Author Topic: New Product - WERKSracing WR-2 LNF Bolt On 450hp Turbocharger!!!  (Read 23719 times)
After a couple years of time investing thousands of dollars and countless man hours in developing our LNF Borg Warner EFR Turbo kits and exhaust manifolds only to have Borg Warner pull their EFR supply and resources to dedicate them to Indy Car (Non-open wheel spec) we had to do something about it!!!
We listened to what our customers wanted which was a higher flowing bolt on style of LNF tubocharger so we developed the all new WERKSracing WR-2 LNF Bolt On 450hp Turbocharger!!!
WERKSracing WR-2 on display at the 2012 CED meet -
Installed Picture -
Top view -
Product description -
This is it, The Ultimate LNF Bolt on turbo upgrade, the WERKSracing WR-2 Bolt on LNF Turbo Upgrade is here!!!
On a customer Saturn Sky Redline we made 390whp and 408ftlbs TQ on our Mustang dyno with 93 Octane fuel!
Stock appearing exhaust and compressor housings for a completely bolt on sleeper upgrade!!!
Supports up to 450hp!!!
Exhaust side Black Ceramic Coating included in price!!!
Forge Billet Aluminum adjustable bypass valve standard, can be deleted bringing price of turbocharger down an additional $160.00
Core exchange program
Incredible response
51mm leading edge technology billet aluminum compressor wheel
56.5mm exhaust turbine wheel
Internal WG actuator included
Comes complete with all necessary lines and fittings
Compressor housing powdercoating = $50.00
Pricing -
$2025.00 (With your core, Forge Bypass Valve plus shipping)
$2525.00 (Outright with Forge Bypass Valve, plus shipping)
1 year warranty from the date of purchase
2-3 week current build time.
Starting at $1865.00 you can order yours today here - http://www.performanceautowerks.com/catalog/product_info.php?products_id=1925
Re: New Product - WERKSracing WR-2 LNF Bolt On 450hp Turbocharger!!!
« Reply #1 on: July 19, 2012, 01:05:48 PM »
 :yay: :yay: :yay:
looks really promising!!
the exhaust side comes from the factory turbo?
what about tuners supporting a tune for this set up?
will stock clutch be OK?
« Last Edit: July 19, 2012, 01:12:03 PM by Arabas »
« Reply #2 on: July 19, 2012, 01:29:42 PM »
looking good WERKS!!!
good job Dave! :)
Offline Brazen17
« Reply #3 on: July 19, 2012, 02:14:39 PM »
Did the RL have any other supporting mods?
« Reply #4 on: July 19, 2012, 03:00:26 PM »
What EFR is this?
At what boost the dyno was made?
The turbine housing is the one from stock turbo so no manifold or adapter is required?
Looks great, if it was released in beginning of 2011 I would have bought it.
« Last Edit: July 19, 2012, 03:15:13 PM by Kelu »
« Reply #5 on: July 19, 2012, 03:39:36 PM »
What EFR is this?
I don't think its EFR turbo kelu.
dave mentioned:  Borg Warner pull their EFR supply and resources to dedicate them to Indy Car (Non-open wheel spec)
« Reply #6 on: July 19, 2012, 03:54:51 PM »
Than what turbo is this?
« Reply #7 on: July 19, 2012, 04:59:22 PM »
Yes, here goes -
3" Magnaflow exhaust
K&N panel filter and WERKS modified airbox
WERKS 3" high flow cat
WERKS valve springs
WERKS 2.5" Intercooler pipes
Hahn FMIC
WERKS Phenolic intake and throttle body spacers
Wiseco pistons
Carillo rods
ARP Head Studs
WERKS MLS head gasket
WERKS dyno tuning
« Reply #8 on: July 19, 2012, 05:01:06 PM »
Antonio is definately correct, it is not a Borg Warner, it is a custom piece made for us to our specs by Precision Turbo, the same folks who make our WR-1 "Big Wheel" turbo.
