Author Topic: Daniel from Germany  (Read 11005 times)
Offline Daniel
Daniel from Germany
« on: August 14, 2012, 02:57:26 AM »
Hi guys,
I´m Daniel from Germany and i´m a proud user of the opel gt. I have got a lot of modifications on my gt.
Currently i have got to less hp i the moment my gt has got around 350PS and i´m looking for more.
My aim is 450ps :tool:
I hope that i found a lot of tips in our forum  :D
Offline hammy221
Re: Daniel from Germany
« Reply #1 on: August 14, 2012, 06:16:25 AM »
Looking good
« Reply #2 on: August 14, 2012, 07:00:09 AM »
I love the paint scheme on the car and welcome to the forum!
« Reply #3 on: August 14, 2012, 09:16:48 AM »
Looks good, looks fast. lots of custom work.
« Reply #4 on: August 14, 2012, 09:39:58 AM »
im intrigued by the exhaust... do you have any close up shots of the exhaust and rear valence?
« Reply #5 on: August 14, 2012, 09:48:45 AM »
Welcome to the forum!
Pls post info About the hard top.
Mechanical mods?
« Reply #6 on: August 14, 2012, 10:02:28 AM »
Welcome to the Kappa Performance Forum Daniel.  Awesome to have another member from Germany here with an Opel GT!  I like you already cause I am half German and ancestors came over from Hanover, Germany way back.  You will meet some members here from overseas and really from many countries outside the borders of the USA!
« Reply #7 on: August 14, 2012, 10:26:34 AM »
Welcome onboard !
Is the car used in a competitive event ?
Offline Daniel
« Reply #8 on: August 14, 2012, 03:44:03 PM »
Yes, it is for competitive events.
@miller11386: I will make photos on the weekend.
@Arabas:Yes, i made a lot of mods on my GT but not yet on the engine. I´ve got a new software and a katless 3" exhaust system.
« Reply #9 on: August 14, 2012, 04:48:02 PM »
Welcome sweet ride.
Offline Brazen17
« Reply #10 on: August 14, 2012, 05:03:07 PM »
By the way, EXCELLENT first post. Cut Kelu off right at the knees.
« Reply #11 on: August 14, 2012, 07:22:03 PM »
He's still taller than Elff.
« Reply #12 on: August 14, 2012, 10:11:46 PM »
No Kelu is the short one.
That is one awesome looking GT.
Awesome first post.
Welcome aboard!
Would you mind listing your mods?
Offline Daniel
« Reply #13 on: August 15, 2012, 02:52:04 AM »
My mods:
-full welded rollcage
-1 Recaro Pro Racer Seat
-Sparco Snap Off steering wheel
-KW Competion suspension
-370mm Brembo Brake in the Front
-Smoothline Hardtop
-no ABS and Electronic  Stability  Program
-3" katless Exhaust
-BMC Airbox
-Aircondition remote
-Fidanza Flywheel
and a lot of weight things. Actually is the GT around 1150KG with petrol
In the future I want do a lot of other things:
-4,11 Differential with a cooler
-a other turbo with more hp, but I want to keep my current Exhaustsystem, can anybody help me ?
-my GFK Hood to paint
-a bigger Brembo Brake in the rear
-a new color
-a carbon spoler in the rear
« Reply #14 on: August 15, 2012, 04:11:45 AM »
What tune do you have?
Also have u found a 4.11 diff?
As for turbo with the same exhaust side, u can check ddm 2871 (but with e47 fuel to get around 400hp), also wait for hahn 20g to be released, as well as eds new turbo kit
Offline Daniel
« Reply #15 on: August 15, 2012, 05:53:19 AM »
Yes, I found a Differential Kit here in Germany to built the 4.11 technic in my Diff.
Is that the Hahn 20g Turbo ? ( 412RWHP / 441RWTQ Sky Red Line with Hahn Turbo Setup )
If I want to drive E85 I need other injections, right?
« Reply #16 on: August 15, 2012, 06:51:29 AM »
that is a hahn turbo.
To run E85 you have to replace the valve seals on your injectors to prevent injector seal failure.
Also if you want to go past 480PS you will need an 5th injector to over spray e85 in the manifold.
« Reply #17 on: August 15, 2012, 08:36:12 AM »
What type/kind of competitive event ?
« Reply #18 on: August 15, 2012, 09:51:51 AM »
I am not sure how if you need to Modify the Downpipe to connect to the Hahn turbo.
They are in the process of revamping their website with new offerings so you should have an answer soon.
I do know that the DDM 2871 Kit that I have
http://www.ddmworks.com/sky/engine/lnf_gt_turbo_upgrade.html
Will work with your existing downpipe and as stated, with E47 you can break 400whp.
If you run E47 vs E85 a good tuner can utilize the stock fuel system.  It's quite robust.  The difference in HP to bump from E47 to E85 is only about 5 HP, so IMHO, it's not worth the jump if you can avoid having to add additional components.
Offline Brazen17
« Reply #19 on: August 15, 2012, 02:57:39 PM »
Offline Whip
  • Global Moderator
  • Air Force Retired
« Reply #20 on: August 16, 2012, 09:49:24 AM »
Welcome to the forum, Daniel.  You will find lots of useful information here and meet a lot of nice people.  Your GT is awesome.
GMPP Stage II Tune
Deepblue turn signal mod
Burl wood dash
Offline Sky4Two
  • Sky4Two
« Reply #21 on: August 20, 2012, 10:31:48 AM »
Welcome Daniel, glad to have you aboard.......stanich1
Blooper
