Author Topic: DSS 1000HP Axles In Stock!  (Read 13995 times)
Offline Ricky@werks
« on: January 24, 2012, 05:21:28 PM »
We have one set of DSS 1000hp axles in stock. Retail price is $1699.98. For this set we will do $1500 plus shipping. Save some money and have no wait time!
The Home of WERKSracing products!
-Ricky Rodriguez
Home of the world's most powerful Solstice GXP - 415whp!
Ricky@performanceautowerks.com
www.werksracing.net
815-439-4547
Offline Bottoz
Re: DSS 1000HP Axles In Stock!
« Reply #1 on: January 24, 2012, 06:07:15 PM »
Details on the CV Joints please.
... in my other car, the Axle Shafts are always fine, it's the joints that fail.
07 Sky Redline
84 Porsche 944SPEC Racecar
02 TrailBlazer
Offline Ricky@werks
« Reply #2 on: January 24, 2012, 06:40:36 PM »
The CV joints are 108mm Porsche ones. Very strong. These things are seriously beefy
-Ricky Rodriguez
www.werksracing.net
815-439-4547
Offline Bottoz
« Reply #3 on: January 24, 2012, 06:47:30 PM »
Nice! And funny you should mention Porsche. I've had rebuilt/reman'd axles for my Porsche Race Car and the CV joints always fail on the race track. ALL of them! When I switch to 20+ year old junk yard OEM Porsche axle/CV joints, they're 100% all day long.
07 Sky Redline
02 TrailBlazer
Offline Ricky@werks
« Reply #4 on: January 24, 2012, 06:51:24 PM »
Yeah rebuilt or reman'd stuff tends to not hold up well to the abuse. They are usually solid for just driving around but when you put them to the test, more often than not they will fail far before an OEM part
-Ricky Rodriguez
www.werksracing.net
815-439-4547
« Reply #5 on: January 24, 2012, 08:49:38 PM »
I have the Driveshaft Shop 600hp Axles............
they are NICE!!! :)
definitely these axles are worth it!  :)
I believe that WERKS sell the 600hp versions as well...
« Reply #6 on: January 24, 2012, 09:20:39 PM »
I thought stock axles were good to 600hp?
« Reply #7 on: January 24, 2012, 09:43:58 PM »
and is this for 1000whp? slicks? street tires?
« Reply #8 on: January 24, 2012, 09:57:36 PM »
What are they made from?
« Reply #9 on: January 25, 2012, 09:02:24 AM »
these are the 600hp set that DSS gave me.
Frank the owner of DSS  told me the set can easily handle 600whp on drag slicks all day....
« Reply #10 on: January 25, 2012, 09:23:51 AM »
Are you going to run slicks or street tires antonio?
Street tires & wheel hop tend to destroy half shafts. I have seen street tires snap half shafts off at the spline (in the diff)
I am really tempted to get those from werks, however I want to see if the stockers hold up first.
Ricky,
What is the normal lead time on these shafts from the DSS?
« Reply #11 on: January 25, 2012, 09:30:41 AM »
on the streets and probably in scca events,  I'll run my 295s Nitto NT05...
but once I get a roll bars.....I'll have drag slicks in a drag racing event.............
I believe Ricky already mentioned on his first post that the DSS units are IN STOCK
« Reply #12 on: January 25, 2012, 09:47:49 AM »
taken from dss
1000hp axles:  The Pontiac Solstice / Saturn Sky 1000HP Axle Kit features a direct fit outer CV made from a high grade proprietary material, Porsche style 108mm inner CV, our aerospace quality torsional center bars that twist significantly more than a factory unit, allowing them to absorb a great deal of the shock produced by high horsepower applications. The axle kit also includes bolt-on stubs into the differential.
« Reply #13 on: January 25, 2012, 10:35:36 AM »
Another question for Ricky:
Are they for the GXP or N/A?  I ask because the 600hp set are for N/As only.
« Reply #14 on: January 25, 2012, 10:39:33 AM »
Im not Ricky but.....
I double checked with DSS today over the phone, and the 600 hp axles will also bolt on to the gxp/redline.
You will need to disassemble the factory outer CV's and assemble them with the included CV races of this kit.
« Reply #15 on: January 25, 2012, 10:42:21 AM »
OK, not Ricky, what about the ones that this thread was supposed to be about?
« Reply #16 on: January 25, 2012, 10:49:02 AM »
geeezz...some attitude there.........Im just helping out.....so easy now
anyways, to answer your question its for a gxp/redline.
dss can send you anything you want..........non-gxp or gxp
Offline Ricky@werks
« Reply #17 on: January 25, 2012, 11:24:54 AM »
Slicks are actually much more friendly to axles than street tires are. The softer sidewall absorbs a good amount of the shock that would normally go straight into the driveline
Ricky,
Normal lead time is a couple weeks but we have a set in stock ready to go
They will fit either
-Ricky Rodriguez
www.werksracing.net
815-439-4547
Offline Ricky@werks
« Reply #18 on: January 25, 2012, 11:25:28 AM »
Thanks for answering a lot of the stuff for me Ant. Appreciate it
-Ricky Rodriguez
www.werksracing.net
815-439-4547
« Reply #19 on: January 25, 2012, 11:54:23 AM »
Yes street tires and wheel hop hurt half shafts. That is why I asked if the "1000hp" rating was if you were on slick or street tires.
So I would imagine these shafts are rated for 1000hp on slicks and maybe 700hp on street tires? would you agree?
« Reply #20 on: January 25, 2012, 12:09:35 PM »
i think, if the "stock axles" which you mentioned previously can handle 600hp with street tires.
I honestly believe that even the 600hp rated axles can withstand more than 600hp w/ street tires
and of course more hp rating with the 1000hp axles....
The WERKS race car alone is being abused at the track and I think it has stock axles.  And running fine.
And there are several kappas out there already are in the 600hp range using stock axles w/ street tires w/ no issues.
I think these DSS kits will be able to handle more abuse than the stock axles....
« Reply #21 on: January 25, 2012, 12:31:21 PM »
Well I plan to abuse mine :devil: So i guess hopefully no one needs these axles before I break my stock axles :)
« Reply #22 on: January 25, 2012, 12:39:52 PM »
so what happens when you break yours?    how about the affected parts due to axle breakage? :)
its almost pushing a 500whp LNF w/ stock internals....waiting for the internals to get damaged.  If a stock rock bends.....other engine internals will be affected as well.
« Reply #23 on: January 25, 2012, 12:47:14 PM »
The one I saw break in person, he drove it home and then we diagnosed it in the garage.
We drained the rear diff, pulled the broken shaft, flushed with brake clean, and replaced with an oem shaft and refilled the diff. (not a kappa) I am sure our cars would be the same, but not sure if we could drive home as easily.
I am not sure what power numbers you are talking about here, but I have not witnessed a half shaft failure affecting a motor.
Run before breaking the axle (Half launch ~4000rpm)
Aarons evo 11.73 @ thompson
Run breaking the axle (Full launch 6500rpm)
Evo breaks LR half shaft
Keep in mind these were OEM shafts and there was over 50lbs of glue on the track that day in the first 100' His broke at the spline inside the diff.
« Reply #24 on: January 25, 2012, 12:54:24 PM »
Im not saying that it will affect the motor :)   I just gave an example about if a connecting rod breaks....it might affect other engine internals as well.
so if an axle breaks during high rpm.....will it affect other stuff undercarriage?   Not sure.
that's why I was asking.
I havent seen a kappa breaking axles though...since there's no high powered kappas out there............unlike honda civics and evos ;)
