Author Topic: DDM s/c mpgs?  (Read 24036 times)
Offline ophidia31
DDM s/c mpgs?
« on: January 20, 2012, 12:05:41 PM »
Just curious as to what everyone with either stage one or two is getting terms of mpg wise? Slightly less, breaking even or slightly more?
Im currently kicking around power mods and dont know if id want to do a s/c or turbo. Im probably doing exhaust this year and whatever comes out of this thread would probably help alot in my decision making. Dont want to buy a header and end up swapping it out with a turbo log and losing money on a resale of the header.
Ive researched the power output from both and the pros/cons but i havent seen much about the mileage with a supercharger. The turbo I know wouldnt necessarily hurt mpgs, provided the go pedal not be to the floor all the time, as its not driven off the engine and may increase the mileage by a decent amount. But not sure with the s/c since its a smaller engine that needs every last bit that can help it and adding something to the belt system probably isnt helping it. Although, on can argue that having that added torque down low to get the car moving would help increase the mileage that way in not needing to put the pedal down so far. And this is what I want to find out.
2013 Grigio Abarth 500
Offline Jackknife
Re: DDM s/c mpgs?
« Reply #1 on: January 20, 2012, 12:52:44 PM »
With my DDM Stage II, I average 23-24 mpg....  never drop below 21, even with spirited driving.
But, of course, economy and performance are the two words that should never occur to the enthusiast's mind simultaneously.
Recessed Grills ... Debadged
DDM Pro-Beam and back brace
Solo Hi-Flo Cat
Re: DDM s/c mpgs?
« Reply #2 on: January 20, 2012, 12:53:32 PM »
With the stage 2, I was getting around 25-27 MPG hwy @ 70MPH/ and probably 23-25 city. At stage 3, I'm getting around 23-25 MPG hwy @ 70MPH/ and around 21-23 city. I get much less than that considering I am normally driving spiritedly around town. I've seen my DIC indicate as low as 4MPG when I have the pedal to the floor.
Re: DDM s/c mpgs?
« Reply #3 on: January 20, 2012, 12:57:25 PM »
It has a lot more to do with how you drive it than it does the SC or TC, or whatever.
Top Gear once ran a V8 M3 and a Prius simultaneously on their track, at a very reasonable speed (not racing, but never stopping), and over multiple laps, averaged out, the M3 was more fuel efficient.
In mixed driving, I've gotten as low as low 9 L / 100km, and a high of around 12 L / 100km, covering the same roads and traffic conditions.
Offline ophidia31
Re: DDM s/c mpgs?
« Reply #4 on: January 20, 2012, 01:17:15 PM »
So, taking into account universal elevations, road conditions, terrain etc, basically its breaking even with the s/c.
It is when the car is a daily driver. If this was a weekend car, I can care less about mileage. But i want something a little more power but not at the expense of fuel economy. Modding, to a point and doing it right way, is usually better for mileage as well if anything just stays the same.
But the graphs Ive seen from what would put me in either power range of eachother, the turbo made less low end torque than the s/c but made more high end hp. At track conditions where you may not be slowing down that much, i would say it might not make too much of a difference. But from the stop and go world, it might. I rarely travel the highway and when i am on it going to work, im there maybe a few minutes max. Other than that, most speeds are below 50mph.  ::cough:: Except on the twisty back roads to my friends house. ::cough::
And I remember that episode. Wasnt it because it had the power to not have to rev out and just lumbered along where the prius had to be pushed to keep up?
Re: DDM s/c mpgs?
« Reply #5 on: January 20, 2012, 01:25:46 PM »
What I'm trying to say is, the small marginal gains/losses in mileage due to the SC or TC or NA, will be far less of a factor than the driver in the seat..
It's because hybrids really only provide a real mileage gain due to a few small reasons.  1) Start-Stop at a red light.  2) Stop and go traffic where braking regenerates power regularly.  But in steady cruising with little braking and stopping both advantages play a very small role.
And comparing the M3's V8's engine efficiency in the runners, the DI, etc, compared to the Prius' antiquated combustion engine, there isn't much of an advantage, and it boils down to weight/aerodynamics.
Bottom line, if mileage is that much of an issue, the SC/TC/NA doesn't mean nearly as much as how you drive it.
Re: DDM s/c mpgs?
« Reply #6 on: January 20, 2012, 01:59:13 PM »
I'm stage III at the moment and average 23-25 combo, 28-30 highway,  but we have no flat roads here.  Best I ever got out of the car was stock with a tune and I saw 33 going across the flatlands to Kansas City for the first regional meet.