« Reply #9 on: July 19, 2012, 06:26:01 PM »
Great to hear that as we have a local PTE dealer. Thanks for sharing.
« Reply #10 on: July 19, 2012, 07:17:16 PM »
They will only be available through us I, it is a private label part designed by myself and PTE.
« Reply #11 on: July 19, 2012, 07:30:51 PM »
There other considerations when it comes with a dealership not only for buying it but also in cases of warranty when shipping a turbo from here to US costs like 400-700$ :D
Offline spoolin
« Reply #12 on: July 19, 2012, 08:46:00 PM »
Is it a ball bearing or journal bearing CHRA?
Coming from Precision I'm guessing it is ball bearing.
« Reply #13 on: July 19, 2012, 11:14:11 PM »
Very interesting.
Quick question.
Will this work with a stock sized cat?
Like the solo hi flo that fits the k04?
What is the side by side comparison/contrast to the BNR K04/2871 turbo?
« Reply #14 on: July 19, 2012, 11:34:43 PM »
Damn!!!  No joke, if this were available about 6 months ago, I would have went this route, and not my crazy stereo/radar detector/gauges project . . . which actually cost even more all together than this kit even with a core charge  :nuts: :tool:
Offline spartan
« Reply #15 on: July 20, 2012, 10:21:16 AM »
Does that price include the tune that got you to 390 whp?  You mentioned dyno tuning ref the RL you used but it isn't clear in the other write-ups.  I have the GMPP tune.  Lastly, what would the installed package cost if one wanted the upgrades above that were made to the mule (minus the cat and exhauast, assuming the Solo prods fit).
« Reply #16 on: July 20, 2012, 10:25:35 AM »
One other question
Does this require an external BOV, or does it recirculate like the like K04.
Offline spoolin
« Reply #17 on: July 20, 2012, 11:48:30 AM »
One other question
Looks like it just uses a machined out stock K04 compressor cover so it would be just like stock and recirculate. They are just offering the Forge unit as an upgrade.
« Reply #18 on: July 20, 2012, 02:32:47 PM »
Yes it is a hollowed out K04 compressor housing and yes we offer the Forge as an option but strongly reccomend it as standard for this turbo.  The turbo flows a lot more air than the stock unit and you will most likely be running a lot higher pressure as well.  The Forge unit does not use a rubber diaphram that could tear, holds pressure better and is much faster acting for better response in between shifts.
« Reply #19 on: July 20, 2012, 02:38:37 PM »
We do not include any tuning with this turbocharger, we do offer e-mail with datalogging tunes for $350.00.
For a breakdown of installation and exact parts wanted/needed please e-mail me at dave@performanceautowerks.com and I can put together an estimate and e-mail it back.
« Reply #20 on: July 20, 2012, 02:39:22 PM »
Dual ceramic ball bearing CHRA
« Reply #21 on: July 20, 2012, 02:40:37 PM »
Very interesting.
Quick question.
Yes the exhaust housing is flanged for the stock or any driect replacement aftermarket high flow cat or cat delete pipe.
Offline Brazen17
« Reply #22 on: July 20, 2012, 02:51:01 PM »
Would it work "detuned" with stock internals until I can upgrade internals at a later date. Somewhere on the order of 350-375 bhp? I won't be able to do a rebuild for a few more years. Unless of course disaster stikes...
« Reply #23 on: July 20, 2012, 03:49:38 PM »
Brazen, I will not be comfortable using it de-tuned.
if you do, you might not have to wait for 2 years...to do a an engine rebuild.   It will be sooner than that.
« Reply #24 on: July 20, 2012, 03:52:24 PM »
If the whp is under 400 and you have a good tune with no knock you don't need to upgrade the internals.
The thing you should worry about is the stock rockers, lash adjusters and valve springs if you plan on being in the 7000 rpm range on a regular basis
