Author Topic: Key On accessory fuse location.  (Read 2590 times)
« on: February 14, 2009, 10:33:03 PM »
Need to tap into a key on accessory fuse so I can run a XM radio unit.  The unit I have can be taken out of the vehicle or I could mount it permanently in the vehicle.  I want to do the key on accessory so that if I forget to turn off the unit it will shut off once the I take out the key and open the doors.  Is this possible?
Thanks
Re: Key On accessory fuse location.
« Reply #1 on: February 14, 2009, 11:23:39 PM »
#18 I believe
« Reply #2 on: February 14, 2009, 11:36:50 PM »
A multimeter is your friend but yeah, I believe it to be #18 as well.
« Reply #3 on: February 15, 2009, 01:58:33 AM »
Thanks guys.
« Reply #4 on: February 15, 2009, 09:03:34 AM »
All above are correct, it is in the passenger footwell fuse box
Offline JRinKY
« Reply #5 on: February 15, 2009, 11:54:23 PM »
Fuse 20 is the one most commonly used, and I know that it is part of the RAP circuit. You'll have to check on 18, the service manual lists it as "not used" and is not on the schematics.
« Reply #6 on: February 16, 2009, 01:56:52 AM »
Fuse #18 is Hot and key on.
Thanks