Offline ophidia31
Re: DDM s/c mpgs?
« Reply #7 on: January 20, 2012, 05:21:07 PM »
Right now I get maybe 27 @70ish on the highway. But thats up and down the mountains and hills of 81 on a 2hr trip from wilkes-barre to chambersburg to visit the sister. The design of this top kills this car. We must have the wake of a semi.
Re: DDM s/c mpgs?
« Reply #8 on: January 20, 2012, 08:28:43 PM »
Watch your wake in the rain at speed.
Re: DDM s/c mpgs?
« Reply #9 on: January 20, 2012, 09:38:08 PM »
You think are cars are bad, try my jeep.
It's a rectangle on wheels
In the driving you described, I'd suggest the sc over the tc.
Sc benefit is isn't power.  Tc needs to get to 2600 Rpms for he power to kick in
Offline diamoney
  • I coulda had a V8! But I'm not a fan of tomatoes.
Re: DDM s/c mpgs?
« Reply #10 on: January 20, 2012, 10:26:30 PM »
Put the top Down!!
In an experiment prior to s/c, I actually got my daily driver DIC # up to 32 MPG.  Dave asked me if that was real (not an interval reading).  It was, but I've never been able to hold back enough "charged" to match those numbers.  I do find that when I get into light -to-light driving, I get down to around 23 MPG while my usual experience is 27 or so.  I find my Long highway trips to have surprisingly similar mileage numbers, but then the added weight of the wife...
...No you DID NOT call me FAT!  DON'T you DARE call me FAT!!!
(I never said fat, didn't mean to imply fat, wouldn't DREAM of calling her fat.  I'll leave it at that)
And BTW, I haven't done so in along time, but I seem to recall actually getting better gas mileage with the top down.  For the record, I now have over 100,000 miles on my Stage I (at 90,000 Dave change the oil in the unit during the last open house).
« Last Edit: January 20, 2012, 10:30:43 PM by diamoney »
#000600 S/C
158000+ miles
'07 GXP T/C+
0-100 in what?
Re: DDM s/c mpgs?
« Reply #11 on: January 20, 2012, 11:08:20 PM »
 I have a T/C  and only MagnaFlow Cat back exhaust and a GMPP tune . My Last Full tank of Gas I got 322 Miles with it driving only 55-65 and Not getting into it AT All . I just filled up this Morning and it took 11.8 Gal. This was the Most Mileage I've gotten on a tank and forgot to see what I was doing Mileage wise . Wife says thats 27.3 MPG. BUT I rarely drive Sloe .<---- OOps Look  I can't even Spell the word. If my foot isn't in it I'm not driving it.
Re: DDM s/c mpgs?
« Reply #12 on: January 21, 2012, 09:23:39 AM »
Turbos will definitely get the mpgs. Just ask what the auto manufacturers are using today in their economy cars.
If you get the right turbo/tuning it can match or better a sc for responsiveness. And well exceed a sc in mpgs.
I drive 80% highway and don't see less than mid 30's in the winter for the 600 mile weekly commute. Summer with top up I'm half way through the 40's!
Offline ophidia31
Re: DDM s/c mpgs?
« Reply #13 on: January 21, 2012, 12:05:48 PM »
My dilema is different. If my foots not in it it, Im not moving.  :lol:
Everytime i see your sig it amazes me. Although driving in the snow this morning, makes me wonder if i want that instant torque available from the s/c. Just blipping the throttle broke the back end loose when I was already moving. From a stand still i had to be ginger off the line or else i wasnt moving anywhere other then sideways. Havent had that experience with other rwd vehicles Ive driven in the snow. Then again, i held the trac button till everything turned off because i hate nannies in the snow. The other cars didnt have those systems and were heavier than the kappas which probably made the big difference there. But those two systems would have been kicking on and off constantly and being really annoying otherwise. That alone made me think about things a little more as well. Since the turbo wouldnt be AS instant as the s/c thats in essence coupled directly to the crank.
Re: DDM s/c mpgs?
« Reply #14 on: January 21, 2012, 02:29:14 PM »
Actually the sc would be more linear than the spool up of a turbo. The sc is like having a larger displacement motor. Where the turbo spool up reminds of the elastic rubber band on a balsa wood plane.
Offline JimmyBaja
Re: DDM s/c mpgs?
« Reply #15 on: January 23, 2012, 09:07:02 AM »
Your mileage will go down because the instant rush of power is so much fun that it makes it almost impossible to keep your foot out of it.
 and you might as well forget driving in the snow, cold rain is bad enough especially if you turn traction control off... mister critterman has a story about the rain with no traction control and a slight incline.  :)
Re: DDM s/c mpgs?
