstice/Sky Convertible with Manual Transmission
MC = Solstice/Sky Convertible w/ Auto Transmission
MF =  GXP/Redline Convertible w/ Auto Transmission
MG = GXP/Redline Convertible w/ Manual Transmission
Aggressive #000741
Offline DaveOC
  • Running Wisconsin
« Reply #7 on: October 12, 2011, 07:06:14 PM »
Well, that comes as a surprise, and no I don't know of another site that decodes VIN#s as conveniently.
Aggressive #000741
Offline bds
« Reply #8 on: October 12, 2011, 07:39:09 PM »
I remember when searching for my SKY Red Line that there was some discrepancy between the VIN and the RPO Code List.
I just attributed it to a GM inconsistency.
Here's a link to a posting by Stephen (saf0775) on the SKY Forum providing the RPO Codes:
http://www.skyroadster.com/forums/f5/rpo-codes-36984/
And here's a link to the 2008 GM Passenger Card VIN System:
http://www.mycertifiedservice.com/gmgoodwrenchjsp/gmspo/Vin/2008vincard.pdf
Hope this helps,
Brian
Offline brad_wp
« Reply #9 on: October 13, 2011, 12:25:34 AM »
I think this .pdf is the cause for confusion for some of the VIN codes, every RL manual I've seen for sale has the MG code vice the MF code.
Brad
'08 Redline Manual
"Fly Navy"
Offline bluegxp
« Reply #10 on: October 13, 2011, 10:55:04 PM »
Thanks Gents.  My 2008 GXP is blue with an auto trans & AC, and a several other options.
« Last Edit: October 13, 2011, 11:24:31 PM by bluegxp »
2008 GXP (stock)
« Reply #11 on: October 13, 2011, 11:20:59 PM »
I believe this to be  a complete list of RPOs for the 2007 Solstice.
RPO Codes - Pontiac Solstice
OptionCode / Description
A31 Windows, power
A50 Seats, front bucket
AF2 Seat adjuster, driver 2-way power
AU0 Remote Keyless Entry
AU3 Door locks, power
AZ5 Headliner, premium
B32 Floor mats, color-keyed and carpeted front
C41 Heater, outside air with fan
C60 Air conditioning, single-zone manual
D44 Mirrors, outside manual, body-color
D48 Mirrors, outside power-adjustable, body-color
D52 Spoiler, rear
DT4 Regular production accessory, Smoker's Package
FE3 Suspension, Sport
FE9 Emissions, Federal requirements
G80 Differential, limited slip rear
GT4 Rear axle, 3.73 ratio
GW1 Rear axle, 3.91 ratio
J65 Brakes, 4-wheel disc
JF5 Pedals, Sport metallic
JL4 StabiliTrak, vehicle stability enhancement system
JL9 Brakes, 4-wheel antilock
K34 Cruise control
LE5 Engine, ECOTEC 2.4L Variable Valve Timing DOHC 4-cylinder SFI
LNF Engine, Turbo ECOTEC 2.0L Variable Valve Timing DOHC 4-cylinder, aluminum
MM5 Transmission, 5-speed manual
MX0 Transmission, 5-speed automatic
N34 Steering wheel, 3-spoke leather-wrapped
N45 Steering wheel, 3-spoke urethane
N87 Wheels, 18" (45.7 cm) silver-painted aluminum
NB8 Emissions override
NC7 Emissions override, Federal
NE1 Emissions, Maine, Massachusetts, New York or Vermont state requirements
PCM Preferred Package
PCQ Premium Package
PD5 Wheels, 18" (45.7 cm) chromed aluminum
QF8 Wheels, 18" (45.7 cm) polished aluminum
QFX Tires, P245/45R18 all-season, blackwall
QSL Tires, P245/45R18-96W blackwall
R8G OnStar 1 Additional Year of Safe and Sound Service (MSRP= $199)
R8P OnStar 2 Additional Years of Safe and Sound Service (MSRP=$379)
R8U OnStar 3-Years Safe and Sound Service (MSRP=$679)
R8V OnStar 3-Years Directions and Connections Service (MSRP=$979)
R8W OnStar 1-Year Directions and Connections Service (MSRP=$100)
R8Y OnStar 2-Years Directions and Connections Service (MSRP=$399)
R8Z OnStar 3-Years Directions and Connections Service (MSRP=$679)
