Author Topic: FS: DDM tuned ECM for 2008 GXP  (Read 3171 times)
Offline DickW
« on: February 10, 2012, 10:06:54 PM »
I HAVE A SPARE ECM TUNED BY DAVE. IT IS FOR AN 08 GXP AUTOMATIC WITH GMMP UPGRADE. I DON'T KNOW WHAT OTHER YEARS COULD USE IT.
$300.00 SHIPPED.
276.5 HP  290.2 TORQUE
« Last Edit: February 12, 2012, 03:17:55 PM by DeepBlueGXP »
Re: FOR SALE: DDM tuned ECM for 2008 GXP
« Reply #1 on: February 10, 2012, 10:16:21 PM »
DickW,
The ECM will fit 08 and 09 turbos.  It will have to be reprogrammed in order for it to be used in any car other than yours, but that can be done with HPTUNERS or other.
Best of luck with the sale.  It will NOT work in any 07 or any 2.4.
Offline Brazen17
« Reply #2 on: February 10, 2012, 10:38:27 PM »
What hp is it tuned to?
Offline U4EA
« Reply #3 on: February 10, 2012, 10:50:24 PM »
Auto or Manual trans.?
Offline DickW
« Reply #4 on: February 11, 2012, 01:12:26 AM »
 I added Automatic and 276.5 HP and 290.2 Torque to the original. I can send you a graph from DDM.
« Reply #5 on: February 11, 2012, 12:17:40 PM »
I think the auto or manual is a simple binary digit change in the tune, so it might be able to be used for either.  I would defer to DBG as he is my source for that info.  That may only apply to the 07.... But worth looking in to
« Reply #6 on: February 11, 2012, 01:19:44 PM »
GJ is correct.  The auto is just a bit code change to tell it not to look for a clutch pedal being pushed in.
Offline spartan
« Reply #7 on: February 11, 2012, 01:37:04 PM »
Anybody know if ECMs for GXP and Redline are interchangeble for 08 and 09 models except for changing the VIN?  I asked at the dealership and they did not know.
« Reply #8 on: February 11, 2012, 02:07:50 PM »
Yes.  Turbo ECMs all the same 08-09-10
2.4 ECMs all the same
2.0 and 2.4 ECMs different.
« Reply #9 on: February 11, 2012, 02:08:32 PM »
GJ is correct.
Let the history books show on this day in history....
Offline Brazen17
« Reply #10 on: February 11, 2012, 06:04:51 PM »
 :rofl:  :D  :lol: ...Wait a minute. That's kind of scary   :gaah:
Offline Brazen17
« Reply #11 on: February 11, 2012, 06:07:18 PM »
Would there be any downside to going this route (ie does it need to be retuned to my car)? Do you need the dealer to swap ECM's?
« Reply #12 on: February 11, 2012, 06:20:56 PM »
you need the vin reprogrammed to your vin and then you have to do a security relearn cycle.
« Reply #13 on: February 11, 2012, 11:34:49 PM »
So, if I put this PCM in my manual-transmission '8 GXP and did the necessary "integration steps", then it would disable the starter-clutch interlock and allow my car to be started without pushing the clutch pedal ?
If so, sweeet ! :)