« Reply #16 on: January 23, 2012, 12:15:57 PM »
OK, this is something that I keep meaning to address and keep forgetting to explain.
Do you know how the computer calculates your MPG in these cars?
Offline ophidia31
Re: DDM s/c mpgs?
« Reply #17 on: January 23, 2012, 12:22:31 PM »
No, but Im sure your going to tell us.  :D
Ive also learned not to rely on the dic because it can vary +/- up to 3mpg. And that to get somewhat close, the avg mpg should be reset everytime you drive the car because from fill up to fill up the average wont be as accurate since you drive different everyday even if it is the same route.
Re: DDM s/c mpgs?
« Reply #18 on: January 23, 2012, 12:37:18 PM »
No, please DO explain.  I've always though that the ECM should know exactly how much fuel it injects and exactly how many miles travelled, so should be exactly accurate.  It isn't, so I'd love to know why.
Re: DDM s/c mpgs?
« Reply #19 on: January 23, 2012, 12:48:49 PM »
How the DIC calculates MPG - Quick explanation - The MAF in the car coverts the air flow going past it into a frequency that is shared over the CAN bus to the ECM, BCM, TCM (if equipped) and dash. Based on a couple factors the DIC can calculate fuel mileage based on that air flow and other factors such as current speed, etc. This all works great, until you change something in the system that the DIC can not be adjusted for, and in the case of the HAHN turbos, that is the size of the tube that the MAF is located in. The stock tube size for an intake on a 2.4L Kappa is 2.75" OD, the HAHN kits use a 3" OD tube. Since the DIC can not be told you are using a different size tube, it is still assuming you are using a 2.75" OD tube. With the 3" OD tube the frequency the MAF outputs will be lower (since there is greater area in the 3" tube compared to the 2.75" tube) and so the DIC will think that there is less air coming in then actually is coming in. This results in the DIC displaying a higher MPG reading then what is correct because it thinks it is using less fuel then is actually being used. You can do the same thing with the supercharger cars, or naturally aspirated cars and the more you increase the size of the tube the better the MPG's look on the DIC.
Offline ophidia31
Re: DDM s/c mpgs?
« Reply #20 on: January 23, 2012, 01:01:25 PM »
Well would you look at that.
Also, dave, have you ever though of modifying the black box that jutts off the firewall in order to have the intake sneak through under the fuse box and sit above the battery? Seems like alot less for the s/c to pull through than curving under the s/c, run by the exhaust manifold and then up to the front of the car.
Re: DDM s/c mpgs?
« Reply #21 on: January 23, 2012, 01:06:36 PM »
We have looked at all kinds of ways of doing the intake over the years, and that would work great actually, but most people don't like to cut up their car when doing the install so we make the kit that requires the least amount of modification to the car. We also used to check the prototype systems with what we called the "Stove pipe" which was a tube that came off of the throttle body and went straight vertical with a filter on it, there was some power to be made with it, but not enough to warrant cutting the hood for the install ;)
Offline JimmyBaja
Re: DDM s/c mpgs?
« Reply #22 on: January 23, 2012, 01:13:52 PM »
Ophidia, don't let the mileage scare you off, it only drops a little if you keep your foot in it, way worth the gain in power & fun!!!
Offline ophidia31
Re: DDM s/c mpgs?
« Reply #23 on: January 23, 2012, 01:20:53 PM »
Nice, well that is something to think about. Thanks dave. I dont mind doing a little cut and chop for the better. Thats the whole point of modifying your car.
It isnt, as long as it breaks even I dont care.  But I also like to gain it. And what dave said, well, I like to do things a little different and that lets me do that. Most turbo kits are bolt them and well, thats it. Not much you can change to be a little different.
Offline TecSolOnt
Re: DDM s/c mpgs?
« Reply #24 on: January 23, 2012, 08:51:35 PM »
 I did a measure of  highway mileage on the way down to get my Stage  II S/C  installed ,  34 MPG,  that was based on gas pumped in and mileage off of  the odometer.  On the way back after the install , 34.5 MPG.  So I expect a bit better from the tune Dave applied.  In the end you punch the gas you pay,  normal cruising seems not to matter.  I'm sure it has a impact on around town vs. running down the highway on cruise control.  This is based on a Cdn gallon which is slightly larger than a U.S gallon so more MPG.
« Last Edit: January 23, 2012, 08:55:03 PM by TecSolOnt »