RFA OnStar 1-Year Business Vehicle Manager Service (MSRP=$25)
RFB OnStar 2-Years Business Vehicle Manager Service (No charge)
RFC OnStar 3-Years Business Vehicle Manager Service (No Charge)
T96 Fog lamps, front
U1C Audio system, AM/FM stereo with CD player
U2K XM Satellite Radio
U68 Driver Information Center
UE1 OnStar, 1-year of Safe and Sound plan
UK3 Steering wheel accessory controls, mounted audio, Driver Information Center and cruise controls
UQ3 Audio system feature, Monsoon premium 7-speaker system
US6 Antenna, fixed-mast
US8 Audio system, AM/FM stereo with CD player and MP3 playback
US9 Audio system, AM/FM stereo with 6-disc in-dash CD changer and MP3 playback
UW5 Audio system feature, 6-speaker system
VK3 License plate bracket, front
YF5 Emissions, California state requirements
Z0K Club Sport Package
ZQ3 Convenience Package
« Last Edit: October 14, 2011, 01:14:28 PM by Sly Bob »
Offline bluegxp
« Reply #12 on: October 13, 2011, 11:25:30 PM »
Thank Sly Bob.......I went to the link provided as well.
2008 GXP (stock)
« Reply #13 on: October 13, 2011, 11:30:06 PM »
In the attached file at the bottom of this post you will find the RPOs for the 2009 Solstice. As it's a fairly large PDF it may not open in your browser.
« Reply #14 on: October 14, 2011, 09:50:03 AM »
OK, not sure why I did this, but I did!  I OCR'd the 2009 pdf that Bob posted into a spreadsheet, then did a comparison of the 2009 RPO list, Bob's 2008(?) text list and the 2008 Sky forum Word doc list that bds linked-to.  Interesting that all of these differ and all have some codes that others don't as well as differing textual descriptions.  Not sure that it's worth anything to anyone, but I created the attached spreadsheet showing those three versions side by side and aligned so you can see the differences (also included is the full 2009 equipment list from the pdf, as a second tab).  Enjoy.
« Last Edit: October 14, 2011, 01:33:31 PM by TomatoSoup »
« Reply #15 on: October 14, 2011, 01:13:37 PM »
Thanks Mark for taking the time to do that. I believe thought that the text list that I posted was for a 2007 and I will update my post to reflect that.
« Reply #16 on: October 14, 2011, 01:35:15 PM »
OK, I updated the spreadsheet column titles accordingly and re-attached in the post above
Offline DaveOC
  • Running Wisconsin
« Reply #17 on: October 14, 2011, 04:04:53 PM »
If anyone is interested, I have the Solstice printbooks for 2007, 2008, and 2009 in PDF format, also the Sky printbook for 2009 in PDF.  They all have the RPO printouts in the rear of the document.  If you want to add to your list PM me with your email address.
Dave
Aggressive #000741
Offline bluegxp
« Reply #18 on: October 14, 2011, 04:12:02 PM »
There are some RPO codes on the tag I cannot find information on:
IP2, R9N, SLM, 1SZ, 191, and 25U.
2008 GXP (stock)
« Reply #19 on: October 14, 2011, 05:22:57 PM »
Not sure about all of those but I can tell ya' that the 25U is your paint colour, Deep (Dark Blue Metallic).
edit:  Google came through again    ;)
IP2 Trim - Interior Design (P2)
R9N - LEATHER SEAT TRIM
SLM - sales processing stock orders
1SZ Preferred Equipement
19I Interior Trim Ebony (I) (00)
That last one is 19I not 191 as far as I can tell.
« Last Edit: October 14, 2011, 06:54:27 PM by Sly Bob »
Offline bluegxp
« Reply #20 on: October 14, 2011, 10:06:05 PM »
Sly Bob....u da man! Thanks!
2008 GXP (stock)
