Author Topic: Think I might have found the bulk 3 bar T-Map o-rings  (Read 3309 times)
« on: July 11, 2012, 10:53:06 PM »
Not sure if anyone else has looked into the size of the 3bar T-Map o-rings.  You can get replacements from Crate Engine Depot but there around $3 an o-ring plus shipping.
http://www.ebay.com/itm/Black-NBR-O-Rings-Oil-Seal-Washer-13mm-x-6mm-x-3-5mm-50pcs-/180921470088
Could be this one though.
http://www.ebay.com/itm/50-Pcs-Black-Nitrile-Rubber-O-Ring-Grommets-Seal-7mm-x-13mm-x-3mm-/350580068348
Here is the one from Crate Engine Depot and it looks black not blue.
Eye balling the size from the picture I would say it's the 13mmX6mmx3.5mm which is the first pic.
http://www.crateenginedepot.com/O-RING-3-Bar-Map-Sensor-12626998-P17760.aspx
« Last Edit: July 12, 2012, 12:49:46 AM by tazz »
Re: Think I might have found the bulk 3 bar T-Map o-rings
« Reply #1 on: July 11, 2012, 11:37:29 PM »
I have some spare blue orings.  Unfortunately I do not have one of the digital measures To check the size.
« Reply #2 on: July 11, 2012, 11:43:11 PM »
Use the tail end of a drill bit Elf assuming there are no sharp edges.
Offline JoshMcMadMac
« Reply #3 on: July 12, 2012, 08:21:38 AM »
I have a small bag of them.  McMaster Carr part #9464K118.  Look it up on their site and it gives the dimensions.  If the eBay ones are the same size, they are cheaper.
« Reply #4 on: July 12, 2012, 01:04:48 PM »
13mmx6mmx3.5mm are the same size as the ones you have but yours are Viton vs the ones on ebay are Nitrile that's probably the reason for the price difference.
« Reply #5 on: July 12, 2012, 02:35:15 PM »
That makes sense.  You should be perfectly fine with either material in the environment it will see.
