Author Topic: help inner fender liner  (Read 12618 times)
Re: help inner fender liner
« Reply #25 on: July 26, 2012, 01:41:22 PM »
I think it was called DEC
« Reply #26 on: July 26, 2012, 01:48:03 PM »
Thank You got it ordered and shipping on Thursday July 26,2012.
Bobby, can you please measure the box and approximate the weight when it arrives?
Offline Goat67
« Reply #27 on: July 26, 2012, 01:53:11 PM »
I bought a pair from crate engine depot about 4 months ago, while ordering some other stuff, cost was $57.00 each, plus shipping. As often as these things crack, I would put the cheapest thing I could find on my car. I had to put one on 6 weeks ago, in less than 1500 miles two of the screw holes have cracked. I am trying a hopefully better approach at mounting them.
« Reply #28 on: July 26, 2012, 02:24:17 PM »
The ol' "cracking at the holes" issue has been the topic of a few recent posts/threads.
Having put some thought into this, my approach (should I need to replace mine) will be to drill the holes a little larger.  Apply heat to reseal the hole edges.  Then squeeze in a dab of 100% silicone caulk in each hole prior to fastening with the push pins.
The caulk will set, but still be flexible, taking up any road vibrations and thus not straining the holes and (hopefully) not causing cracks in the future.
Who knows?  Worth a try.
« Reply #29 on: July 26, 2012, 04:58:11 PM »
Certainly worth a try TS. I"m happy that mine haven't cracked (yet?) since my dealer reinstalled them with only 2 screws and the rest push pins.
« Reply #30 on: July 26, 2012, 08:01:39 PM »
Yeah test it out soon.  I'm replacing mine in a couple of months, I had a dwarf elff climb on it and destroyed it.  It was fine when he was elff size.
« Reply #31 on: July 26, 2012, 08:23:05 PM »
Wait, I'm confused.  Is a dwarf Elff larger or smaller than a regular sized Elff?  This is very confusing.
« Reply #32 on: July 26, 2012, 08:48:16 PM »
over 13 real pounds larger, not to be confused with elff pounds.
« Reply #33 on: July 26, 2012, 09:43:07 PM »
You were drinking a 13£ lager and did what to Elf?
I think I might know why his hips are hosed up.
« Reply #34 on: July 26, 2012, 10:57:19 PM »
Kelu the company is  "rock Auto.com "   Maybe the problem is they are so stiff and have no Flex or give at the screw points . R A had (4) for the GXP left side Left. I will measure the carton it comes in it should be here Satursay or Monday,
